My '68 Roadster project
Emptytank
Hi, since I have not posted in this particular forum, I'll start with a little history.
Last December I bought this 68 roadster, I wasn't ready to start work on it, but I have been wanting one of these for a while and snagged this one.
I drug it from one field ...just to put it back in another field :blink:
When you don't have a top for protection from the weather, I found that an old pickup bed liner does a good job of keeping the elements out
Now that I have finished my El Camino project, i'm ready to get busy on the Datsun
So now the Roadster occupies my empty space in the shop
I found these Ansen sprint wheels with the tires on Craigs list, good looking rollers
So now it's time to give it a good look over on the lift
Not too bad overall
Time to gut this thing and get down to the bare frame. I have been soaking every fastener with PB blaster preparing for the teardown
This needs to come out first
Next is the steering column, dashboard, exhaust system, and disconnect the body from the frame.
While I was at this point, I was talking to a guy from work who is kind of a motorhead, he asked me if I wanted a body dolly?
Hell Yea! I scored this for free! He just wanted it gone, it's almost like it was made for this car
So now i'm at the frame, a little surface rust, but very solid, no repairs needed......well i'll find out after the frame comes back from the blaster
So that is where i'm at right now...stay tuned for updates
I hope this thread satisfies the need for pics :rolleyes:
  • Replies 30
  • 2 months later...
OK time for some updates. Been a while since I posted, been getting rid of grease.
I took the frame to the blaster, had it completly stripped, a minor repair done, and painted. This little car is so fun to work on! I was able to load and transport the frame by myself, and it fit in the bed of my El Camino.
Now it's really nice that all of that crap is somewhere else, and not floating around in my shop.
Here is the freshly painted frame, rear end back in so I can move it around.
Cleaning up the 'reusable' parts, new lower ball joints (Holy crap those were expensive!) Good thing the uppers were in good shape
Time to reassemble the front end
Much better now
These are kind of nasty, but still within spec.
Whoever had this car before me might of planned on it sitting for a while, the hubs were packed full of marine grease, hard to clean out, but the bearings and races were near perfect. A few grease seals, repack with the correct high temp wheel bearing grease, a quick cleanup on the lathe, replaced the studs and I ended up with these.
bad news is that the calipers were not as serviceable, pretty bad really
So after a little research on 311.org I decided to go with the Volvo calipers. The new (not rebuilt) calipers and ceramic pads cost less than having just one of the bores resleeved, and that would be X 4, and all the related hardware.
Well that's it for now, back to work, and more postings as I go.
Mick
  • 3 weeks later...
Hi again.
In my last post I was looking into converting the front brakes to use the Volvo calipers, and after researching the cost of rebuilding the stock roadster brakes I went ahead and did the conversion.
It wasn't as hard as I thought it would be, just some details that had to be done prior to installing, I had a machine shop turn the rotors to reduce the diameter by1/4 ", Then I had to drill the caliper mounting holes out to 1/2" , and use various size washers to shim them into the correct position/ centered to the rotor.
Other that that it is a real nice conversion / upgrade.
So instead of using these.
I now have this.....
Not to be a dick...:huh: ...but your rear spring shackles are on wrong. Man, you've put alot of work in all that!!!
When you start working on the body, these cars tend to rot in the cowl area. Only way to see it is climb in head first in the foot well area and look up to where the air vents are.
Good luck!!!!
How are they supposed to go? I never took them off of the rear end housing, so they must have been wrong for a very long time.
Here it is before I took it apart
I'm all ears?????
Very nice! Aptitude, resources, and dry storage. This is going to way cool.
Subscribed to the thread :cool:
Engine in camino?
It's the original 283, I just rebuilt it .030 over bore, hardened exhaust seats, ect. nothing special except adding disc brakes, rebuilt the front end, and installed air conditioning.
I did freshen up the interior while I was at it, and added factory gauges in the dash.
And you can see by the fuel gauge, why I go by 'Emptytank'
how are the supposed to go on???
The leaf spring eye goes above the 'S' bend part, not below it. I was trying to mark a pic up, but for some dumb reason I can't post it????:(
Here's a link to the original dealer parts catalog if you want your head to explode!:frantics:
http://webpages.csus...sandhoff/fiche/
I think I know what your talking about, I thought that looked weird.
That must be a cheap way to raise the rear when the leafs get a little flattened out, because I have seen other Roadsters with them set up like that.
PS. Please ,be a dick if you see anything else that is wrong, this is my first Datsun, and the reason I joined is for the experience and knowledge you guys have.
Until more progress :cool:
Time for an update.
Well since i was starting to get burned out with the frame and suspension, I decided to turn my attention to other things to break up the monotony, when you have something drug in from a field, almost every piece needs some sort of attention, so this week was the seats.
These were a little weathered but not ripped or seperated at the seams, but the foam was a little flat and the webbing was stretched beyond use.
A little tear down shows this
Cannot reuse these, so a $20.00 roll of generic seat belt webbing, an hour or so on my friends sewing machine and i have fresh webbing
Now that old flattened foam needs some attention, looking at it reminded me that when I redid my Corvette interior I saved the old seat foam from that, a trip up in the attic and drug these down.
Real close to the datsun, except for that flat, tired part, a little sculpting with a razor and ready to reassemble.
Now the vynal has some serious weathering, and is now actually grey instead of black
A little acetone made them a little better, but after that i just tried some Mguires polish and it made a night and day difference!
The seat bottom on the left is the finished product, frame cleaned and painted, new webbing, the old Corvette seat foam and the acetone/ polish finish
Now I have to reassemble the remaining parts and the seats are ready for when the rest of the car is
