just got a 1200!
squatches
  • Replies 179
I've had a problem on my a15 dieseling. If you know your anti-dieseling solenoid isn't bad, adjust your choke, make sure it isn't sticking. Also adjust your idle mixture, make sure it's spot on. My a15 is real picky about idle mixture. All else fails, stall it out in 4th while shutting off the engine.
anyone have any problems with their a14 dieseling?
Yes. But this...
Most Datsun owners I know have become masters of the "clutch kill". Right foot on brake, left foot on clutch, slide it in a higher gear, and while holding firm on the brake pedal you turn the key off and release the clutch at the same time.   :thumbup:
heres a pic of dash, ill get some better ones after i clean it up some.
i got bored and decided to do something with all my emblems.
and a tattoo my friend started on my leg, this is his first tattoo on someone besides himself.   its also not finshed yet, rest will be done later when he is off of work.
  • 3 weeks later...
