just got a 1200!
squatches
  • Replies 179
That's awesome man, I love 1200's.
You should stuff a long rod L18 in it and build a rev king!
i thought about using one of my l20's but i dont wanna pull it out of my truck, and i havent ventured upon a l18 near me yet.
im really liking the thought of a single cam turbo in there.
Build a rev-king L20B -- 45mm webers and a large duration cam! More power than an L18 built similarly and it doesn't need custom rods.
But the KA will beat either. It's 20% larger AND has two intake valves per cylinder.
a ka would be nice in there but i dont want the weight that comes with it lol
this engine is the single cam or ca18et, he doesn't have a transmission with it tho so ill have to track one down if i go that route. I would like to do the ca18det but i havent found one that was in my price range, which is cheap lol. i also dont want to have to cut the trans tunnel so i may just go with an a series again.
pulled engine and trans out today, gonna be cleaning up the engine bay while its out.
Also pulled out drivers seat which was only held in with three bolts and the front mount is a ghetto fab with angle iron.
i will be redoing the mounts with some square tubing when i fix all the holes in the floor and the frame rail.
found this under the carpet. :mad:
i didn't get a pic of the 1 1/2 foot round hole under the panel.
Got pics of the seat mount? Angle iron is a strong way to do it, if done properly.
Or do you mean the seat riser on the floor was replaced with angle iron. Bad idea.
the riser or mount on the floor where the seat bolts to was replaced with angle iron.
I have a cheap L16 and am "local" and off all week. PM me if interested.
im not sure what all is needed to swap and l series into a 1200, im still not sure if im gonna stay a series or not. i dont want to hack up car anymore haha. but when i decide i i want to go l series ill hit you up.
Why o why do people cut a structural unibody crossmember like the front floor riser??? :yawn:
When swapping L-series, a lot of guys use cut-n-weld, which I hear can be quick and easy. But you don't have to cut anything to swap in L-series into 1200 ... IF you use the right combination of parts. Use the 510 4-speed and stock 1200 auto driveshaft and front sump & oil pickup from 810 or 720. The only thing I'm not sure about is the tunnel, I know using the 1200 auto tunnel allows the largest Datsun transmissions. But the smaller 63 series I think will fit in the smaller 1200 manual tunnel but not sure if you have to do any "massaging" of the tunnel. Make custom engine brackets if you don't want to modify the crossmember -- many guys don't like that because it is more work.
idk on the riser but it will be getting replaced with square tubing connected to frame,floor and trans tunnel. i have a l20 from a 620 and the short trans from a 510, but the 1200 auto driveshaft may be a hard one to come by out here... seeing as ive only seen one other 1200 around here lol. I dont mind doing some custom work or fabrication i just dont want to cut the trans tunnel.
heres a few pics of the seat bracket.
floorboards.
some goodies i got today.
240 lower control arms.
fuel rail with injectors and another set of tested injestors.
240sx maf and z32maf
some sad news is the 1200 will be prob be retired for awhile because i dont want to alot of custom stuff because i dont have the cash for it. if i could find an a series around here i would put that in. so the 12 is gonna be sitting and im gonna try to fix my subies
