Dat Lurka Posted December 20, 2012 Report Share Posted December 20, 2012 Make a shift boot out of a bloody flannel shirt. Quote Link to comment
squatches Posted December 20, 2012 Author Report Share Posted December 20, 2012 That's what she said. are you outside my window again? :blink: Make a shift boot out of a bloody flannel shirt. thats a good use for all those bloody flannel shirts i have laying around! Quote Link to comment
Dat Lurka Posted December 20, 2012 Report Share Posted December 20, 2012 Oh good I was gonna ask if you needed one. I have loads. Quote Link to comment
squatches Posted December 21, 2012 Author Report Share Posted December 21, 2012 yea i seam to have an abundance of them after obtaining this bone. Quote Link to comment
squatches Posted December 27, 2012 Author Report Share Posted December 27, 2012 anyone have any problems with their a14 dieseling? Quote Link to comment
LeviGideon Posted December 27, 2012 Report Share Posted December 27, 2012 I've had a problem on my a15 dieseling. If you know your anti-dieseling solenoid isn't bad, adjust your choke, make sure it isn't sticking. Also adjust your idle mixture, make sure it's spot on. My a15 is real picky about idle mixture. All else fails, stall it out in 4th while shutting off the engine. Quote Link to comment
squatches Posted December 27, 2012 Author Report Share Posted December 27, 2012 i dont have the anti dieseling solenoid, im using an a12 carb. ill try playing with the idle mixture tomorrow, it only diesels sometimes its not constant but still annoying. Quote Link to comment
ggzilla Posted December 27, 2012 Report Share Posted December 27, 2012 Yes, by design it will diesel. Thats why 1200 carbs added the antidiesel valve. Quote Link to comment
squatches Posted December 27, 2012 Author Report Share Posted December 27, 2012 so will the idle mixture fix my prob or no? Quote Link to comment
ggzilla Posted December 27, 2012 Report Share Posted December 27, 2012 Nothing will fix the dieseling. It is a by-product of the open chamber cylinder head, which started in 1972. So for 1973 they added the anti-diesel valve. You can minimize dieseling by reducing idle speed (try 600 rpm). Quote Link to comment
squatches Posted December 27, 2012 Author Report Share Posted December 27, 2012 well poo.... haha mine idles at about 900 anywhere under that and its not to happy, and runs like ass at idle. Quote Link to comment
Dat Lurka Posted December 27, 2012 Report Share Posted December 27, 2012 Leakages Quote Link to comment
datsunfreak Posted December 27, 2012 Report Share Posted December 27, 2012 anyone have any problems with their a14 dieseling? Yes. But this... All else fails, stall it out in 4th while shutting off the engine. Most Datsun owners I know have become masters of the "clutch kill". Right foot on brake, left foot on clutch, slide it in a higher gear, and while holding firm on the brake pedal you turn the key off and release the clutch at the same time. :thumbup: 1 Quote Link to comment
squatches Posted December 27, 2012 Author Report Share Posted December 27, 2012 clutch kill it is!! haha 1 Quote Link to comment
squatches Posted December 29, 2012 Author Report Share Posted December 29, 2012 just scored a crackless dash for the 1200! guages wire harness and all. 2 Quote Link to comment
squatches Posted December 30, 2012 Author Report Share Posted December 30, 2012 heres a pic of dash, ill get some better ones after i clean it up some. i got bored and decided to do something with all my emblems. and a tattoo my friend started on my leg, this is his first tattoo on someone besides himself. its also not finshed yet, rest will be done later when he is off of work. Quote Link to comment
squatches Posted December 30, 2012 Author Report Share Posted December 30, 2012 The lines of the sun part are straight its just the way im standing in the pic. Quote Link to comment
squatches Posted January 2, 2013 Author Report Share Posted January 2, 2013 i made a piece to cover the hole where the manual choke cable went in the dash today while i was bored. Quote Link to comment
datsunfreak Posted January 2, 2013 Report Share Posted January 2, 2013 Creepy... ^_^ Quote Link to comment
ggzilla Posted January 2, 2013 Report Share Posted January 2, 2013 I have used nickels like that to plug the air pump holes on the engine. Quote Link to comment
squatches Posted January 3, 2013 Author Report Share Posted January 3, 2013 I have used nickels like that to plug the air pump holes on the engine. you carve skulls into them and then plug up holes with them? :confused: lol. heres better pic of the nickel before i put it on dash. 1 Quote Link to comment
squatches Posted January 20, 2013 Author Report Share Posted January 20, 2013 so i pulled apart the original a12 out of my 1200 and found this.. anyone ever had a valve look like that? the head and piston have no marks or scars on them. Quote Link to comment
ggzilla Posted January 20, 2013 Report Share Posted January 20, 2013 Yes, it's burnt good. Perhaps from too tight valve lash and they kept driving it. Quote Link to comment
squatches Posted January 20, 2013 Author Report Share Posted January 20, 2013 well atleast i know why it ran like poo while it was in the car. Quote Link to comment
graveltrapp Posted January 20, 2013 Report Share Posted January 20, 2013 Mystery solved, Quote Link to comment
