Matchbox Dizzy
521chowda
so in the first image the bigger connector is batterey and the little connector is coil. we also set up a ground and for some reason i have no spark. i took off the rotor for the picture....it has a new cap and rotor but im not getting anything. any suggestions or if these pictures have something funny looking in them please let me know.
  • Replies 24
Is it just me, I just don't think the module should be that close to the exhaust, mine is 180 degrees the other way, facing forward. As long as you didn't turn the engine over, the distributer should have dropped in the same position. Put the crank at TDC, check the #1 cylinder cam lobes to make sure the lobes are at 10am and 2pm, put the rotor on and see where #1 is on the cap and make sure that is where the wire goes, #1.
That's the stock Datsun electronic ignition (1st Hitachi version). It works very well.
It uses this remote ignitor box, although you can use a CDI controller or GM ignitor alternatively:
The only downside is that the box is not weatherproof, so it needs to go in the passenger cabin
I did mine the same way Wayno!!
