troyt Posted December 23, 2011 Report Share Posted December 23, 2011 Wagons look good with wood! Maybe try a little on top too... Quote Link to comment
TENDRIL Posted December 24, 2011 Author Report Share Posted December 24, 2011 that does look sweet! ill keep it in mind! Quote Link to comment
TENDRIL Posted January 6, 2012 Author Report Share Posted January 6, 2012 anybody have an idea where about a l20b should idle at? Quote Link to comment
TENDRIL Posted January 6, 2012 Author Report Share Posted January 6, 2012 it sounds good at 9ish but the whole car has a shit ton of rattle, it sounds a little high at 1k 1.1k but all the rattle stops and the car is pretty quiet Quote Link to comment
datzenmike Posted January 6, 2012 Report Share Posted January 6, 2012 Factory says 600 for a standard and an automatic in Drive. I like slightly higher, about 700. Rattle? Like engine shake? could be differences in compression between cylinders, valve clearances too tight, the idle mixture off or timing off. Check/set valve lash. Confirm timing at 10 BTDC.... then with warm engine.... Turn idle speed screw down as low to 600 as you can. Doesn't matter if you can't get there. Turn mixture screw in and out to find where the idle is smoothest and fastest. Usually there is a 2 turn range where it runs best and falls off on either side, just pick the middle. Likely the idle will improve if it was out some. Turn idle speed down close as you can to 600 and repeat the idle mixture adjustment. Keep going until you cannot improve the idle speed or quality. Done. Quote Link to comment
TENDRIL Posted January 6, 2012 Author Report Share Posted January 6, 2012 if i bring it that low it starts to cut out..would that meen my distributr or my carb is outa wack? Quote Link to comment
hang_510 Posted January 6, 2012 Report Share Posted January 6, 2012 timing chain rattle? Quote Link to comment
hang_510 Posted January 6, 2012 Report Share Posted January 6, 2012 so i found some hardwood flooring and got an idea :D and the metal along the side of the headliner will be carpeted your not supposed to huff the glue! :hmm: shag carpet! don't forget the 8-track player! :cool: i have some nice bubble windows if you ever decide to do something crazy with the cargo windows. doesn't give me a woody but reminds me of a woody, ha ha. I wood only worry about it falling on my head while I sleep. i wood be worried about it while driving. Quote Link to comment
ariascarlos1990 Posted January 6, 2012 Report Share Posted January 6, 2012 and i got this idea from carlos's goon build thread found the parts for under 40$! pretty f'in stoked so i did it up hahha :lol: Good shit. Quote Link to comment
TENDRIL Posted January 6, 2012 Author Report Share Posted January 6, 2012 timing chain rattle? i guess its a chatter most likely the valves and all of the above said by mike, im going to try and get a video up, probly wont do it justice but worth a shot Quote Link to comment
TENDRIL Posted January 6, 2012 Author Report Share Posted January 6, 2012 http://s895.photobucket.com/albums/ac158/TENDRIL_TRAY/?action=view¤t=VIDEO0021.mp4 Quote Link to comment
TENDRIL Posted January 9, 2012 Author Report Share Posted January 9, 2012 thers a little bitty stumble when shut off ... that pre ignition right? Quote Link to comment
hang_510 Posted January 10, 2012 Report Share Posted January 10, 2012 sounds like the valves need adjusting. Quote Link to comment
TENDRIL Posted January 11, 2012 Author Report Share Posted January 11, 2012 compression test today 1. 195 2.180 3.195 4. 200 ?? not to shure about the #2 piston why it would be low, or why 4 is high,, :huh: Quote Link to comment
TENDRIL Posted January 11, 2012 Author Report Share Posted January 11, 2012 oh and theres a timing mark on the 2nd to last notch on the left hand side of the crank pully, and when i turn my dizzy to get it on the metal arrow timing mark it will line up but the cars starts to stumble, should i have it on that mark than do the mixture and idle? Quote Link to comment
TENDRIL Posted February 11, 2012 Author Report Share Posted February 11, 2012 hey guys so an update! she's running, registered and insured so heres where im at with her something still isn't right..... if i punch it in 3rd and sometimes in 2nd she will back fire every once in a while and it doesn't feel like there's as much power behind her as i thought there would be....? and when its warmed up after ive driven it about 20 miles and i let it idle there is still a wispy white exhaust not cloudy but it comes out about a foot and dissipates ..? another thing is at about 65 mph on the freeway shes running about 3200 in 5th gear (dogleg tranny) is that normal it sounds kinda loud... also my temp. gauge was working when i was still getting her dialed in it would go above the C but not much higher (wasnt driving) and now it dosnt move at all... :blink: help :mellow: Quote Link to comment
TENDRIL Posted February 11, 2012 Author Report Share Posted February 11, 2012 anybody in for a bump? plz help :D Quote Link to comment
Laecaon Posted February 11, 2012 Report Share Posted February 11, 2012 Points or EI? Quote Link to comment
TENDRIL Posted February 11, 2012 Author Report Share Posted February 11, 2012 ei... i havnt done anything with the lash pads yet and i cant seem to find any thing on what they should be.. and im not sure what mark on the crank pully is 10 btdc .. Quote Link to comment
Laecaon Posted February 11, 2012 Report Share Posted February 11, 2012 well check this for timing marks: http://www.davidcmurphy.com/olddat/620tech2.htm#TM To see if your gauge still works, disconnect the temp sensor wire and ground it. Turn the ignition on and see if the gauge goes up. If it does not, then your gauge either stopped working, or you have a wiring issue. If it does work, temp sensor is having issues. Definitely need to check your timing. Quote Link to comment
TENDRIL Posted February 11, 2012 Author Report Share Posted February 11, 2012 so my pully dosnt have a 20' and is this looking at it from the front ...if you were standing in front of head lights on pass. side with a timing light :huh: Quote Link to comment
Laecaon Posted February 11, 2012 Report Share Posted February 11, 2012 I do believe so, though I havent looked at my car in awhile. You can think about when your timing light is suppose to flash, as in like 12btdc, so the light will flash as 12 degrees passes the timing mark, but since this is before TDC it has to be before the TDC mark. If that makes any sense... Quote Link to comment
TENDRIL Posted February 11, 2012 Author Report Share Posted February 11, 2012 shout out to the L motor God (hainz) help us understand Quote Link to comment
Laecaon Posted February 12, 2012 Report Share Posted February 12, 2012 Just looked at my extra crank pulley, it most definitely is. Quote Link to comment
TENDRIL Posted February 12, 2012 Author Report Share Posted February 12, 2012 so i should have the timming light hitting 10btdc Quote Link to comment
