80datson Posted July 5, 2011 Author Report Share Posted July 5, 2011 He was sayin that if you bolt in the A10 crosmember, you can bolt the KA straight to that... if you have the right oil pan! and if i cant get my hands on that xmembr? cut n weld is my only choice? Quote Link to comment
80datson Posted July 5, 2011 Author Report Share Posted July 5, 2011 He was sayin that if you bolt in the A10 crosmember, you can bolt the KA straight to that... if you have the right oil pan! he also says taht yu cant swap pans on a ka. Quote Link to comment
flatcat19 Posted July 5, 2011 Report Share Posted July 5, 2011 he also says taht yu cant swap pans on a ka. That's because you can't swap pans on a KA. Bolt holes and pickups are not the same. That's why he said you need the right motor. Quote Link to comment
80datson Posted July 5, 2011 Author Report Share Posted July 5, 2011 That's because you can't swap pans on a KA. Bolt holes and pickups are not the same. That's why he said you need the right motor. so whats wrong with cutting the engine mount towers and fab them? Quote Link to comment
flatcat19 Posted July 5, 2011 Report Share Posted July 5, 2011 so whats wrong with cutting the engine mount towers and fab them? Nothing that I see. When you first said "fab towers" I thought you meant strut towers. Fabbing the crossmember is a completely different thing. Do you have a truck KA or a 240sx KA? If it was me, I'd scour the salvage yards. And I wouldn't be using thinner metal if I had to fab an engine cradle. Quote Link to comment
80datson Posted July 6, 2011 Author Report Share Posted July 6, 2011 Nothing that I see. When you first said "fab towers" I thought you meant strut towers. Fabbing the crossmember is a completely different thing. Do you have a truck KA or a 240sx KA? If it was me, I'd scour the salvage yards. And I wouldn't be using thinner metal if I had to fab an engine cradle. yes jst a missunderstanding :P 240ka. Quote Link to comment
80datson Posted July 6, 2011 Author Report Share Posted July 6, 2011 Mabey I can use the stock a15 motor mounts bolted to quarter inch plate bolted to the block n make it adjustible Quote Link to comment
ggzilla Posted July 6, 2011 Report Share Posted July 6, 2011 Yes, you can make new engine brackets, and leave the crossmeber alone. Few guys do it that way, but it is the most elegant way. KA will fit with the stock A-series crossmember. Just need brackets for the engine mounts to put them in the correct spots. The brackets mount to the engine block. Quote Link to comment
80datson Posted July 7, 2011 Author Report Share Posted July 7, 2011 Yes, you can make new engine brackets, and leave the crossmeber alone. Few guys do it that way, but it is the most elegant way. KA will fit with the stock A-series crossmember. Just need brackets for the engine mounts to put them in the correct spots. The brackets mount to the engine block. im in the process of drawing up a mini blueprint. ill post a pic as soon as i think it may be done Quote Link to comment
80datson Posted July 7, 2011 Author Report Share Posted July 7, 2011 taking some measurments.. idea of what i have planed Quote Link to comment
ggzilla Posted July 7, 2011 Report Share Posted July 7, 2011 Datsun A-series crossmember with (non-stock) round insulators fitted Engine mount bracket located high on the block (block is upside down) Quote Link to comment
RedBanner Posted July 7, 2011 Report Share Posted July 7, 2011 those insalators look just like the poly first gen rx7 mounts 78-85 12a or 85-91 non turbo non convertable motor insolators. 1 Quote Link to comment
Pumpkn210 Posted July 7, 2011 Report Share Posted July 7, 2011 Now thats a good way to do it, I like that! 1 Quote Link to comment
80datson Posted July 7, 2011 Author Report Share Posted July 7, 2011 Datsun A-series crossmember with (non-stock) round insulators fitted Engine mount bracket located high on the block (block is upside down) that xmembr looks very similar to the 210s. thanks for the pics! their giving me good ideas Now thats a good way to do it, I like that! hopefully it works out well. now i just gota figure out where exactly i will need to drill the center hole for the mount on the bracket.. i was thinking maby i should measure from the crank pulley to the middile of the hole for the engine mount bolt on the A series. and use that lengh on the ka.. Quote Link to comment
80datson Posted July 7, 2011 Author Report Share Posted July 7, 2011 also i will be using 1/4 inch steel plate. and heat treated. would that be strong enough yu guy think? Quote Link to comment
ggzilla Posted July 7, 2011 Report Share Posted July 7, 2011 1/8" is what the factory ones are. 1/4" will work. Quote Link to comment
Mr.Dean_Yates Posted July 7, 2011 Report Share Posted July 7, 2011 my buddy put a single cam ka in his 510 and its ballsy. he needs a better trans than that sr 5 speed. but he did a subaru rear end from i think a forester? i dont remember. but its a ba car. Quote Link to comment
jaime.g Posted July 7, 2011 Report Share Posted July 7, 2011 i like this thread. i can't wait to get started on fabbing up my own mounts for my sr into b210. Quote Link to comment
80datson Posted July 8, 2011 Author Report Share Posted July 8, 2011 found something that should work. 25cents . scribing all the holes to drill and slot. Quote Link to comment
80datson Posted July 9, 2011 Author Report Share Posted July 9, 2011 got some progress done. still need to mill the slots. this is an idea of what im doing. thickness between kA series engine mount.. Aseries engine mount. it will be adjustble both ways.. Quote Link to comment
80datson Posted July 9, 2011 Author Report Share Posted July 9, 2011 Looks good! thanks!! Quote Link to comment
yoke_a_b210 Posted July 16, 2011 Report Share Posted July 16, 2011 are you swappin rear ends or what? Quote Link to comment
