DAT510 Posted August 28, 2012 Author Report Share Posted August 28, 2012 Before it wouldn't idle worth a damn... Now? its as smooth as a sewing machine. I can literally balance a quarter on the valve cover and let it idle. Quote Link to comment
I'm BLUE Posted August 28, 2012 Report Share Posted August 28, 2012 Great feeling !!! now go fix yer toilet you broke .. Quote Link to comment
DAT510 Posted August 28, 2012 Author Report Share Posted August 28, 2012 Great feeling !!! now go fix yer toilet you broke .. I'd rather not deal with shit :sick: Me no plumber. Quote Link to comment
I'm BLUE Posted August 28, 2012 Report Share Posted August 28, 2012 Takes like literally a few tools ,,, and a strong nose to fix most toilets ,,, :lol: Good job on the gasket replacement and lifter re-covery ! Keep it close to town until comfy all is a-ok ! :thumbup: Quote Link to comment
DAT510 Posted August 29, 2012 Author Report Share Posted August 29, 2012 SOOO I made it home. However.. it needs a lot of work. I can't keep her at home.. yet. 1. Clutch most definitely needs to be replaced. 2. Carb needs to be gone through or replaced. 3. replace everything ignition. On my way home, it would cough and sputter under load.. then as soon as I let off the gas it would die. BUT, this was with the choke in, i pulled the choke out and it was good enough.. I don't feel comfortable driving this around everyday quite yet.. Thinking it was timing related I stopped and advanced the timing a bit.. it was indeed way retarded. I need to rev to like 4k so the clutch can engage lolol This thing is such a hoopty.. I love it soo much though :thumbup: Quote Link to comment
DAT510 Posted August 29, 2012 Author Report Share Posted August 29, 2012 I need to go to school super early tomorrow to avoid traffic... :( Edit: She's leaking oil. Not driving her at all now. I was being hasty. Quote Link to comment
I'm BLUE Posted August 29, 2012 Report Share Posted August 29, 2012 *Confirm fuel pressure/volume *Check quick fo vacuum leaks *I'm sure you've change the fuel filter already *Check for carb fuel leaks/seeps *Check accelerator pump operation (it will give a cough ,,, putt ,,, puttt ,,,, stalll ,,,, and then the engine will catch up and go eventually ,,, unless it's completely shot lol ) *Check Fuel float level *See if main-jets are clogged/fuel bowl full of sediment. *Idle circuit check I think like you said earlier ,,, possibly just a used webber :cool: OR a spare to re-build ,,, and put back on ! If you're going to rebuild any carb = make sure throttle shaft bushings are good ! Does it have points and condensor still ? ( sorry I slow ) * Definetly check and replace points/condensor if not have for a while ( I'm sure you have ) yeah the distributors advancement .. can def be problematic over time... def check it's operation VERY thoroughly ! Hainz enjoy's running per-tronix EI conversions and more importantly believes in them :) Also = use very light torque when putting the carburetor back together. Over-tightening bolts/screws on carbs is very common ,,, and causes leaks = issues. ( I know you know most of this , but I am just going to kick the dead horse for a while lol ) Quote Link to comment
I'm BLUE Posted August 29, 2012 Report Share Posted August 29, 2012 What's wrong with the clutch ? Quote Link to comment
DAT510 Posted August 29, 2012 Author Report Share Posted August 29, 2012 Hmm.. never would of thought of the fuel pump. Float level is ok I guess, the float is in the middle about, though it has gotten stuck before. though its fine noaw (me thinks? (float level) ) If I were to buy a weber.. i'd rather swap a L series in. It's a J13 so still points. the only thing I replaced were spark plugs, cap and rotor. no EI I think. Damn it I don't like the way this J is set up.. I hate push rods with a passion. I didn't lose a ton of oil, but it's like a quite a bit more that I'm comfortable with. And you prob guessed it.. it's from the tappet cover. I really like the L so much. So let me describe what I think to be a carb problem I was at a stop sign, threw it first and went to go, ( Just so I don't confuse coughing, missing, or dieing.. i'll describe it as a normal person would lol) The rpms began to drop as if it were dieing than it would shoot up back to normal.. and the truck was shuddering. almost like the fuel cutout when you hit the speed limiter in a modern car (don't ask how I know.... :devil:) Quote Link to comment
DAT510 Posted August 29, 2012 Author Report Share Posted August 29, 2012 Another thing I would like to add is that i'm not running bone dry with oil, im just leaking some.. I make it seem like it's catastrophic.. (which for me actually it is) I just have a OCD of having everything working in perfect condition.. It's just I was hot to trot and that got in the way of my thought process lol.. almost like sporadic purchases :lol: I'm freaking out though lol.. and shaking my head in disappointment.. Quote Link to comment
I'm BLUE Posted August 29, 2012 Report Share Posted August 29, 2012 :lol: jk bro Quote Link to comment
jrock4224 Posted August 29, 2012 Report Share Posted August 29, 2012 dude we are brothers.... i got some hitachis off a 1600 i would happily donate to your cause .....i think theres two or three carbs plus a rebuild kit i think or alt least most of one...even throuhg in a weber off a 2002 bmw... Quote Link to comment
DAT510 Posted August 29, 2012 Author Report Share Posted August 29, 2012 dude we are brothers.... SWEEET. Mine is 69.. beat that. My favorite number :lol: I want to lower it a bit, add red steelies.. some white walls.. call it good.. and do the swap.. wretched J series! Rather... Wretched me!! for being stupid.. and thinking it ran good enough lol. Quote Link to comment
DAT510 Posted August 29, 2012 Author Report Share Posted August 29, 2012 And it has an annoying lifter tick.. it had it before.. but not AS noisy. Could be rocker out of spec. Quote Link to comment
I'm BLUE Posted August 29, 2012 Report Share Posted August 29, 2012 Lifter or rocker is worth checking out. It can lead to a serious issue. Quote Link to comment
DAT510 Posted September 2, 2012 Author Report Share Posted September 2, 2012 Yeah, i'll take a look after I do the oil change. Quick question, if I just put the intake and exhaust gasket on, can I take the in/ex manis off with out replacing the gasket? I need access to tappet covers. I bought cork and made gaskets lol. I replaced the head unit on the 510, I was tired of listening to the same CD over and over again. Now I have 2000 songs on the go. First I cleaned a spare cigarette thing up Then I filed for the cord had to cut off these plastic things, don't worry, it was a spare.. done Quote Link to comment
DAT510 Posted September 2, 2012 Author Report Share Posted September 2, 2012 I only drove the 521 for a day lol.. my 510 drives like a Cadillac compared to the 521 lol. the 521 will get some love very soon. Quote Link to comment
DAT510 Posted October 6, 2012 Author Report Share Posted October 6, 2012 Thought I should update.. I've been driving my 510 every day for the past month. Everything is functioning fine! there are times when im driving my 510 and it's surprises me.. like overtaking people on the highway! or the fact it actually breaks loose! There are however, some things that need attention. The suspension- Something about it doesn't feel right. I get a annoying squeak coming from the driver side strut, where the strut meets the arm (i'm guessing, cause it's only when turning.) I jacked her up and moved ever steering/suspension component as best I could to try to find the squeak.. nothing. it squeaks every once in a while.. like a rubber on rubber sound. Also, out of nowhere the alignment goes of whack and starts tracking to the right a bit. Nothing is loose, but the bushings do need replacing. The ass end also bounces a lot around turns, it's hard to describe, but I can't turn to hard because I feel as if the rear will flip over, not the front, the front is stable. The engine- compression is low on the 4th cylinder, because of rings i'm guessing. under load, at high RPM, If I blip the throttle a plume of blue smoke comes out.. I tested this at idle or at low RPMS under load and nothing happens. Also, at start up, there is a timing chain rattle.. it's getting a bit worse.. according to one of the techs at Rebellos, (Which I thank a lot for putting up with my shit haha, I couldn't stop talking about their L32 stroker) The flat driver side guide is pretty worn. Chain is also a bit worn so a new timing chain kit is in need. Gas tank - I'm tired of showing up to anywhere smelling like gas. Some girls like it.. but most don't haha. It also annoys me that I leak more gas than I actually use. For this, I was thinking of just making my own filler neck and flange out of steel, to eliminate the need for the rubber filler neck. I'm wondering if using steel is a good idea, couldn't it maybe get corroded by the fuel? I'm pretty confident in my welding abilities, But at this point I can only use a MIG machine.. so.. Other than that, the 510 is running/handling tits. The auto tranny needs to GTFO. The 510 seems to not care whether it's 110 degrees or 50.. it preforms perfect. Quote Link to comment
DAT510 Posted October 6, 2012 Author Report Share Posted October 6, 2012 Oh and I may or may not have beaten a 1.6 sentra..... :devil: It's pathetic to think that's an achievement but... the L20B isn't exactly a performance built engine.. haha. It just has a static advance of 13 degrees, and a Weber. I really like the sound of the weber sucking in air.. I can hear it through my firewall!! :w00t: :w00t: Quote Link to comment
DAT510 Posted October 20, 2012 Author Report Share Posted October 20, 2012 It's true... I got rearended. I was pulling out of the parking lot, car died because the motor was still cold, idiot behind me in a ranger floored it. Pulled over and started crying. not like a bitch but a silently stare and cry. lol. This car is my life. Why I didn't bash his head in, I don't know. I have pretty good control of myself. My friends are really sad too. They love this car haha. All the while the stupid fuck was bragging how he doesn't have a single dent on his ranger. I really don't know why I didn't smash his face. Quote Link to comment
DAT510 Posted October 20, 2012 Author Report Share Posted October 20, 2012 It's not that bad at all btw. Im definitely over reacting. It's just the one thing in my life I've actually been proud of. Quote Link to comment
I'm BLUE Posted October 20, 2012 Report Share Posted October 20, 2012 You'll get it fixed man ! I have faith :D carry forward with yer sekret plans as well .. I approve of them... whatever they may be Quote Link to comment
DAT510 Posted October 20, 2012 Author Report Share Posted October 20, 2012 Thanks, I know I can get it fixed. Might as well try to find a bluebird tail light panel :ninja: And put a fuel cell in it :angel: lol. Quote Link to comment
I'm BLUE Posted October 20, 2012 Report Share Posted October 20, 2012 Bluebird tailight panel would be pretty dang cool ! 510keeper ? :D :lol: Fuel cell ... hmmmm ... well you have had a leaky gas tank filler neck hose .. How big are 510 gas tanks ? That reminds me .. I have the baffled 17-18 gallon zx one sitting (gas lines not hooked up) in my project 240z now lol Quote Link to comment
