DAT510 Posted August 24, 2012 Author Report Share Posted August 24, 2012 I spent all day cleaning the gasket surfaces lol.. and taking the damn tappet plates off, so I could put the lifters back in place.. lol You're probably wondering why it took all day... it's cause I was doing it with a razor, and the gasket was cooked on lol. Then I had to go to school at 7, so the work day was cut short. :( Cylinder head before, after Block These pesky lil sumbitches. 1 Quote Link to comment
DAT510 Posted August 24, 2012 Author Report Share Posted August 24, 2012 By the way, that head probably weighs 30lbs.. not good being hunched over all day and pulling that bitch off... Quote Link to comment
I'm BLUE Posted August 24, 2012 Report Share Posted August 24, 2012 Looks pretty clean ! extra internets if take a vacuum to cylinder bores and head meow :sneaky: pffffffffffff 30lbs !? bisch please ,,,, 1 Quote Link to comment
DAT510 Posted August 24, 2012 Author Report Share Posted August 24, 2012 I already vacuumed!! :lol: I remember you saying that! It's an iron head.. 30lbs GIVE/take 10 lbs.. :lol: i'm gonna rub the surfaces with rubbing alcohol to get rid of grease, dirt.. etc. after going through it once more.. lol ocd sorta kicked in 1 Quote Link to comment
I'm BLUE Posted August 24, 2012 Report Share Posted August 24, 2012 :lol: ,,, I enjoy adding to your ocd list :sneaky: :lol: vacuum 10times ,,, than another 10 times ,,, then one more time before final sealing ,,, Do it the right way ^^^ or don't do it at all :lol: :lol: well in that case 20-40lbs ,,, pffffffffffffffffffff ,,, :lol: :hyper: 1 Quote Link to comment
DAT510 Posted August 24, 2012 Author Report Share Posted August 24, 2012 You fucker.. Now I need to take off the tappet (lifter) plates cause I remember seeing some gasket material in there.. FUCK. Now I need to clean the fucker out. Lol might as well rebuild it! sike. Quote Link to comment
INDY510 Posted August 24, 2012 Report Share Posted August 24, 2012 . Nice 510 ... :cool: Quote Link to comment
I'm BLUE Posted August 24, 2012 Report Share Posted August 24, 2012 :lol: but seriously ,,, I will let you point out what you forgot to do before I do :) Quote Link to comment
DAT510 Posted August 24, 2012 Author Report Share Posted August 24, 2012 . Deleting is not cheating ... I can edit this post or you can delete the gif ...... your call ... :fu: How about.... Quote Link to comment
DAT510 Posted August 24, 2012 Author Report Share Posted August 24, 2012 but wait that would be a paradox.. because if I delete that post.. then that quote would be incorrect, therefore I never gary buseyed anything... paradox.. Quote Link to comment
Laecaon Posted August 24, 2012 Report Share Posted August 24, 2012 Its a datsun motor, razorblade old gasket off, some degreaser on a rag to clean some stuff, throw the motor back together. Bam, it works. I somehow never even thought of vacuuming my engine... Quote Link to comment
DAT510 Posted August 25, 2012 Author Report Share Posted August 25, 2012 OCD was going fucking crazy, I cleaned the fuck out of the head, and cleaned the fuck out of the deck. I took a razor to it at least 10 times... then blew all the shit off with compressed air, then gave her a wipe with alcohol vacuumed some moar, and 5 more cleans with alcohol lol. I reward myself noaw celebratory fap for everybody! 1 Quote Link to comment
I'm BLUE Posted August 25, 2012 Report Share Posted August 25, 2012 :rofl: ,,, I sucessfully added my OCD to yours ! :thumbup: ( even though you would have done it in first place haha ) Seriously though ,,, good work !!! ,,, It's all about pride and attempting to do as clean of a job as you can :cool: your engine thanks you !! :thumbup: celebratory fap ,,, lol Quote Link to comment
DAT510 Posted August 25, 2012 Author Report Share Posted August 25, 2012 i'm so excited right now!! GAHHHHHHHHHHHHHHHHHHHHHHHHHH I love working on Dattos so much.. it was such a pain in the ass.. hopefully it will pay off once she turns on.. lol now I have to rebuild the carb :( or drop $342342354235236535 on a Weber.. which I don't wanna do lol. Quote Link to comment
I'm BLUE Posted August 25, 2012 Report Share Posted August 25, 2012 :thumbup: ,,, it is !!! rebuild carb = easy ( compared to what you just did/are doing :sneaky: ) or used weber :sneaky: Quote Link to comment
DAT510 Posted August 25, 2012 Author Report Share Posted August 25, 2012 Lol why didn't I order the rebuild kit. I have one off of my L16.. wonder if it would work. Quote Link to comment
I'm BLUE Posted August 25, 2012 Report Share Posted August 25, 2012 I no no you have one rebuild kit for l16 ? or carb ? Quote Link to comment
DAT510 Posted August 25, 2012 Author Report Share Posted August 25, 2012 Carb, but it's electric choke nevermind Quote Link to comment
I'm BLUE Posted August 25, 2012 Report Share Posted August 25, 2012 you can use electric-choke on it Quote Link to comment
DAT510 Posted August 25, 2012 Author Report Share Posted August 25, 2012 On a 69 521? Doesn't it require the wire for the elec choke? or can I just wire it with a switch? lol Quote Link to comment
I'm BLUE Posted August 25, 2012 Report Share Posted August 25, 2012 yup a switch works as well ,,, if needed ,,, :lol: :) or ... wire to "switched" ign source (key on = power ,,, key off = no power) think fusebox-ish ;) some people wire to (+) of coil ,,, but probably not the most approprate idea ( I have done it in the past lol ) Quote Link to comment
DAT510 Posted August 25, 2012 Author Report Share Posted August 25, 2012 Fawk it I'll just stick with the maual choke lol. run rich on command :lol: Quote Link to comment
I'm BLUE Posted August 25, 2012 Report Share Posted August 25, 2012 :lol: hahah Quote Link to comment
DAT510 Posted August 28, 2012 Author Report Share Posted August 28, 2012 THE HEADGASKET WAS SUCCESSFUL! I DIDN'T BLOW UP!! This day will be marked on my calendar!!! OMG OMG OMG OMG OMG OMG I need the gaskets for the lifter access plates(?) though :( Quote Link to comment
I'm BLUE Posted August 28, 2012 Report Share Posted August 28, 2012 Awesome :hyper: :thumbup: Quote Link to comment
