Zeusimo
How To: LED Your 620 Truck (Inside)
Nope i haven't. It doesn't take a whole lot to pull the gauzes. Just do it and count the bulbs.
I'm more concerned if I got the right bulbs that's all
Share this post
Link to post
do this and check to make sure
Share this post
Link to post
Lol I just don't want to have spare bulbs that I can't use if I get it wrong
Share this post
Link to post
are you drIrving the vehicle and unable to pull the lights to count before purchasing?
Share this post
Link to post
yes I am .. I want to be prepared
Share this post
Link to post
On 5/1/2011 at 6:13 AM, Zeusimo said:
This Is A Simple How To LED Your 620 Truck (Because You And I Both Know You Can't See Your Gauges At Night To Save Your Life) :rofl:DSC03667.jpg
^^ Simple Thing I Made That Shows Where The Bulbs Are
*Please Note*
It Is Best To REMOVE The Whole Gauge Bezel W/ Gauge Cluster To Do This
This Is On A 78 Non KC With AC, I Know There Are Variations But The Gauges Should Have The Same Lights :huh:
1 - The Tach... - A Little Tricky :hmm:
Bulbs - BA9s
http://www.superbrig...2Fba9s_1led.htm
Make Sure - You Get The 180 Degree Viewing Angle And 12V DIRECT CURRENT , Then Choose 2 Of Your Desired Colour
Installation - You Will Need To Remove Everything Off The Back To Open It And Remove The Lens Because The LEDs WILL NOT FIT
Now Put The Tach Back Together And Install LEDs
1b - Heater Controls... - A Little Tricky :hmm:
Bulbs - BA9s
Make Sure - You Get The 180 Degree Viewing Angle And 12V DIRECT CURRENT, Then Choose 2 Of Your Desired Colour
Installation - Once Again, Remove The Lens Because The LEDs WILL NOT FIT
1c - A/C Controls... - A Little Tricky :hmm:
Bulbs - BA9s
Make Sure - You Get The 180 Degree Viewing Angle And 12V DIRECT CURRENT, Then Choose 1 Of Your Desired Colour
2 - Turn Signal Lights... - As Simple As It Gets ?
Bulbs - BA9s
http://www.superbrig...2Fba9s_wide.htm
Make Sure - You Get The 90 Degree Viewing Angle And 12V DIRECT CURRENT, Then Choose 1 Green
Installation - Simply Replace The Bulbs
3 - Speedometer... - Somewhat Complicated :geek:
Bulbs - Miniature Wedge Base
http://www.superbrig...s%2F74-xHP.html
Simply Choose 2 Of Your Desired Colour
Now To Get These Bulbs To Fit You Will Need To Pinch The Contacts Together To Get The Bulbs To Fit,Use A Simple Screwdriver Like So:
Now You Might Be Thinking To Yourself... "Why The Hell Do I Need To Get These Tiny Ass Bulbs When They Have Some That Fit Right In"
If You Want To Get The Different Bulbs, Go Right Ahead.
I Did The Math And The Other Bulbs Will Illuminate About Twice As Much As Your Other Gauges.
With These All 3 Of Your Gauges Will Be The Same (In Brightness)
*Also* - These Bulbs Are Polarized, If They Do Not Turn On Simply Flip Them Around.
4 - Idiot Gauge... - Simple ?
Bulbs - Wedge Base
http://www.superbrig...s%2FWLED-x5.htm
Simply Choose 1 Of Your Desired Colour
5 - Idiot Lights... - As Simple As It Gets ?
Bulbs - Wedge Base
Make Sure - You Get The 90 Degree Viewing Angle, Then Choose 3 Red
5b - Idiot Lights... - As Simple As It Gets ?
Bulbs - Wedge Base
Make Sure - You Get The 90 Degree Viewing Angle, Then Choose 1 UV (Blacklight)
6 - Light And Wipe & Wash Illumination... - Simple ?
Bulbs - Wedge Base
This Is Hidden Somewhere Behind Your Dash
6b- Dome Light... - As Simple As It Gets ?
Bulbs - Wedge Base
7 - Floor Temp & Seat Belts... - As Simple As It Gets ?
Bulbs - BA9s
Make Sure - You Get The 90 Degree Viewing Angle And 12V DIRECT CURRENT, Then Choose 2 Red
5
I know that there are several people who have gone through the process of changing out all of their bulbs for the LED style, but I am a bit confused when I go through Zeusimo's How-To, as items 5 & 5b (Idiot Lights) describe Wedge Base bulbs, but the link provided is for BA9's.  I don't have the opportunity to remove the gauge cluster just yet to visually confirm the type of bulb, as it is my daily driver.  Can anyone who has performed this swap confirm if the bulbs are in fact Wedge Base bulbs or BA9's (I'm guessing Wedge Base due to the fact that the Idiot Gauge bulb item 4 is a Wedge Base but want to confirm)?
Additionally, the How-To says that you only need 1 green bulb for item 2 (Turn Signal Lights), but I want to confirm if you only need the 1 because it does both the left turn indicator and the right indicator, or if you actually need 2 separate bulbs (one for left and one for right)?  Along with the Turn Signal Lights, I am wondering if the Light and Wipe/Wash Illumination is similar in that you actually need 2 separate bulbs rather than the 1 bulb that the How-To indicates.
Share this post
Link to post
This is for the 521 trucks but uses same wedge base bulbs as the 620.  Hope this helps
521 LED Cluster
Share this post
Link to post
