will 13 inch wheels fit on zx struts?
  • Replies 13
Will bolt on but won't clear the caliper.I have 13" on my 710 and test fit (tried to actually) and no way it would clear. BTW these are Maxima struts which have a slightly smaller diameter rotor than the zx.
For inexpensive wheels, no, you won't be able to fit 13". With Diamond Racing Wheels or other brands that are expensive and available in a large amount of offsets, and or custom made, yes, they will fit. To answer your question, if you have money, yes. If you're poor like the majority of ratsun, no. :)
Like Hang said, my 13" x 7" libres fit, just barely.
You can't run the stick on inside wheel weights, and it helps to grind the caliper just a tad for a little extra clearance.
You have to either machine the center bore of the wheel just a little, or grind down the hub just a tad, because the taper on the hub keeps the wheel from laying flat against it. Or you can also just use an 1/4" spacer, and no mod is required.
