6speed L20?
Rustina 510
  • Replies 15
Is there a 6 speed tranny, any tranny that has 6 foward gears that will bolt onto a L20b ?
That transmission is some kind of hybrid, if you look close the whole thing is tilted badly, i am assuming your talking about the body drop thread, and it has an abnormally long tail area where the rev. and 5th gears are. wayno
A six speed would allow closer spacing of the gear ratios. (I don't mean closer together physically) For example a 280zx non turbo 5 speed ratios are
1st... 3.062
2nd.. 1.858 .... 39.3% drop in RPMs into 2nd 3,360 @6K
3rd... 1.308 .... 29.6% drop in RPMs into 3rd 4,260 @6K
4th... 1.000 .... 23.5% drop in RPMs into 4th 4,590@ 6K
5th... 0.773 .... 22.7% drop in RPMs into 5th 4,638 @ 6K
Lets imagine a six speed with the same 1st and 5th gear ratios so two cars are identical at take off and top speed.
1st... 3.062
2nd... 2.296 25% drop in RPMs into 2nd 4,500 @ 6K
3rd.... 1.722 25% drop in RPMs into 3rd 4,500 @ 6K
4th.... 1.291 25% drop in RPMs into 4th 4,500 @ 6K
5th.... 0.968 25% drop in RPMs into 5th 4,500 @ 6K
6th.... 0.773 20% drop in RPMs into 6th 4,800 @ 6K
It can be seen that 2nd gear is reached at the same 1st gear RPMs but there is less of an RPM drop with the six speed meaning that the motor is revved higher and is presumable making more hp as it starts out in 2nd. This would be very important to turbo motors to keep the turbo spooled and also a camed motor that only produces hp higher in the RPM range.
This is a totally hypothetical gear set exaggerated for effect. Some of these ratios may not be possible in practice.
I could use a 6 speed. The combination of the goofy shift dogleg and 4.11 gearing makes for a good workout of rowing. It's also why my 0-60 is slow, but my 0-80 is fast! ;) 60 for me with the rear gearing is 5300 rpm in 3rd. I like the torque factor of the low gears though. May eventually move to a truck 5 speed with L bellhousing to get a more highway friendly 5th.
The later na zx 5 speed go's good with the 411's
