Rustina 510 Posted April 27, 2011 Report Share Posted April 27, 2011 For? Taking some cars apart, getting the pedal assembly for my car, and just to hang out, I thought we talked about this before. Quote Link to comment
DISLEXICDIME Posted April 27, 2011 Author Report Share Posted April 27, 2011 Oh yah I forgot not thus week end next weekend I have Saturday Sunday and Monday off Quote Link to comment
Rustina 510 Posted May 1, 2011 Report Share Posted May 1, 2011 Saturday then? Thx dude. Quote Link to comment
Rustina 510 Posted May 1, 2011 Report Share Posted May 1, 2011 Cool, as long as izzo is not coming to my place that day to weld I will be their Quote Link to comment
DISLEXICDIME Posted May 19, 2011 Author Report Share Posted May 19, 2011 A little up date got. My flipped cross member today . Thanks nelson! Then I tore apart a l16 so I could get the a87 off it I should have ran the l16 it is all rebuilt and nice looking in side. other then the carbin build up from the su's that where on it running rich Then I busted a shock mount on this bad boy and called it a day Quote Link to comment
banzai510(hainz) Posted May 19, 2011 Report Share Posted May 19, 2011 "silver seal" had head shims. dial in datsun in the blank should come up. Quote Link to comment
DISLEXICDIME Posted May 24, 2011 Author Report Share Posted May 24, 2011 Muahahaha my l20b lives again. As much as I am sick of having a l series at least I can drive it. Looks like I will be going to canby. Quote Link to comment
slodat Posted May 24, 2011 Report Share Posted May 24, 2011 Did that head gasket set work out ok then? Quote Link to comment
Sinnful Posted May 24, 2011 Report Share Posted May 24, 2011 bad ass, you cruzin again Quote Link to comment
DISLEXICDIME Posted May 24, 2011 Author Report Share Posted May 24, 2011 Did that head gasket set work out ok then? I used the fuel pump gaskets I didn't trust the rest bad ass, you cruzin again Heck yah ! But now I have a ton of stuff to do to it. Quote Link to comment
slodat Posted May 24, 2011 Report Share Posted May 24, 2011 I used the fuel pump gaskets I didn't trust the rest Crap, were they too old? Quote Link to comment
Sinnful Posted May 24, 2011 Report Share Posted May 24, 2011 Heck yah ! But now I have a ton of stuff to do to it. hahah me too buddy, I'm driving mine tomorrow cause its supposed to be like 70 then its coming back int eh shop for the rain to get worked on again. hoping to have alot of the shit done by this weekend Quote Link to comment
DISLEXICDIME Posted May 24, 2011 Author Report Share Posted May 24, 2011 Crap, were they too old? They could still be used I just didn't like the quality hahah me too buddy, I'm driving mine tomorrow cause its supposed to be like 70 then its coming back int eh shop for the rain to get worked on again. hoping to have alot of the shit done by this weekend Hmmm maybe I should drive mine tomorrow Quote Link to comment
DISLEXICDIME Posted May 24, 2011 Author Report Share Posted May 24, 2011 Craaaaaaaaaap Drove it o work and there is oil pumping out of the valve cover breather. It pumped about a 1quart in 13 miles =( Quote Link to comment
Sinnful Posted May 24, 2011 Report Share Posted May 24, 2011 Damn dood that sucks Quote Link to comment
banzai510(hainz) Posted May 24, 2011 Report Share Posted May 24, 2011 what brands gaskets you use? I commneted on the realm swap another oil filter and ck the PCV valve Quote Link to comment
DISLEXICDIME Posted May 24, 2011 Author Report Share Posted May 24, 2011 I used fail pro . I m going to buy a pcv and oil filter . Thanks hainz wish me luck Quote Link to comment
skunk Posted May 24, 2011 Report Share Posted May 24, 2011 that fuckin sucks man, Quote Link to comment
banzai510(hainz) Posted May 24, 2011 Report Share Posted May 24, 2011 PCV most likely you can clean with carb cleaner. Just a metal slug that slides back and forth. unless you got a hole in a piston or valve soemthng is causing a over pressure. Quote Link to comment
Rustina 510 Posted May 24, 2011 Report Share Posted May 24, 2011 Dam dude. Gasket? Quote Link to comment
windowlicker Posted May 24, 2011 Report Share Posted May 24, 2011 i would do an comp. test on it.....you might have an hole on your piston. i have a friend had this same thing happen to him,and when he pulled the head off....dum dum dum....hole in piston. in his case,he ran the fuel lean and burned a hole in the piston. just a thought! good luck. Quote Link to comment
DISLEXICDIME Posted May 25, 2011 Author Report Share Posted May 25, 2011 Can't find my comp tester. Now its pumping steam out of the breather. Changed oil filter pvc I am guessing either the block is warped or cracked some where. It over heated after the oil change. I am calling it . Time of death 8:40 pm may 24th 2011. Quote Link to comment
Rustina 510 Posted May 25, 2011 Report Share Posted May 25, 2011 Yeah get that dam sr in their. Then it will become the coolest boxed dime I've ever seen... Tell mine is done ;) Quote Link to comment
philcas1987 Posted May 25, 2011 Report Share Posted May 25, 2011 Starting to think 510's are bad for you. :(. Order the parts one by one. Sr will be in there.But then what. Quote Link to comment
