sick620 Posted December 15, 2010 Report Share Posted December 15, 2010 Hey I got an offy intake and I want to polish it but I dont know how... I cleaned it good with carb cleaner and a wire brush.... Now Im ready... Do I just alternate sand paper from low grit to high grit? Than use mothers? Help please? Quote Link to comment
sick620 Posted December 15, 2010 Author Report Share Posted December 15, 2010 Would paint be cool? Quote Link to comment
INDY510 Posted December 15, 2010 Report Share Posted December 15, 2010 . Is it on the motor??? ...... is the motor in the Datsun??? Do you want to smooth out all the casting marks??? ............ .. Are you wearing saftey glasses??? Quote Link to comment
Radim Posted December 15, 2010 Report Share Posted December 15, 2010 Send it off to a polisher's would be a lot of work by hand, better yet powdercoat is getting a lot better at chrome/polished finishes... stop by your local Powdercoating shop and check it out. Quote Link to comment
sick620 Posted December 15, 2010 Author Report Share Posted December 15, 2010 . Is it on the motor??? ...... is the motor in the Datsun??? Do you want to smooth out all the casting marks??? ............ .. Are you wearing saftey glasses??? Its not on the motor.... Its not in the datsun..... and I dont want to smooth the casting marks..... :lol: Quote Link to comment
sick620 Posted December 15, 2010 Author Report Share Posted December 15, 2010 wouldnt it get too hot for powder coat.... ? Quote Link to comment
INDY510 Posted December 15, 2010 Report Share Posted December 15, 2010 . Try a small area first......... if it's already wire brushed ........ I'd start with 220 grit or corse steel wool and some mothers polish....... then use a clean cloth to polish if that doesn't look good start with a corser grit Quote Link to comment
yello620 Posted December 15, 2010 Report Share Posted December 15, 2010 If you are wanting to keep all the rough-as-cst finish them i would not put any sandpaper on it. Just start with the mothers polish. This is going to take a long time to do by hand too. Patience. And where are our PICS Quote Link to comment
INDY510 Posted December 15, 2010 Report Share Posted December 15, 2010 . Yeah,,,, the sandpaper will make you just want to smooth out all the casting ripples......... . so mother's + steel wool might be a good thing to try first Quote Link to comment
Skib Posted December 15, 2010 Report Share Posted December 15, 2010 I always like getting my stuff bead blasted and then I just clear coat it. Quote Link to comment
izzo Posted December 15, 2010 Report Share Posted December 15, 2010 micro clear coated his valve cover, looked great at first, i saw it after it started peeling :\ Quote Link to comment
Just Joel Posted December 15, 2010 Report Share Posted December 15, 2010 micro clear coated his valve cover, looked great at first, i saw it after it started peeling :\ Hi heat clear? Quality paint product? I've wondered how this would hold up. :huh: Later Joel Quote Link to comment
yello620 Posted December 15, 2010 Report Share Posted December 15, 2010 Hi-heat clear works better and seems to not peel much for me, but it starts to turn kinda yellow after a couple of years. Looks terrible. Stick to polishing, looks better. Quote Link to comment
crackerjack69 Posted August 12, 2011 Report Share Posted August 12, 2011 Too smooth surface=paint no sticky good. Im gonna get me a powder coat setup :P Por15 makes a clear-coat btw... Quote Link to comment
crackerjack69 Posted August 12, 2011 Report Share Posted August 12, 2011 "Glisten PC" @ Por15's website. Works on polished aluminum ;) Quote Link to comment
pocket rocket Posted August 12, 2011 Report Share Posted August 12, 2011 ceramic coating is the hot ticket. easy to keep clean once done too. Quote Link to comment
Shagy Posted August 12, 2011 Report Share Posted August 12, 2011 the blasted and cleard stuff looks pretty cool....maybe down the road I'll try that. for polishing...send it to me...same with powder/ceramic coatings. Quote Link to comment
datrod Posted August 12, 2011 Report Share Posted August 12, 2011 Before. After. $40.00 bucks Quote Link to comment
d510addict Posted August 13, 2011 Report Share Posted August 13, 2011 Hit it with some strong degreaser and scotch bright, or do the bead blasting that should clean it up nicely. That mani would look good just cleaned real well, it doesnt have the nasty edges and stuff that the stock L series have. Though I am interested to see how those things look after polish compound + steelwool. Quote Link to comment
NOTES... Posted August 13, 2011 Report Share Posted August 13, 2011 DatRod or Shagy, U guys do Powder coating? I have lots of pieces ive taken off the dime id like to get worked on.. PM me.. - Sorry to thread invade for a bit... Quote Link to comment
Shagy Posted August 15, 2011 Report Share Posted August 15, 2011 Hi heat clear? Quality paint product? I've wondered how this would hold up. :huh: Later Joel if you have the stuff media blasted, have a powder clear shot over it. I wish I had photos of the motor cycle frame we did. sanded the whole frame down and then shot clear powder on it. I'll have to look for them. Quote Link to comment
JasonGW Posted August 19, 2011 Report Share Posted August 19, 2011 Before. After. $40.00 bucks How? What kind of place did you take it to have this done? :) Quote Link to comment
