wayno Posted September 23, 2010 Report Share Posted September 23, 2010 Ok guys, what L blocks did the U67 head come on? wayno Quote Link to comment
skunk Posted September 23, 2010 Report Share Posted September 23, 2010 i think there were on some of the 77ish l20b in 620s, iv seen them on a few. im sure someone can tell you every year/make that they came on, but thats all i know. Quote Link to comment
hang_510 Posted September 23, 2010 Report Share Posted September 23, 2010 AFAIK, only on the L20b in the states Quote Link to comment
wayno Posted September 23, 2010 Author Report Share Posted September 23, 2010 AFAIK, only on the L20b in the states I'm an old guy hang 510, what does "AFAIK" mean. I have one(U67) on a 1980 datsun 4X4 with a L20B, and another one on a L16 from a 1970 521, I am so confused.:unsure: wayno Quote Link to comment
izzo Posted September 23, 2010 Report Share Posted September 23, 2010 I'm an old guy hang 510, what does "AFAIK" mean. I have one(U67) on a 1980 datsun 4X4 with a L20B, and another one on a L16 from a 1970 521, I am so confused.:unsure: wayno Wayno, as far as i can tell the U67 heads came on L20's, so the 70 521 has had a head swap at some point. AFAIK = As far as I know. Quote Link to comment
Sealik Posted September 23, 2010 Report Share Posted September 23, 2010 AFAIK, only on the L20b in the states Got a better pic somewhere.....but This is stamped U67 on the side of the head.....77ish+...? pickup Canada............ Quote Link to comment
wayno Posted September 23, 2010 Author Report Share Posted September 23, 2010 So what type of head did a 1970 L16 have? wayno Quote Link to comment
hang_510 Posted September 23, 2010 Report Share Posted September 23, 2010 I'm an old guy, I am so confused. :unsure: :huh: what ?!? damn, i hate gettin old :angry: :rofl: Quote Link to comment
hang_510 Posted September 23, 2010 Report Share Posted September 23, 2010 A87 open or closed chamber W58 where the hell is that head ID thread??? :angry: Quote Link to comment
wayno Posted September 23, 2010 Author Report Share Posted September 23, 2010 :unsure:I am still confused, I have a W58 peanut style head with square ex. ports, and then I also have a W58 from a 1980 720 with round ex. ports. Then there is the 210 head(L block) with the tiny intake ports. Is there any list of the apps.(what years they came on) for these heads? wayno Quote Link to comment
MicroMachinery Posted September 23, 2010 Report Share Posted September 23, 2010 A 1970 USDM L16 should have a 210 open chamber casting. Quote Link to comment
Braden Posted September 24, 2010 Report Share Posted September 24, 2010 my 77 620 came with u67 and now im running an l20 out of a 610 wagon that has a u60 head, identical other than casting numbers Quote Link to comment
wayno Posted September 24, 2010 Author Report Share Posted September 24, 2010 So the 210 casting head is the one prone to oil jacket cracks leading to oil in the water jacket. Is this correct? wayno Quote Link to comment
izzo Posted September 24, 2010 Report Share Posted September 24, 2010 Head ID http://www.olddatsuns.com/html/tech/head_ID_2.htm 1 Quote Link to comment
wayno Posted September 24, 2010 Author Report Share Posted September 24, 2010 Head ID http://www.olddatsun...h/head_ID_2.htm Thankyou very much h2theizzo, very enlightening, as it turns out I have a W58 closed chamber head with round ex. ports, is it good for anything being it is one of the rare exceptions supposedly. Thanks again. wayno Quote Link to comment
izzo Posted September 24, 2010 Report Share Posted September 24, 2010 Thankyou very much h2theizzo, very enlightening, as it turns out I have a W58 closed chamber head with round ex. ports, is it good for anything being it is one of the rare exceptions supposedly. Thanks again. wayno Are you sure yours is a closed chamber w58? I have a W58 on my 1980 720, there are open and closed chambers, i highly doubt mine is closed chamber... they are a lil more rare. Quote Link to comment
datzenmike Posted September 24, 2010 Report Share Posted September 24, 2010 Early L20Bs ('75ish) sometimes had the open A87 head but usually were square port U-67 up until '77. '78 and up were round port W-58 with liners. I did have a peanut W-58 head, so they are out there. I saved from being destroyed for the aluminum and the tag said 200sx. I've checked and the '78-'79 200sx uses the same part number, W-58 head as the 620 truck. My theory is that the head was replaced under warranty by the dealer and this was intentionally or accidentally put on it. Lots of JDM L20B were imported too. A closed chamber on an L20B gives 8.9 compression. Hardly noticeable with '79 gas. L16 always used number heads like 210, 219. L18 were likely A87s. I'm not aware that one head is prone to cracking or leaking oil into the cooling system. Quote Link to comment
wayno Posted September 24, 2010 Author Report Share Posted September 24, 2010 I do beleave that this is a closed chamber head(peanut), but it is a round exhaust port head, it came off a 1980 datsun 720KC, the cab I used to make my 720 dually. I was mistaken earlier about my work truck head, it is a W53 peanut head that I had 260 Z valves put in it and had the intake ported to match the SU intake manifold. Back to the W58, is it good for anything, that head ID site said that the head was poorly designed for flow. wayno Quote Link to comment
HRH Posted September 24, 2010 Report Share Posted September 24, 2010 There's nothing wrong with a W58 head, smog or not. Most don't like the cylinder liners and round ports, but if you remove the steel liners, you have to have MAJOR air flow to make use of the head. Race motor airflow. If you're just building a street motor, leave it in, it helps emissions, burns more deposits. If it's a closed chamber, you're already there with high compression but you can't go much larger than 2.0 liter or you may have excessive compression in which case you'll need water/methanol injection or something to curb detonation. If you have both, use the square port over the round port. The square port also shouldn't have the liners, but good flow, though not excessive flow. Quote Link to comment
hang_510 Posted September 24, 2010 Report Share Posted September 24, 2010 where the hell is that head ID thread??? :angry: Head ID http://www.olddatsuns.com/html/tech/head_ID_2.htm :thumbup: Quote Link to comment
datzenmike Posted September 24, 2010 Report Share Posted September 24, 2010 "These heads don't flow well and are avoided for high-performance applications." Exhaust is under extreme pressure, it wants OUT! Those liners aren't going to stop it. Only when the motor is really revved up is the flow going to matter. I took the ones I had out. Lot of work, I doubt you could tell the difference. Quote Link to comment
HRH Posted September 25, 2010 Report Share Posted September 25, 2010 Double post FAIL!!! :D And "wants", grammar fail sez grammar Nazi! :P Quote Link to comment
datzenmike Posted September 25, 2010 Report Share Posted September 25, 2010 Mercy! I worked outside in rain gear all day.... then bicycled home 5 miles into a 30 mph headwind with rain. Had to climb over a downed tree on the bike path. (I'd better check my other posts) Quote Link to comment
Charlie69 Posted October 5, 2010 Report Share Posted October 5, 2010 Wayno I am runningn a U67 on my L20B mainly because of the low octane gas that we buy now. I had an A87 closed chamber that I sold instead of using it. Quote Link to comment
