Skib Posted April 10, 2011 Report Share Posted April 10, 2011 jealous of who ever buys this :cool: Quote Link to comment
lynchfourtwenty Posted April 10, 2011 Report Share Posted April 10, 2011 can always adjust it by the TB.. Quote Link to comment
sycloned916 Posted April 10, 2011 Author Report Share Posted April 10, 2011 I have a extra tps,afm,iacv and i get the same. Adjusted tps to .48v, timming at 15, fuel at 44psi vac disconnected . Ecu has code 55. I think it might be the harness or that dam tuned ecu just about been though it all. Quote Link to comment
lynchfourtwenty Posted April 10, 2011 Report Share Posted April 10, 2011 ditch the iacv an adjust the idle while warm with the tb screw. it will suck when cold but once warm will be great Quote Link to comment
sycloned916 Posted April 10, 2011 Author Report Share Posted April 10, 2011 ditch the iacv an adjust the idle while warm with the tb screw. it will suck when cold but once warm will be great So dont use it at all?Iacv And set idle off the tb. Ill try that tommorow and see what it does. Quote Link to comment
lynchfourtwenty Posted April 10, 2011 Report Share Posted April 10, 2011 yea cap the iacv completely and just warm the engine by holding foot on gas pedal.. or take it for a drive.. once warm set the idle using the screw on the TB once warm it should idle nice an since you dont have emissions theres no worrys about passing.. i will admit its annoying baby sitting the throttle some times.. i've thought about hooking up a choke cable or something but been spending money on go fast stuff instead lol Quote Link to comment
sycloned916 Posted April 10, 2011 Author Report Share Posted April 10, 2011 yea cap the iacv completely and just warm the engine by holding foot on gas pedal.. or take it for a drive.. once warm set the idle using the screw on the TB once warm it should idle nice an since you dont have emissions theres no worrys about passing.. i will admit its annoying baby sitting the throttle some times.. i've thought about hooking up a choke cable or something but been spending money on go fast stuff instead lol Ok Ill try that. Thanks. Quote Link to comment
lynchfourtwenty Posted April 10, 2011 Report Share Posted April 10, 2011 no prob, hope it helps Quote Link to comment
Z chopper Posted April 10, 2011 Report Share Posted April 10, 2011 this is like my dream truck. only better Quote Link to comment
hessianben Posted April 10, 2011 Report Share Posted April 10, 2011 I'm selling the 520. $8500 FOR REAL ?Q?!! :0... hope you're just messing about :( hopefully once you get the idle dialed... Quote Link to comment
sycloned916 Posted April 10, 2011 Author Report Share Posted April 10, 2011 Unhooking the iacv was a no go ran like shit even when warm. I did here a funny noise for the turbo like a bear gralling so later Ill take it off and see. Dont see it being that, it runs fine for a min then starts to lope real bad I thought it was the hks S1 cams but it was like that with the stock cams. Quote Link to comment
lynchfourtwenty Posted April 10, 2011 Report Share Posted April 10, 2011 you gotta cap the line where the iacv hooks up to the intake pipe, then plug the intake pipe then adjust the throttle body to get it to idle where you want.. if you were closer i'd hook my laptop up an see whats really going on :( Quote Link to comment
sycloned916 Posted April 11, 2011 Author Report Share Posted April 11, 2011 you gotta cap the line where the iacv hooks up to the intake pipe, then plug the intake pipe then adjust the throttle body to get it to idle where you want.. if you were closer i'd hook my laptop up an see whats really going on :( I blocked the line on intake pipe and iacv and disconnected the iacv and nothing idle was same all over the place. Ran it back to the normal way same. Im guessing its the ecu or someone said it could be the afm wires getting interference. At idle the a/r are around 14.8-15.6 but when my idle starts to act up the a/r's go rich to 20.0-21.8 . Thanks man for the help. Quote Link to comment
lynchfourtwenty Posted April 11, 2011 Report Share Posted April 11, 2011 20.0-21.8 afr is lean as fuck dude, my car does those afr's while coasting in gear.. sounds like your problem is more along the lines of loosing fuel at idle, so i would start looking into that direction possibly.. maybe try a stock det ecu? do you have a fuel pressure gauge? Quote Link to comment
sycloned916 Posted April 12, 2011 Author Report Share Posted April 12, 2011 20.0-21.8 afr is lean as fuck dude, my car does those afr's while coasting in gear.. sounds like your problem is more along the lines of loosing fuel at idle, so i would start looking into that direction possibly.. maybe try a stock det ecu? do you have a fuel pressure gauge? Ya my fuel press is set to 44psi vac disconnected at idle. I have a 255 walbro pump, Ill check my fuel system out. Im trying to find a stock ecu now i can try. My buddy might try to check what tune is on the ecu. Quote Link to comment
lynchfourtwenty Posted April 12, 2011 Report Share Posted April 12, 2011 somethings fishy.. it should not be leaning out that far.. let me know :) Quote Link to comment
sycloned916 Posted April 12, 2011 Author Report Share Posted April 12, 2011 Will do. Check out the turbo its fine. Quote Link to comment
burrito213 Posted April 12, 2011 Report Share Posted April 12, 2011 ready to run right out of the box.....geez, this is a sweet truck!... :thumbup: Quote Link to comment
sycloned916 Posted April 14, 2011 Author Report Share Posted April 14, 2011 20.0-21.8 afr is lean as fuck dude, my car does those afr's while coasting in gear.. sounds like your problem is more along the lines of loosing fuel at idle, so i would start looking into that direction possibly.. maybe try a stock det ecu? do you have a fuel pressure gauge? Good looking on running Lean. I think I got it now, my fuel pressure gauge was reading were it should be,so I turned up the pressure and it started to run and Idle better AFR at Idle is at 15.-16.5. When I get home Im gonna take it out and see what it does and also get a new gauge and check my regulator too.Thanks. Quote Link to comment
lynchfourtwenty Posted April 14, 2011 Report Share Posted April 14, 2011 np man Quote Link to comment
bonvo Posted April 23, 2011 Report Share Posted April 23, 2011 so you keeping it or selling it Quote Link to comment
sycloned916 Posted April 25, 2011 Author Report Share Posted April 25, 2011 so you keeping it or selling it Looks like I'm gonna keep it now Thanks to (lynchfourtwenty). I went to this car show last min. on Saturday at my buddy's 300zx shop and my truck got alot of attention . So far its running good I put about 60 miles on it this weekend with no problems just alot of Looks! Quote Link to comment
hessianben Posted April 25, 2011 Report Share Posted April 25, 2011 yeah dude. after all you been through with the last truck and now all the work into this one, you gotta enjoy it for a while!! Quote Link to comment
lynchfourtwenty Posted April 25, 2011 Report Share Posted April 25, 2011 Looks like I'm gonna keep it now Thanks to (lynchfourtwenty). I went to this car show last min. on Saturday at my buddy's 300zx shop and my truck got alot of attention . So far its running good I put about 60 miles on it this weekend with no problems just alot of Looks! hahahahahhahahahaha.. lynch strikes again! dude this is one of like 3 threads im subscribed to.. i really dont come on here very often... but i keep a close eye on this thread an always checkin to see who said what ect.. it would be a shame for you to sell this truck, you have alot of hard work into it that unforunately no one cares about as much as you an well maybe a hand full of us here.. Glad to see your keeping it an that i could help :) Quote Link to comment
