sycloned916 Posted November 5, 2010 Author Report Share Posted November 5, 2010 Where is the radiator going to fit it looks very tight. It will fit like my first one,I had a 3in radiator in there with plenty of room. Quote Link to comment
fisch Posted November 5, 2010 Report Share Posted November 5, 2010 Sycloned, I know I keep telling you how much I dig this thing, but I can't help it. I think I remember tearing up when I saw what happened to the first one. You should be proud man, hell if it were mine and I built it with my own hands, I'd prolly never drive it because I'd be staring at it the whole time thinking what a bad-ass I was! Much respect! Quote Link to comment
sycloned916 Posted November 5, 2010 Author Report Share Posted November 5, 2010 whats spl? i never heard of them.. you should get a nistune! Here's the stuff on the ECU. STOCK TURBINE-S14 turbine works just great as well, STOCK INJECTOR, FUEL MAP REFINED FOR BOOST UP(0.65-1.1bar), AIR CLEANER, SPEED LIMITER AND REV LIMITER HAS BEEN CUT, F/M INTERCOOLER, EXHAUST SYSTEM, AIR CLEANER, STOCK AIR FLOW METER. QUICK RESPONSE. Later on I might run that,I want a standalone or something so I can run it with a laptop.But that will be later after I dial it all in how I want it. Quote Link to comment
sycloned916 Posted November 5, 2010 Author Report Share Posted November 5, 2010 Sycloned, I know I keep telling you how much I dig this thing, but I can't help it. I think I remember tearing up when I saw what happened to the first one. You should be proud man, hell if it were mine and I built it with my own hands, I'd prolly never drive it because I'd be staring at it the whole time thinking what a bad-ass I was! Much respect! Thanks Man! I have over 300+ pictures of both 520's,everytime I come across the Crash pic's it breaks my heart. Thats how I feel sometime with all the bad drivers out there. But if you dont drive it what's the point of building it. So it will be driven and my other buddy I'm helping build his 520 to plan on going to some meets down south and Canby when were done. Ya I'm so close to being Done with it I can't wait to drive it. Quote Link to comment
lynchfourtwenty Posted November 5, 2010 Report Share Posted November 5, 2010 Here's the stuff on the ECU. STOCK TURBINE-S14 turbine works just great as well, STOCK INJECTOR, FUEL MAP REFINED FOR BOOST UP(0.65-1.1bar), AIR CLEANER, SPEED LIMITER AND REV LIMITER HAS BEEN CUT, F/M INTERCOOLER, EXHAUST SYSTEM, AIR CLEANER, STOCK AIR FLOW METER. QUICK RESPONSE. Later on I might run that,I want a standalone or something so I can run it with a laptop.But that will be later after I dial it all in how I want it. nistunes fully tuneable(timing map an fuel maps + lots lots more), you can use a laptop to datalog everytiny little thing an the softwares compatable with most wideband units.. Quote Link to comment
sycloned916 Posted November 6, 2010 Author Report Share Posted November 6, 2010 Spent about 2hr's wire tucking and trying to hide some of the engine harness and putting the braided cover over it all so it looks clean. Found a good spot to mount the AFM in the wheel well,there's alot of room in there so next I have to cut a hole in the inner fender well and gromet it and them pipe it to the AFM and them mount it, I also have a sheild for the AFM from my other 520 for it so water and other stuff wont get in the filter. Got my hood emblem too. And there's a picture of the gauges I'm going to run Cyberdyne that one's for outside air temp,but I will have them for speedo,tach,oil press,water temp,fuel level,volts and boost. I'm gonna run a Innovation Turbo Timer/Wideband unit too in all the madness. ] Quote Link to comment
sycloned916 Posted November 9, 2010 Author Report Share Posted November 9, 2010 This morning while I was waiting to go to my shop,got the spot were the AFM is going to be piped,cut a hole through the inner fender and cleaned it up,I'll put a gromet around it once I get it all squared away. I'll run the AFM wire along the inside fender for that clean look. Picked up my Pass side IC pipe on Sunday still have to clean it up and smooth it up,then add a BOV on it. So far everything is ran how it will be,just waiting on my water temp harness and fitting's for the TB water in-outlets lines,and then it should be ready to fire-up! I'll get the radiator last once I know it runs. Quote Link to comment
nis720 Posted November 9, 2010 Report Share Posted November 9, 2010 Why is this not in the Project Datto section like your other build? BTW it's looking real good. :D Quote Link to comment
lynchfourtwenty Posted November 9, 2010 Report Share Posted November 9, 2010 soo jealous.. Quote Link to comment
sycloned916 Posted November 9, 2010 Author Report Share Posted November 9, 2010 Why is this not in the Project Datto section like your other build? BTW it's looking real good. :D Got lazy didn't think I was going to go this far with it,plus i don't want to double post. Quote Link to comment
sycloned916 Posted November 9, 2010 Author Report Share Posted November 9, 2010 soo jealous.. Haha my buddy stopped by today and spent 15-20min just looking over my engine bay on how clean everything is. That's how I want it when the hood is pop'd it's like a pearl. I spend countless Hr's going over everything seeing what I can replace or change so it will be perfect. Quote Link to comment
sycloned916 Posted November 13, 2010 Author Report Share Posted November 13, 2010 Got it started today,fired right up after I let the pump run for abit. Now I can get the rest of it finished up still need afew things in the engine bay,throttle cable,some hose clamps for all the IC and AFM piping and then the Radiator. Got one door panel mounted and put the dash in so I can start the panel for my gauges. I have a black coupler coming for the AFM so I can get rid of the red one that is on it. The Exhaust is pretty loud but thats how I want it,I still need to mount it with a hanger so it's up more. Quote Link to comment
sycloned916 Posted November 13, 2010 Author Report Share Posted November 13, 2010 See if this works. My belt was slipping when I first started it. Fixed it now and It runs Like a Champ Now! My link Quote Link to comment
lynchfourtwenty Posted December 4, 2010 Report Share Posted December 4, 2010 lets see more pics of the intercooler setup Quote Link to comment
sycloned916 Posted December 21, 2010 Author Report Share Posted December 21, 2010 Been pretty busy the past few weeks,but here's what I got done as of now. Runs had a small problem with the fuel cell foam,clogged my filter. Its now fixed and running on 105 octane now. Got fenders done today abd mt grill done in wrinkle black,still need to do piping,valve cover and compressor in wrinkle black. Brakes need to be bleed one more time. Need to run all the gauges and get my turbo timer/wideband unit. Get my doors fixed. Hood should be done next month.And then some tires. Other than that It's almost there,just been driving up and down my driveway and in front of my house when the weather is good. Quote Link to comment
Charlie69 Posted December 21, 2010 Report Share Posted December 21, 2010 Looking good. I would try a single head light 520 grill with holes in it for the cooler lines. This has to be a fun drive. Quote Link to comment
lynchfourtwenty Posted December 21, 2010 Report Share Posted December 21, 2010 need better engine shots man Quote Link to comment
hessianben Posted December 21, 2010 Report Share Posted December 21, 2010 Oh, god this thing scares me :) menacing!! incredible build going! it would make your old deceased truck proud.... Quote Link to comment
sycloned916 Posted December 21, 2010 Author Report Share Posted December 21, 2010 Here's afew of the motor. Quote Link to comment
lynchfourtwenty Posted December 21, 2010 Report Share Posted December 21, 2010 you shouuld get some S15 injectors and up the boost to like 15 psi ;) them 370s wont hold much more then 10lbs iirc Quote Link to comment
lynchfourtwenty Posted December 21, 2010 Report Share Posted December 21, 2010 how bout some pics of the down pipe? im so jealous Quote Link to comment
]2eDeYe Posted December 21, 2010 Report Share Posted December 21, 2010 Badass! :cool: Quote Link to comment
Wide14u Posted December 21, 2010 Report Share Posted December 21, 2010 all hrs of work shows this is bad ass Quote Link to comment
Bob3 Posted December 21, 2010 Report Share Posted December 21, 2010 . SWEET ! SWEET ! SWEET ! Quote Link to comment
sick620 Posted December 21, 2010 Report Share Posted December 21, 2010 good work!!! i likey! :thumbup: Quote Link to comment
