Blknight692 Posted July 9, 2010 Report Share Posted July 9, 2010 So I run out to my truck and get ready to jump in to go to work and I notice I have a puddle about the size of a diner plate under it. I push it forward and smell it, fuel, crap! I look under my rig and see that I have a small leak from a previous patch. Watch it for a bit and its dripping about 1 drip every 30-45 seconds. Not much, but a fuel leak. What are my options, it looks like it was already patched with an epoxy but has worked through the side of the patch. Do I need to drain the tank and patch it from the inside and if so, how do I do that? Anything would be awesome! Thanx in advance! Quote Link to comment
jefe de jefes Posted July 9, 2010 Report Share Posted July 9, 2010 Drain then jb weld. Quote Link to comment
Pacific coast Datsun Posted July 9, 2010 Report Share Posted July 9, 2010 Jefe is right. JB weld fast dry. Cover the previous patch entirely. Quote Link to comment
hang_510 Posted July 9, 2010 Report Share Posted July 9, 2010 temporary fix: bar soap. not effective if much bigger than a pinhole. Quote Link to comment
wildmaninid Posted July 9, 2010 Report Share Posted July 9, 2010 JB weld waterweld. COmes in a small tube with a plastic coating......gray outside, dark gray inside......cut off a chunk, rub together to mix up the 2 parts and shove her in the hole. Impervious to fuel and no need to drain the tank. Bar soap is an effective temporary solution. Just fire up the torch and braze the hole closed!! Kidding. Waterweld works awesome Bill Quote Link to comment
WAGON JON Posted July 10, 2010 Report Share Posted July 10, 2010 JB weld, for the rest of the week. Then pull it out and have it professionally fixed. Then no leak problem, or potential there of, ever again. :D Quote Link to comment
Eastcoast521 Posted July 10, 2010 Report Share Posted July 10, 2010 Mine started leaking just like yours and I used JB Weld and it worked fine but if you have one pinhole leak you have more. I bought the eastwood tank seal kit and it seems to be working fine. While I had the sending unit out I soaked it in vinegar to clean all the corrosion off of it and it works great now. Quote Link to comment
Braden Posted July 13, 2010 Report Share Posted July 13, 2010 ha h a you guys are talkign about torching fuel tanks, well my grandpa used to weld tanker trucks back in the day, one thing he made sure they did was fill the tank before he welded on it, no fumes no boom, other than that the fuel inside actually cooled down the weld. Quote Link to comment
jrock4224 Posted July 13, 2010 Report Share Posted July 13, 2010 Just a opinion but i had the same problem with my tank fixed it once worked fine, but like east coast said if theres one there is more.... i eneded up finding a new tank cause i was tired of trying to chase pinholes every week...pulling the tank isnt that bad but when you have to do it repeatedly it sux.... theres some stuff made by por 15 ...tannk sealer works pretty good...i enede up just finding a tank of a different truck... Quote Link to comment
74datsun620 Posted July 14, 2010 Report Share Posted July 14, 2010 If you weld on a gas tank the first thing is to wash out the tank with water and dawn. Then make a patch ( diamond shape if you can ) as it is easier to weld this way. Perg the tank with argon I use 3M green masking tape to plug holes and 2 pound of pressure on the regulator bubble. This is how it is done to repair aiplane gas tanks legally. If it leaks from a crack you drill a small hole 1/16" at the start and end of the crack then weld. Quote Link to comment
wayno Posted July 14, 2010 Report Share Posted July 14, 2010 So I run out to my truck and get ready to jump in to go to work and I notice I have a puddle about the size of a diner plate under it. I push it forward and smell it, fuel, crap! I look under my rig and see that I have a small leak from a previous patch. Watch it for a bit and its dripping about 1 drip every 30-45 seconds. Not much, but a fuel leak. What are my options, it looks like it was already patched with an epoxy but has worked through the side of the patch. Do I need to drain the tank and patch it from the inside and if so, how do I do that? Anything would be awesome! Thanx in advance! If it's worth doing, then do it right. You will need to pull the tank, empty it first, then pull the gauge unit out, look in the bottom, if it is full of rust you have a couple of choices, get another one(best choice) or if unable to, buy a good quality gas tank sealer, I use "bill hirsh-gas tank sealer"(800)828-2061, I had a ford ranger with dual tanks, it used a fuel system that seemed to pressurize the tank, everytime I used the tank it sprung a new leak, I was tired of welding on it, I used this sealer and no more problems, it filled holes you could see light threw. The number above is a few years old, the address is, bill hirsh auto, 396 littleton ave. newark NJ 07103 This stuff is awesome, you put it in the tank, tilt/move the tank till all areas have been covered, then pour the rest back in the can and save it for the next tank. wayne Quote Link to comment
elmerfudpucker Posted July 14, 2010 Report Share Posted July 14, 2010 Find one of the guys here that work at Boeing, you want some of the "sloshing compound" for fuel tanks. Quote Link to comment
alex843 Posted July 14, 2010 Report Share Posted July 14, 2010 I did the por-15 on my fuel tank about 2yrs ago. Has held up so far. Had some good size pin holes that i filled in with JB weld then did the whole por-15. I also only bought the cycle gas tank repair kit, just to try and save some cash. It did cover the whole tank though. You pretty much just clean the tank with their cleaners and pour the sealer in the tank, slosh it around and try to get a good cover on the inside of tank. Then pour the excess sealer back out and let it dry. It took a good weekend, just because I let the cleaners sit in the tank for a while. I had a good amount of rust in the tank it kept on clogging my fuel filter, then the tank started leaking. Now I just have to find that 'o' ring for the fuel level sender. Quote Link to comment
