TurboHLS30's '75 280z
8/2/10 I went and picked up some new rims and tires for the Z last night. They are knockoffs but they look really nice and have some almost brand new tires. They're 14x7 0 offset with a 3-4 inch lip. The best part about it is that I gave the guy $50 and a strut bar for his civic. Anyways onto the pics
Also the person who put these lowering springs on put them on backwards, as in fronts in the back and backs in the front, so it sits as if it had no motor in it. So now I have to reverse them so that it will sit right.
  • Replies 192
Yesterday I finished installing my rims. Here's some pics.
Little bro preparing to put on the rim
The front wheel well
Still preparing but now doing the one legged dance LOL
Rear wheel well
Little bro starting to put the wheel on after BSing for 5 mins.
He couldn't get it on the first time, so he started complaining about me taking pics of him failing LOL
He still couldn't get it on
He gave up so I ended up finishing it
Back on the ground
Front wheel gap because of screwed up springs
The Suburban and the Z in the driveway
You ROCK MANG! Good work, thats a bad ass setup youve got there! I especially dig the tripple blow thru turbo :cool: Sweet Azz! 2JZ is a awsome motor, but I personally would build on the drivetran thats in it now. Would be cheeper to make this one just as hot, not to mention the one of the Coolest Turbo setups I have ever seen! :thumbup:
Kudos to you, and either way that cars is the :poop:
Got my 2jz today SOOO excited for this build now
My plans are to go through the motor check the bearings and everything and the throw in my 2jz-gte rods and pistons, and turbo cams maybe. FFIM (Forward Facing Intake Manifold), Single turbo manifold with a Precision turbo don't what size, R154, ARP head studs, and a head gasket and hope for 600hp LOL
Ughhh I can't get anything done until I sell the current motor. I have people interested but they want a vid of it running and a compression test. I can't do either because my harness is fried. I know for sure the engine starts and runs because I've started it in my old Z and it ran fine. Any ideas on what I could do to get it running?
Should be fairly easy to make an engine stand that you could start it on. And you dont need much wiring to make a carb'd engine run. Thats quite a bit of money for that setup, so it stands to reason that they would want to see it run! Good luck with everything, wish I could get that setup from ya!
  • 3 weeks later...
No recent updates, this weekend the car was supposed to be running but ended up having to go and meet my Dad's girlfriends parents, so the Z didn't even get touched. But yesterday I decided to take a pic with the Z so that I can have a new screen saver so here it is
Ok we have a problem. The motor that's currently in the car has a problem with the #4 cylinder. The compression numbers in order from fron to back were #1-115 #2-115 #3-110 #4-85 :( #5-115 #6-120. So I guess god wants me to sell this and put the 2jz in the Z LOL. I might still try to fix it and get it running though. What do you guys think?
Well I can tell you with a bum cylinder people don't love to spend as much and I know you wanted to set up that 2jz with the cash so either you are going to have to lower the price of the engine, or fix it. I read your build today looks good man love the Z. I also love the monster truck stance don't let these guys mess with you, how cool is it to go off roading with your Z I mean you see a dried up river bed and you go for it!
  • 3 weeks later...
I redid the compression test with a Mac compression tester and #4 is a little better, it's now at 110 which is within the range of the others so I'll run some SeaFoam through the motor and change the oil and hopefully they will all be bumped up a little. I also bought a new battery which makes a huge difference when doing the compression check.
