hacked521 Posted March 2, 2010 Report Share Posted March 2, 2010 Build your own air/fuel ratio gauge! I wasnt sure where to put this, its both engine and electrical so ill just put it in electrical and let the other people deal with it.... build your own air to fuel ratio gauge cheaply, figured that i would put this on here. I havent tried it yet but will give it a go when i accumulate the parts. click the link! I feel that its a good article for anyone with a bit of experience with soldering and someone that doesnt feel like paying a chunk of change just to know their air/fuel ratio. :cool: Quote Link to comment
Guest DatsuNoob Posted March 2, 2010 Report Share Posted March 2, 2010 Cool. I was actually looking for this last night. Saturday, I saw almost the exact same how to on that show Trucks, but couldnt find it. Quote Link to comment
510goofy Posted March 2, 2010 Report Share Posted March 2, 2010 thats cool thank yo for that Quote Link to comment
bonvo Posted March 2, 2010 Report Share Posted March 2, 2010 i would think it would fit well into the how to section i may have to make me one of these Quote Link to comment
freekwonder Posted March 2, 2010 Report Share Posted March 2, 2010 So would this be the equivilant of a wide band or a narrow band a/f? Quote Link to comment
Duke Posted March 2, 2010 Report Share Posted March 2, 2010 So would this be the equivilant of a wide band or a narrow band a/f? This is a narrow band gauge. IMO, if one is going to be doing any carb tuning, a wideband is the only way to go. Quote Link to comment
72240z Posted March 2, 2010 Report Share Posted March 2, 2010 This is a narrow band gauge. IMO, if one is going to be doing any carb tuning, a wideband is the only way to go. IMHO if your doing ANY tuning wide band is the way to go. Narrow band is just a ball park..... A small ball park lol. I wonder though how accurate it is, the article is saying each bar is a specific A/F in a decent range. It could be helpful if it holds water. I would be interested to hear some peoples experience with it. Quote Link to comment
hang_510 Posted March 2, 2010 Report Share Posted March 2, 2010 for a few dollar in parts it would compliment the carb sych tool nicely. ive been looking at something like this... Quote Link to comment
510goofy Posted March 3, 2010 Report Share Posted March 3, 2010 Cool. I was actually looking for this last night. Saturday, I saw almost the exact same how to on that show Trucks, but couldnt find it. i know hat you are talking about i cound find nether i look all over ther web site Quote Link to comment
datzenmike Posted March 4, 2010 Report Share Posted March 4, 2010 The narrow band only shows a voltage change in an extremely narrow window of 14.7? (w/e) Before and after there is no change, or virtually no change. To register a 12 this must be using a wide band sensor. This: ...is almost worthless as it only indicates over, on or under and not by how much. If tuning you need 11-12 richness under full throttle to reduce pre ignition and give best performance.. Brian how much is this one and is it wide band? . Quote Link to comment
hang_510 Posted March 5, 2010 Report Share Posted March 5, 2010 Brian how much is this one and is it wide band? $~55, and is wideband Quote Link to comment
datzenmike Posted March 6, 2010 Report Share Posted March 6, 2010 Sorry thought I posted the pic... this one. . Quote Link to comment
Datsun fan Posted March 7, 2010 Report Share Posted March 7, 2010 Whats the difference between narrow/wide band, If I know that I can make it cheaper/practical :cool: Quote Link to comment
72240z Posted March 7, 2010 Report Share Posted March 7, 2010 Narrow band doesn't usually read beyond 1:5. You need better then that to actually tune. Quote Link to comment
72240z Posted March 7, 2010 Report Share Posted March 7, 2010 Check this page out I came across. It's a really good write up in addition to the original post. http://www.buckeyetriumphs.org/technical/Carbs/AFMonitor/AFMonitor.htm Quote Link to comment
Datsun fan Posted March 8, 2010 Report Share Posted March 8, 2010 EFI cars don't have CHOKE,carb cars do, Is there effects such as cold choked engine start will produce soot and may get stuck on O2 sensor ? O2 sensors and pretty accurate mV (2 mV sensitivity) meters are really cheap in the place I live, I'm just confused which O2 sensor do I need for A12 engine .I'm really interested in such project lol Quote Link to comment
tlap Posted March 8, 2010 Report Share Posted March 8, 2010 Oxygen sensors put out a 0-1V signal, a narrow band meter indicated from 0-1V. A single wire O2 sensor relies on the exhaust gas to heat it to over 600 deg. I installed a three wire O2 sensor, two of the wires are for the internal heater. They heat up much faster and last alot longer. It is connected to a narrow band meter, agreed that a wide band is better (much more linear), but alot more expensive. The narrow band has worked great for me so far. It showes me when the engine runs rich or lean, combine that information with how the plug look, and jet accordingly. My engine runs 100% better now, than when I was relying on only reading plugs. Just my $.02 Quote Link to comment
MAG58 Posted March 8, 2010 Report Share Posted March 8, 2010 WBO2's are much different from Narrow Band sensors. Narrow Band O2 sensors just rely on the diffusion of gasses into a measuring apparatus to gauge the amount of oxygen in the exhaust and from there a number can be estimated. Wide band sensors use an electrochemical pump to put measured amounts of gas into a chamber for measuring. This allows them to produce a much more specific oxygen concentration over a much wider interval, thus giving the ability to tune at roughly infinite intervals in the range (depending on sensor resolution). However, what makes them more useful to tuning also makes them more delicate. They are more sensitive to high EGT's and as such is why they're always mounted downstream of the turbo. If you're only trying to tune to 14.7 (Lambda=1.0) than by all means go for the Narrowband. It's cheaper and more rugged. however the majority of us want to tune closer to 11-12 AFR (Lambda=.8) as that's where more safe power is to be had (depending on setup). For those of you looking for the difference in the graphs, I found these on boostsource.com. The 02 graph is well above 1.0V which is why most computers require a WB02 controller, which takes the voltage and converts it to a 0-1V output for the computer to read, and facilitate closed loop tuning. This Wide Band graph isn't quite how it really is in real life. A true wideband currently on the market has a graph closer to that of a log function than that of a true linear function. This varies however, and is why it is essential to make sure that you calibrate your WBO2 sensor at the correct intervals. Quote Link to comment
Datsun fan Posted March 24, 2010 Report Share Posted March 24, 2010 EFI cars don't have CHOKE,carb cars do, Is there effects such as cold choked engine start will produce soot and may get stuck on O2 sensor ? Quote Link to comment
Sealik Posted November 10, 2010 Report Share Posted November 10, 2010 Sorry thought I posted the pic... this one. . That one, with the kit is 160 bucks. Plus shipping and duty (for me)......ka ching Been looking around for 1....for my Z24 EFI http://cgi.ebay.ca/AEM-Analog-Wideband-o2-Gauge-Sensor-Air-Fuel-Ratio-/290498605804?pt=Motors_Car_Truck_Parts_Accessories&hash=item43a310f2ec Quote Link to comment
Sealik Posted November 13, 2010 Report Share Posted November 13, 2010 Sooooo........if a guy (me) :) needs an air/fuel ratio gauge to get his Z24/200sx EFI set somewhat properly, would 'he' invest in a narrow or wide band? . Other than looking at the plugs and exhaust....one really has no clue on how rich or lean the engine is running. I'm sure the AFM could be tweeked a little better. Do I need the wide band to see what's happening at WOT and or? Sorry....but I'm not to A/F ratio savvy... :blink: ..yet. :D Big difference in price. Quote Link to comment
datzenmike Posted November 13, 2010 Report Share Posted November 13, 2010 Optimum air/fuel ratio is 14.7 to 1? There abouts. If just tuning for economy then a narrow band is fine as it only indicates when you are spot on for the fuel ratio. If you have the ability to adjust your fuel map (mostly for performance but specially for turbo applications) then a wide band is preferred. Heavy throttle or turbo boost requires a richer mixture to help eliminate pre-ignition. Knowing that you have an air/fuel ratio (AFR) of 12:1 at a certain rpm where it pings means you can program an increase into your system. A narrow band would only be able to tell you when you are at or very near the stoichiometric or perfect AFR of 14.7:1. As a rule the ECU ignores O2 sensor input at wide open throttle (WOT) and falls back on a pre-programed fuel enrichment curve for performance and engine protection. Quote Link to comment
Sealik Posted November 13, 2010 Report Share Posted November 13, 2010 Optimum air/fuel ratio is 14.7 to 1? There abouts. If just tuning for economy then a narrow band is fine as it only indicates when you are spot on for the fuel ratio. If you have the ability to adjust your fuel map (mostly for performance but specially for turbo applications) then a wide band is preferred. Heavy throttle or turbo boost requires a richer mixture to help eliminate pre-ignition. Knowing that you have an air/fuel ratio (AFR) of 12:1 at a certain rpm where it pings means you can program an increase into your system. A narrow band would only be able to tell you when you are at or very near the stoichiometric or perfect AFR of 14.7:1. As a rule the ECU ignores O2 sensor input at wide open throttle (WOT) and falls back on a pre-programed fuel enrichment curve for performance and engine protection. Thanks Mike.... Ya....my system is pretty primitive....no ECU 02 sensor....let alone a turbo :lol: Think I'll invest in a narrow band.....asap. I know this is a little close to the head and picking up only a 'couple' of pistons. Think it might work....?.... but not very efficient? Stick the A/F 02 sensor into the IAS location on my EM Quote Link to comment
Sealik Posted November 13, 2010 Report Share Posted November 13, 2010 Ya.....I know.....should pull the exhaust pipe and drill a hole for the 02. :) Quote Link to comment
datzenmike Posted November 13, 2010 Report Share Posted November 13, 2010 Or.... the Z24i manifold. Comes with an old O2 already installed. Feedback carb manifold should be similar. Quote Link to comment
