datzenmike Posted October 29, 2007 Report Share Posted October 29, 2007 Good idea you had on buying stuff while @ the yards. Theres always gonna be a Ratsun member who needs something + Datsun parts are getting harder to find these days. Ill be going to Ecology next Sat. for half off day, need a few 620 parts. also the 80 720's & 610's had the EI distributors among a few other models which im sure im forgetting. Ill be on the lookout for a few more for me & anybody else who needs one. The 1st gen '79 (probably the '78 too) 200sx L20B also had the EI. Also the Canadian 2nd gen ('80-'81) 200sx with the Z20E motor had the EI distributor. Before I forget... the '76 and '77 California 620 had the remote igniter box distributors too. If switching to EI use the EI coil (without the external ballast resistor). The ballast resistor is just one more thing to go wrong and should be gotten rid of. Link to comment
fisch Posted November 7, 2007 Report Share Posted November 7, 2007 Jovial, I shot you a PM about the distributor you sent. The package was damaged and the poor thing arrived broken! Bummer. Let me know how you'd like to proceed.:( I sent you some pics. Scott Link to comment
Pacific coast Datsun Posted November 7, 2007 Report Share Posted November 7, 2007 Fisch sux to hear bout your dist...:( I did score another EI dist. for my 521 @ the yard last Sat. If yours is beyond repair let us know...ill be going back to the yard here soon. Link to comment
fisch Posted November 8, 2007 Report Share Posted November 8, 2007 Fisch sux to hear bout your dist...:( I did score another EI dist. for my 521 @ the yard last Sat. If yours is beyond repair let us know...ill be going back to the yard here soon. Thanks Pac! I might have to take you up on that. What do you guys think. Would this still work? You can see where the box split too! All the way down the corner. I am not sure if it was insured or not, (Jovial?) but the delivery person made a note of the damage before it was handed to me. Link to comment
datsunfish Posted November 8, 2007 Report Share Posted November 8, 2007 Pretty sure you can live without it.I have before.If not,it is held on with a roll pin and can be replaced with one from another dist.I probably have one if you really need it. Link to comment
fisch Posted November 8, 2007 Report Share Posted November 8, 2007 Pretty sure you can live without it.I have before.If not,it is held on with a roll pin and can be replaced with one from another dist.I probably have one if you really need it. I am waiting to hear from Jovial, but if you have one handy, heck yeah I'll take it! Does a stock l16 dual point have one of these plastic sleeves? I am taking one off to put this on after all! Scott Link to comment
DeRuX Posted November 8, 2007 Report Share Posted November 8, 2007 I had this happen to my EL dizzy I just got off the forum. I used the metal one from my stock dual point dizzy. It fit perfect. Link to comment
fisch Posted November 8, 2007 Report Share Posted November 8, 2007 I had this happen to my EL dizzy I just got off the forum. I used the metal one from my stock dual point dizzy. It fit perfect. Good to hear DeRux and welcome! Link to comment
jovial_cynic Posted November 10, 2007 Author Report Share Posted November 10, 2007 Yup - sucks about the sleeve, fisch. Fortunately, it's an easy and cheap fix. I'm sending you a replacement now. Link to comment
fisch Posted November 10, 2007 Report Share Posted November 10, 2007 Yup - sucks about the sleeve, fisch. Fortunately, it's an easy and cheap fix. I'm sending you a replacement now. Rock on man! Link to comment
]2eDeYe Posted November 10, 2007 Report Share Posted November 10, 2007 I swear sometimes I think they play football with our packages...and I mean the european football :eek: Link to comment
tdaaj Posted November 11, 2007 Report Share Posted November 11, 2007 :: shrug :: I dunno. I'm not a truck guy. Thanks. i know2 this, you left a factory clock in oine of the trucks you pulled a dizzy out of. Link to comment
jovial_cynic Posted November 29, 2007 Author Report Share Posted November 29, 2007 I've got two single-prong electronic distributors available. I don't have the ignition module, but the GM module is readily available. $50, shipped. Link to comment
ggzilla Posted November 30, 2007 Report Share Posted November 30, 2007 I've got some spare black T-terminal (two connector) "Matchbox" units for sale. Make me an offer. The black boxes work excellent. They use stock or slightly wider plug gap, and can be used with a straight 12V (high energy) coil. They are from 1979-up models. Only two wires needed, and you can simply jumper your existing harness. :( One summer I bought a half-dozen distributors from various wrecking yards. They all have bad advance assemblies -- the rotating plate under the rotor assembly. They have three ball bearings in a plastic ring, and the plastic is broken. None of the advances work. Which means poor fuel economy and less smooth driveability. Link to comment
LenRobertson Posted December 1, 2007 Report Share Posted December 1, 2007 I was recently looking at Jason Gray's great dizzy page - http://web.archive.org/web/20050312092651/home.att.net/~jason510/Dizzy_FAQ.htm and noticed in the Advance Mechanism Problems section, he mentions a fix for the broken plastic advance plate. Also, in the Recurving section and the "dizzy specs" page, he explains that dizzys from different models have different advance curves, which may or may not work well on another engine. Link to comment
Dat620 77' Posted December 7, 2007 Report Share Posted December 7, 2007 whats this grab and pull everyone talk about? Link to comment
LenRobertson Posted December 8, 2007 Report Share Posted December 8, 2007 Dat620 77 - If I understand your question, you aren't familiar with U-Pull or Pull n Save (various other names) wrecking lots. They are a packrats dream come true. You go to the lot, pay a buck or two admission, take your own tools and remove your own parts. Since you are doing the work, the parts prices are really reasonable. Since you are in Pendleton, you might be able to find these type yards in Pasco or Walla Walla or Yakima. There are three in Spokane that I know about, but that is quite a drive for you. The one big yard there gets in a number of 620 and 720 trucks, but they get stripped and crushed pretty quickly. The two smaller yards tend to keep rigs in stock much longer. Link to comment
