sfsoccerstud510 Posted November 7, 2009 Report Share Posted November 7, 2009 So I just replaced my 4 speed with a 280zx 5 speed in my 510. I can't seem to get any clutch pressure. How do I adjust the slave cylinder? my clutch hose seems a lil beat up. I try to bleed it, but it won't keep any pressure. thanks Quote Link to comment
datsunaholic Posted November 7, 2009 Report Share Posted November 7, 2009 Did you use the correct throwout collar? You need the one that matches the clutch.pressure plate, not the one that matched the transmission. Quote Link to comment
sfsoccerstud510 Posted November 7, 2009 Author Report Share Posted November 7, 2009 Yea, I used the throwout that was already in my car, as well as the clutch fork. Oh ya, PS. I had a 4 speed truck tranny already in, so no mods... Quote Link to comment
koback68 Posted November 7, 2009 Report Share Posted November 7, 2009 It seems to me most often then not.the five speed pressure plate is thinner than the 4 speed pressure plate.In that case you would need to switch out the collar .Right ? Quote Link to comment
datzenmike Posted November 7, 2009 Report Share Posted November 7, 2009 The pressure plate is matched to the housing that holds the release bearing on the clutch arm. The housing comes in many lengths to compensate for the differences between the pressure plate heights. If all you changed was the transmission then the pressure plate and release bearing housing stayed the same. When swapping, the slave was off and just hanging there. The weight of the fluid in the lines may have pushed the slave piston/seal outward and fluid leaked out. I came out once to find the slave piston popped out from this when changing a tranny. Fill the master and open the bleeder screw and let the air out. Quote Link to comment
LenRobertson Posted November 7, 2009 Report Share Posted November 7, 2009 So you didn't change your actual clutch pressure plate or disk? And you switched the throwout bearing and the collar it mounts on from your 4-speed over into the new 5-speed? From my understanding of clutches and throwout bearing collars and such, that is the correct way to do it. Throwout bearing collar matches the clutch, not the tranny. But I'm in the process of doing an auto to dogleg swap, so I'll be able to test my theoretical knowledge in the real world. It seems possible you actually have a slave cylinder/bleeding problem. Did you swap your 4-speed slave over onto the 5-speed, or did the 5-speed come with it's own slave? Len Quote Link to comment
LenRobertson Posted November 7, 2009 Report Share Posted November 7, 2009 Datzenmike said what I was thinking about air in the slave. I had this happen with my SX while driving once (luckily close to home). I went ahead and put a cylinder kit in the slave, and the problem went away. I never exactly understood what happened, but it seemed air got into the slave. Maybe I could have just bled it, but I put in the kit to be sure it didn't reoccur. Len Quote Link to comment
fisch Posted November 7, 2009 Report Share Posted November 7, 2009 I had this same problem with the l16 slave in my 521. The system seemed to bleed fine, no leaks, yet I couldn't get pressure. I had to rebuild the slave, and that fixed it. I might have rebuilt the master too, but I cant remember! Quote Link to comment
DISLEXICDIME Posted November 7, 2009 Report Share Posted November 7, 2009 did you use the same slave ? Quote Link to comment
sfsoccerstud510 Posted November 8, 2009 Author Report Share Posted November 8, 2009 So I left the L20b truck clutch on along with it's throwout bearing, fork, and slave cylinder. The throwout bearing was the exact same model as the 280. -What do you mean by the collar the throwout bearing mounts to? -Could my clutch master need rebuild? I think its newish. How do I narrow this down?!?? -I need to get this car fixed so I can be a pizza delivery boy :P already got the gig. Hoping for some good tips for a cool delivery car ;) Quote Link to comment
JDM510 Posted November 8, 2009 Report Share Posted November 8, 2009 hahaha their pizza is going to smell like gas when it gets their, they will be pist no tip for you lol Quote Link to comment
MicroMachinery Posted November 8, 2009 Report Share Posted November 8, 2009 Is the Z 5 speed input shaft a different length than the 510 4-speed? I think I heard that or read that somewhere.. could be mistaken.:confused: Quote Link to comment
lynchfourtwenty Posted November 8, 2009 Report Share Posted November 8, 2009 hahaha their pizza is going to smell like gas when it gets their, they will be pist no tip for you lol hahahahahahhaah Quote Link to comment
datzenmike Posted November 8, 2009 Report Share Posted November 8, 2009 -What do you mean by the collar the throwout bearing mounts to? These things: http://i138.photobucket.com/albums/q251/datzenmike/Tranny/transreleasebearings5Large.jpg[/img]"] Pressure plates come in different thicknesses or heights. Since the master/slave/clutch arm/release bearing remains the same there has to be a way to keep them in the same range when used with a taller or shorter pressure plate. A taller pressure plate will use a shorter collar like the one on the far right. A shorter pressure plate will need a taller collar like on the left. This keeps the clutch arm to remain in the same operating range. If you have a short collar on a short height pressure plate the clutch arm will have to travel too far forward to disengage the clutch. The clutch peddle may even hit the floor before the clutch releases properly. If the collar is too long when used on a tall pressure plate the clutch arm may not be able to move back far enough to fully engage the clutch and it may slip. As long as you used the collar that was matched to the clutch on your car/truck, and only swapped the tranny then you should have no problem with this. If you used the release bearing collar that was on the new transmission it could be matched to a totally different pressure plate. http://i138.photobucket.com/albums/q251/datzenmike/Tranny/720dieseltrans002Large.jpg[/img]"] Cyber beer to the first to identify this FS5W71B tranny I have. Quote Link to comment
420n620 Posted November 8, 2009 Report Share Posted November 8, 2009 I'll take a stab at it ~~ 280z 5spd ('77-'78) Quote Link to comment
datzenmike Posted November 8, 2009 Report Share Posted November 8, 2009 Let me think...... NO! Starter is on wrong side. Quote Link to comment
420n620 Posted November 8, 2009 Report Share Posted November 8, 2009 (edited) Ok, how about a '80 200sx. I want that Cyber beer.... :lol: been searching and I might have found it ~ 82 720 Edited November 8, 2009 by 420n620 i want the beer Quote Link to comment
lynchfourtwenty Posted November 9, 2009 Report Share Posted November 9, 2009 its prolly a CA trans.. Quote Link to comment
datzenmike Posted November 9, 2009 Report Share Posted November 9, 2009 Ok, how about a '80 200sx. I want that Cyber beer.... :lol: No. Again, the starter is on the wrong side. ... been searching and I might have found it ~ 82 720 No. Again, again, the starter is on the wrong side. its prolly a CA trans.. No. Again, again, again, the starter is on the wrong side. Thirsty boys? Quote Link to comment
lynchfourtwenty Posted November 9, 2009 Report Share Posted November 9, 2009 man, i noticed that right off the bat, but i cant think of any cars that come with the starter on that side of the engine.. i even cheated an googled an still cant find anything.. but hey mike u might like this site http://www.gracieland.org/cars/techtalk/gearing2.html Quote Link to comment
lynchfourtwenty Posted November 9, 2009 Report Share Posted November 9, 2009 fwd? nah man cant be fwd... the clutch fork is all wrong... well unless it cam out of a old old sentra.... which i know nothing about.. Quote Link to comment
izzo Posted November 9, 2009 Report Share Posted November 9, 2009 (edited) 280 Z FS5W71B 5 spd "B" type 3.321 2.077/37% 1.308/37% 1/24% 0.864/14% 280 ZX (8/78-7/79) FS5W71B 5 spd "B" type 3.321 2.077/37% 1.308/37% 1/24% 0.864/14% also 810 Maxima 280 ZX (8/79-6/80) FS5W71B 5 spd "B" type 3.062 1.858/39% 1.308/30% 1/24% 0.773/23% 280 ZX (7/80-6/83) FS5W71B 5 spd "B" type 3.062 1.858/39% 1.308/30% 1/24% 0.745/26% 200 SX (7/81-9/83) FS5W71B 5 spd "B" type 3.592 2.246/37% 1.415/35% 1/30% 0.813/19% w/Z22E motor 620 Truck (74-80) FS5W71B 5 spd "B" type 3.592 2.246/37% 1.415/35% 1/30% 0.813/19% w/L16 and L20B motors 720/D20 Truck (80-86) FS5W71B 5 spd "B" type 3.592 2.057/43% 1.361/34% 1/27% 0.813/19% w/L20B, Z20, Z22, & Z24 motors Edited November 9, 2009 by h2theizzo Quote Link to comment
lynchfourtwenty Posted November 9, 2009 Report Share Posted November 9, 2009 wrong, again.. the starter mounts on the opposite side.. Quote Link to comment
izzo Posted November 9, 2009 Report Share Posted November 9, 2009 dood it came out of a right hand drive 280zx, wheres my beer? Quote Link to comment
