BRE_dAtSuN Posted March 6, 2011 Report Share Posted March 6, 2011 installed a sheet metal dash where im going to install my gauges when i get some money lol...fixed my sunroof... installed the bluebird fender reflectors...put some hood risers to clear where is was hitting and get a little more cooling Quote Link to comment
benzo Posted March 6, 2011 Report Share Posted March 6, 2011 i love it... no more pinging on 91 with 10.29:1 compression well the wrap and a couple other things Nice. Did you wrap a stock mainfold or header? i am looking to either take off my nissan comp and coat it or go back to stock manifold and coat or wrap it. I need to lower the under hood temp some. I have coated a header for a friend in past using Jet Hot and he told me it was huge help, same response like you. I don't like wrapping steel headers at times as it seems to heat up the welds and the welds break causing leaks. seems wrapping stainless headers work good though Quote Link to comment
BRE_dAtSuN Posted March 6, 2011 Report Share Posted March 6, 2011 yea i wouldnt wrap steel headers... i have an l16 stock manifold port matched.. and took advantage of from taking off both manifolds to clean up the carbs real well.. you wont regret the wrap. ;) Quote Link to comment
SpenOne Posted March 7, 2011 Report Share Posted March 7, 2011 Got a new one today! Interior is Mint! now to sell the old one... <_< 1 Quote Link to comment
Eagle_Adam Posted March 7, 2011 Report Share Posted March 7, 2011 replaced the ignition switch and cleaned a bunch of corroded connections on the dime this weekend and now she starts like a champ :thumbup:, then i snapped the acceleration cable on the 620 on the way home from where the dime is being stored :mad: Quote Link to comment
Shagy Posted March 7, 2011 Report Share Posted March 7, 2011 found all my metal emblems for my wagon. cleanned up the hatch handle and the metal vent covers/grills... Quote Link to comment
johnbureezu Posted March 8, 2011 Report Share Posted March 8, 2011 Wired up the cooling fans and broke the fan switch. oh joy. Quote Link to comment
DottiBlue Posted March 8, 2011 Report Share Posted March 8, 2011 Got rid of the battery tray and welded up the holes from the spot welds. Fabed up some mounts for the KA throttle cable. Got setup to start bending the new fuel lines. Quote Link to comment
erikcarter Posted March 10, 2011 Report Share Posted March 10, 2011 Got all new tie rods and ball joints! Quote Link to comment
BRE_dAtSuN Posted March 10, 2011 Report Share Posted March 10, 2011 Got all new tie rods and ball joints! hey i did the same thing but when i rebuilt the motor.. but i didnt get the ball joints i really want to... i got the center link the pitman arm and the idler arm tho Quote Link to comment
SubwayGUY4 Posted March 10, 2011 Report Share Posted March 10, 2011 Got bored and fixed about everything I could think of. Been sitting for a year. Not no more! Quote Link to comment
inline4 Posted March 10, 2011 Report Share Posted March 10, 2011 ahahah.... streetwize, no compromise. I used to go there all the time in high school. Quote Link to comment
gotpancit Posted March 11, 2011 Report Share Posted March 11, 2011 Put shifter bushings in. wooohhhoooo now the transmission doesnt feel like I'm driving a tractor ! Quote Link to comment
BRE_dAtSuN Posted March 11, 2011 Report Share Posted March 11, 2011 installed an autometer oil pressure gauge.. did my oil change.. new fuel filter... painted my faded bumpers installed a small tach just for now Quote Link to comment
CoilOVerKid Posted March 14, 2011 Report Share Posted March 14, 2011 hey i did the same thing but when i rebuilt the motor.. but i didnt get the ball joints i really want to... i got the center link the pitman arm and the idler arm tho where did you find your steering components??? Staying on topic, I showed my dad my pulled apart dash. I popped my hood and just shook my head. Quote Link to comment
BRE_dAtSuN Posted March 14, 2011 Report Share Posted March 14, 2011 i used to work at kragen and the carry moog now so i orded everything there... moog is good because its all greasable Quote Link to comment
Shagy Posted March 15, 2011 Report Share Posted March 15, 2011 well this weekend I will be out sanding rust off the car...if anyone wants to help...I'll be in Montebello...bring a sander. Quote Link to comment
Lovely_Crucial71 Posted March 16, 2011 Report Share Posted March 16, 2011 Today i replaced my fuel lines from the cargo area of my goon. They were in pretty good shape but i trust it a lot more now that they are new Quote Link to comment
benzo Posted March 16, 2011 Report Share Posted March 16, 2011 wife's honda broke down for good today so the wagon has to step up and I have to drive her to work so did a bit of a one over on it. changed the oil,filter went over any bolts or nuts cleaned underside and engine bay made sure the jets on the carbs were not loose made some adjustments to the mikuni's found a loose header bolt and tightened it up popped on some new wiper blades since it has been raining here checked tire pressure Quote Link to comment
Shagy Posted March 21, 2011 Report Share Posted March 21, 2011 I worked on filling the seams on the bumpers and filling the license plate holes.. learning on a spare set. Quote Link to comment
freaky510 Posted March 21, 2011 Report Share Posted March 21, 2011 where did you find your steering components??? i got mine here still havent insatlled it yet lolz http://www.moog-suspension-parts.com/proddetail.asp?prod=Moog%5FPackageDeal005 here is more lolz http://www.moog-suspension-parts.com/products.asp?cat=1402 Quote Link to comment
VintageRice Posted March 24, 2011 Report Share Posted March 24, 2011 Assembled, welded, and installed my front coilovers/280zx struts. Took 4hrs total. Few hick-ups but they are on and low. Sweet. Quote Link to comment
izzo Posted March 24, 2011 Report Share Posted March 24, 2011 Ordered new parts for the engine. its getting a rebuild... Quote Link to comment
Jennifer Posted March 25, 2011 Report Share Posted March 25, 2011 i halfway installed my rear window latches..then i lost one of the springs.:unsure: Quote Link to comment
Sinnful Posted March 25, 2011 Report Share Posted March 25, 2011 decided to keep one of them....... Quote Link to comment
