510er Posted January 7, 2009 Report Share Posted January 7, 2009 This has been on CL for about a month or so now and im torn about buying it. Its advertised as a '73 the owner thinks its a 78, but the Vin comes back as a 77. I went and looked at it for a ratsun member that decided that he didnt want it. Now Im just torn if i should buy it for myself. It runs great has recently had the engine gone through clean interior (cracked dash :fu:) minor body damage (gives it character) The current owner bought it from an auction and has an Abandoned Vehicle Receipt thats been notarized and all that good stuff. So according to the DOL here all i would need is to take that, a bill of sale, and a release of interest form the current owner and i would have a clean title in 6 weeks. What should I do? do 620's have decent resale value if i buy it drive it/clean it up then sell it this summer...?? Quote Link to comment
Llittle_Llama Posted January 7, 2009 Report Share Posted January 7, 2009 price? Is that the one you looked at for cheq? Quote Link to comment
Cuts metal like mad Posted January 7, 2009 Report Share Posted January 7, 2009 it is worth what someone is willing to pay... Which is usually less than $1000. It's Defiately later than 75 (last year of the pillar vents)... Can't be a 78 unless it has disc front brakes. Quote Link to comment
Llittle_Llama Posted January 7, 2009 Report Share Posted January 7, 2009 antenna is on pass side looks like.... Quote Link to comment
510er Posted January 7, 2009 Author Report Share Posted January 7, 2009 The Vin comes back as a 77 and the price is $400... Quote Link to comment
datzenmike Posted January 7, 2009 Report Share Posted January 7, 2009 What should I do? do 620's have decent resale value if i buy it drive it/clean it up then sell it this summer...?? Shame on you, buying it to turn a buck??? Keep it and enjoy it. The bad... Non-stock crappy aftermarket fuel pump. Hole in front m/c reservoir. Don't see the EGR so might have some 'red-neck tech' block off plate w/o PCV valve. Valve cover vent not properly attached to air filter... fumes in cab. Don't see fuel pressure reg for the Weber. Maybe the crappy pump is low pressure. Definitely '75 or newer. Looks like a U-67 head so not '78 or '79. Check the driver's door tag for the build date. Look at the block to be sure an L18 not slipped in. Quote Link to comment
510er Posted January 7, 2009 Author Report Share Posted January 7, 2009 I checked the block and it is a L20b with a U67 Im not really trying to turn a buck but i would like to buy it enjoy it and fix the minor things and sell it for what im into it later Quote Link to comment
lynchfourtwenty Posted January 7, 2009 Report Share Posted January 7, 2009 Shame on you, buying it to turn a buck??? Keep it and enjoy it. The bad... Non-stock crappy aftermarket fuel pump. Hole in front m/c reservoir. Don't see the EGR so might have some 'red-neck tech' block off plate w/o PCV valve. Valve cover vent not properly attached to air filter... fumes in cab. Don't see fuel pressure reg for the Weber. Maybe the crappy pump is low pressure. Definitely '75 or newer. Looks like a U-67 head so not '78 or '79. Check the driver's door tag for the build date. Look at the block to be sure an L18 not slipped in. whats that about an after market fuel pump .. it looks like mine.. so is mine crappy after market??? oh an weber FPR?? WTF?? Quote Link to comment
datzenmike Posted January 7, 2009 Report Share Posted January 7, 2009 Webers 'prefer' fuel pressure below 3 PSI. The stock pump is rated at 3-3.9 PSI and can easily overpower the float and flood at low speed and idle. Perhaps crappy is too harsh a word. I haven't heard anything good about them. If yours works well consider yourself blessed. :D Quote Link to comment
lynchfourtwenty Posted January 8, 2009 Report Share Posted January 8, 2009 mines never had a problem, only been drivin it a few years tho, god knows how old it is... not the first one i've seen, rarely see the space ship ones any more.. also i run no FPR, never had a problem, infact this is the first time i've heard about using a fpr with a weber, my friends 77 had a stock electric pump an he never had issues either... my step dad runs a yoda an has problems with his some times.. i will ask him if he ever fixed the problem, if not i will suggest a fpr.. his 22r has a manual pump also i think? Quote Link to comment
athoose Posted January 8, 2009 Report Share Posted January 8, 2009 That two tone paint job looks pretty cool. What is the silver band material above the black on the rockers? The dog dishes and black rims set it off. Do you have better pics? Quote Link to comment
510er Posted January 8, 2009 Author Report Share Posted January 8, 2009 i think its white paint, no better pics yet when i looked at it the first time it had about 2 feet of snow on and around it. Ill post more pics today when i bring it home im going to pick it up Quote Link to comment
datsunaholic Posted January 8, 2009 Report Share Posted January 8, 2009 You don't really need a fuel pressure regulator if the fuel return line is hooked up... it's a bypass that works really well (the stock mechanical L20B pump, which is higher GPM than a L16/L18 stock pump, could overpower the float valve in the stock Hitachi). All '75 and later Datsuns had the return stock. In the pic, the fuel return is still hooked up. I'd be more inclined to wonder what kind of Weber that is... it doesn't look like a DGV. Might be a Holley 5200. Quote Link to comment
datzenmike Posted January 8, 2009 Report Share Posted January 8, 2009 The return also keeps fresh cool fuel circulating past the carb and this lowers the risk of vapor lock. I like the idea that your gas is constantly being filtered. Quote Link to comment
Madmax Posted January 8, 2009 Report Share Posted January 8, 2009 my 2 cents...if you can resell it tomorrow for the same amount you spent today then its OK to buy....although you did say its been on craigslist for a month or so...and the boys are trying to help you on the little things and they seem to know there stuff.... Quote Link to comment
510er Posted January 8, 2009 Author Report Share Posted January 8, 2009 I think its been on craigslist for so long because the dude listed it and there is 3 feet of snow on the ground, who wants a 2wd in those conditions.... THIS GUY! Quote Link to comment
izzo Posted January 8, 2009 Report Share Posted January 8, 2009 how much lol i want a 620 :( This has been on CL for about a month or so now and im torn about buying it. Its advertised as a '73 the owner thinks its a 78, but the Vin comes back as a 77. I went and looked at it for a ratsun member that decided that he didnt want it. Now Im just torn if i should buy it for myself. It runs great has recently had the engine gone through clean interior (cracked dash :fu:) minor body damage (gives it character)The current owner bought it from an auction and has an Abandoned Vehicle Receipt thats been notarized and all that good stuff. So according to the DOL here all i would need is to take that, a bill of sale, and a release of interest form the current owner and i would have a clean title in 6 weeks. What should I do? do 620's have decent resale value if i buy it drive it/clean it up then sell it this summer...?? Quote Link to comment
510er Posted January 8, 2009 Author Report Share Posted January 8, 2009 okay im going to get it right now! Quote Link to comment
LAYEDOUTB2K Posted January 8, 2009 Report Share Posted January 8, 2009 okay im going to get it right now! sweet, i really liked how the paint scheme is on it when the cl ad was posted on here. Quote Link to comment
DISLEXICDIME Posted January 9, 2009 Report Share Posted January 9, 2009 if you buy a 620 it will make you appreciate the way your 510 handles and brakes. but ask your self this do you need 2 datsun's to work on? Quote Link to comment
510er Posted January 9, 2009 Author Report Share Posted January 9, 2009 okay got like halfway there and the guy called me... can we make it 445? so im home again waiting anxiously to leave... Do i need 2 datsuns to work on? No but im driving this one home, and as far as appreciates how my 510 handles and drives... its in a little of 6 billion pieces so the 620 is going to handle like a dream in comparison. Im just going to drive this until it wont drive no more! Quote Link to comment
lynchfourtwenty Posted January 9, 2009 Report Share Posted January 9, 2009 i love 510s i really do.. wish i owned one.. but i'd never trade my truck for one.. not saying its better.. but its my first ride.. its my baby.. an no one would pay me what i want for it in a million years.. an i dont think i could part with it really.. Quote Link to comment
510er Posted January 9, 2009 Author Report Share Posted January 9, 2009 okay i got it! I would have paid the 400 bucks for it a when i looked at it the first time, the floor mats were frozen to the floor. I lifted the drivers side and was greated with the most redneck hilarious floor pan that i have seen in a long time. there was obviously some rot in the floor at one point and the remedy was to drop in a large piece of sheet metal to cover it up.... well the areas that the sheetmetal was to far from the floor to weld the gap they wedged wrenches in between and welded the patch to the wrench and the wrench to the truck.... to ensure a proper seal between the old floor they never removed and the new patch they used newspaper to keep it from rattling... Also i think it had a roof rack on it at one point because the roof needs some TLC So i gave the guy 300 for it and drove it home. it back fires twice from first to third upon hard acceleration, it is a 5 speed, the brakes are SUPER touchy. the dash bezel that goes around the heater controls is broken and half missing. It does have excellent studded snow tires on the front...(WTF) and newer allseasons on the back. seat is flawless both door panels are perfect, someone recently redid the headliner with a kind of tweed brown stuff looks good. Once home i swapped the studs to the rear and check out brake pads and drums, all look rusty and amazing! I cleaned it all out and found lots of bank statements... I wired in a headunit and some speakers to play the mixed cd i found under the floor mat. working on tuning the carb and going to check the timing tomorrow. Future plans, Paint the wheels red, do a rising sun hood, drive the ell out of it. Pictures of all to follow this afternoon Quote Link to comment
Bleach Posted January 9, 2009 Report Share Posted January 9, 2009 It almost looks like the engine compartment pic shows part of an hour meter. The hour meter came only in 1976 trucks. Quote Link to comment
Bandit240 Posted January 9, 2009 Report Share Posted January 9, 2009 ^WTF was up with the hour meter anyway? My 76 had one, but it didnt work. Quote Link to comment
