frankendat Posted March 22 Report Share Posted March 22 There is an Inter button on the dash of a 4wd 1990 D21. Is this a stock locking diff? Quote Link to comment
frankendat Posted March 22 Author Report Share Posted March 22 Dammit. I found out it is not a locking diff, it is for starting the engine without depressing the clutch. Why would I want to start the engine without depressing the clutch? Quote Link to comment
petercscherer Posted March 22 Report Share Posted March 22 I've never even conceived of such a procedure. That's a first for me too. Quote Link to comment
fiveoneO Posted March 23 Report Share Posted March 23 Supposedly you can get more torque to the wheels by starting the truck in gear. Its so if you're out wheeling and get stuck, the extra torque can hopefully get you unstuck. 3 Quote Link to comment
datzenmike Posted March 23 Report Share Posted March 23 It would be turning the wheels with the starter basically. Less chance to over power and spin them. My '70 Dart had a clutch interlock. I got rid of it. Figured it was for pussies and if ever you stalled and could not restart you could still move the car out of an intersection or RR tracks with the starter. 2 Quote Link to comment
frankendat Posted March 23 Author Report Share Posted March 23 57 minutes ago, datzenmike said: It would be turning the wheels with the starter basically. Less chance to over power and spin them. My '70 Dart had a clutch interlock. I got rid of it. Figured it was for pussies and if ever you stalled and could not restart you could still move the car out of an intersection or RR tracks with the starter. Seems like a product designed and installed by companies who hold stock in remanufactured, rebulit, and replacement Nissan D21 starters Quote Link to comment
datzenmike Posted March 23 Report Share Posted March 23 Well you aren't using it every day, hardly at all really. Quote Link to comment
Stoffregen Motorsports Posted March 23 Report Share Posted March 23 Rock crawling. Slow cranking, yes, but sometimes pushing the clutch pedal introduces a dangerous situation. If you're pointing uphill and the motor dies, then you push the clutch in to start, A - you've just unsettled the balance of the vehicle, which could cause problems, and B - you now have to slip the clutch like mad to get rolling, which is also dangerous and hard on equipment, and C- to get started on a steep hill with the clutch, you need three feet to work all the pedals. My Rover has a separate starter button so I can crank the motor without starting it. 1 Quote Link to comment
bananahamuck Posted March 26 Report Share Posted March 26 try pushing it to make in flight announcements. Quote Link to comment
Icehouse Posted March 26 Report Share Posted March 26 I use the interlock switch so I don't have to get in to start my truck when I warm it up. Quote Link to comment
