rosso Posted February 14 Report Share Posted February 14 These may be a bit more expensive, but I just ordered a set for my VG33 swapped 510 wagon. https://jdm-car-parts.com/en-gb/products/kameari-performance-drive-shaft-bolt-set-for-skyline-hakosuka-kenmeri-laurel-fairlady-z-datsun-240z-260z-280z-280zx-510-810?variant=32232220426349 1 Quote Link to comment
Stoffregen Motorsports Posted February 14 Report Share Posted February 14 Here's that pic I promised. Quote Link to comment
iceman510 Posted February 14 Report Share Posted February 14 Those are 8 x 1.25? Underhead length? Quote Link to comment
Stoffregen Motorsports Posted February 14 Report Share Posted February 14 Yes, 8x1.25. Didn't get a length, but I can. I am now thinking they were used on the giant CVs, not the driveshaft, but they work for driveshafts because I've used them there. Quote Link to comment
datsunfreak Posted February 15 Author Report Share Posted February 15 18 hours ago, Stoffregen Motorsports said: Yes, 8x1.25. Didn't get a length, but I can. I am now thinking they were used on the giant CVs, not the driveshaft, but they work for driveshafts because I've used them there. With that flange, I would think they wouldn't work on most Datsun stuff? Or did you file one side flat? 1 Quote Link to comment
iceman510 Posted February 15 Report Share Posted February 15 18 hours ago, Stoffregen Motorsports said: Yes, 8x1.25. Didn't get a length, but I can. I am now thinking they were used on the giant CVs, not the driveshaft, but they work for driveshafts because I've used them there. OK, probably right. I tried checking that bolt yesterday in the NIssan system and spec book, and could not match up those characteristics and part number with what Mike listed. I will check that CV bolt. I can see they would work as they appear to be shoulder bolts, other than the comment above on the flange size as there is limited space around the u-jt flange.. 1 Quote Link to comment
Stoffregen Motorsports Posted February 15 Report Share Posted February 15 Yeah, I don't recall. Sorry guys. Quote Link to comment
Stoffregen Motorsports Posted February 15 Report Share Posted February 15 I searched "Nissan 720 front CV joint bolt" and found this - https://www.z1motorsports.com/rear-differential/nissan/oem-rear-differential-output-shaft-bolt-p-11423.html https://www.z1motorsports.com/driveshafts-and-hardware/nissan/oem-350z-370z-g35-g37-driveshaft-bolt-p-12521.html Looks similar. Quote Link to comment
datzenmike Posted February 15 Report Share Posted February 15 I don't see a flat side. If I had a Nissan part number for the bolt that only has a flat on it I can find all the vehicles it was used on. Then you could order it new or go hunting the yards'. I'm sure I used them on my 620? Something. Quote Link to comment
datsunfreak Posted February 15 Author Report Share Posted February 15 1 hour ago, datzenmike said: I don't see a flat side. If I had a Nissan part number for the bolt that only has a flat on it I can find all the vehicles it was used on. Then you could order it new or go hunting the yards'. I promise you, regardless of what the part number is, Nissan is asking at least 5 times as much money as Subaru. 😄 Quote Link to comment
datzenmike Posted February 15 Report Share Posted February 15 But if it's used on 720 and D21/Xterra/Frontier 4x4 differentials then they are basically free in the wrecking yards. Quote Link to comment
datsunfreak Posted February 16 Author Report Share Posted February 16 16 hours ago, datzenmike said: But if it's used on 720 and D21/Xterra/Frontier 4x4 differentials then they are basically free in the wrecking yards. I was just thinking of more readily available sources. Personally, I have not seen one of those in the junkyard in 10+ years. YMMV And these days, $1.18 each is damn near free. 😄 2 Quote Link to comment
datzenmike Posted February 16 Report Share Posted February 16 IF. Just an example. Often enough a part can be found on other vehicles. $1.18??? I thought someone quoted over $30 for.... something. 2 Quote Link to comment
Stoffregen Motorsports Posted February 16 Report Share Posted February 16 I agree. Who has time to hit up wrecking yards anyway. Quote Link to comment
datsunfreak Posted February 16 Author Report Share Posted February 16 5 hours ago, datzenmike said: IF. Just an example. Often enough a part can be found on other vehicles. $1.18??? I thought someone quoted over $30 for.... something. The Nissan OEM bolts are over $30-40 a set, new from the dealer (or other online source). The Subaru bolts are $1.18 each, new from the dealer. 👍 4 hours ago, Stoffregen Motorsports said: I agree. Who has time to hit up wrecking yards anyway. Then there's this. If I had known how cheap they were new from Subaru, I would not have bothered with getting these used from the junkyard. 😋 1 Quote Link to comment
Stinky Posted March 17 Report Share Posted March 17 (edited) ON my 720, I ruined the nuts. I got nuts from TrueValue. They have a 13mm head on them and are much easier to use. I also bought bolts at the HW store. The have a 13mm head on them and also fit just fine. The bolt's shaft, is the same size. Edited March 17 by Stinky Quote Link to comment
