Dats_Mandersun_408 Posted August 2, 2023 Report Posted August 2, 2023 anyone know where I can get a front brake banjo bolt? I have a 1972 521 pickup, thanks! Quote
Crashtd420 Posted August 2, 2023 Report Posted August 2, 2023 2 hours ago, Dats_Mandersun_408 said: anyone know where I can get a front brake banjo bolt? I have a 1972 521 pickup, thanks! Usually they come with that tee that comes with the wheel cylinder.. Probably have to find them used.... I can look through my old parts and see if I still have them... 1 Quote
datzenmike Posted August 2, 2023 Report Posted August 2, 2023 The 620 used similar bolt. Not the same part number but can't see why they would change it. Quote
Crashtd420 Posted August 2, 2023 Report Posted August 2, 2023 43 minutes ago, datzenmike said: The 620 used similar bolt. Not the same part number but can't see why they would change it. The diameter and threads are wrong.... Sae vs metric.... But you can use the entire assembly if buying new.... Quote
Stoffregen Motorsports Posted August 2, 2023 Report Posted August 2, 2023 If you know the size, you can buy new ones. Probably 3.8-24, but that's just a guess - https://www.summitracing.com/search/part-type/brake-fittings?SortBy=BestKeywordMatch&SortOrder=Ascending&keyword=banjo+bolt https://www.summitracing.com/search/part-type/brake-fittings/fitting-size-1/3-8-in-24?SortBy=BestKeywordMatch&SortOrder=Ascending&keyword=banjo+bolt Quote
Crashtd420 Posted August 2, 2023 Report Posted August 2, 2023 26 minutes ago, Stoffregen Motorsports said: If you know the size, you can buy new ones. Probably 3.8-24, but that's just a guess - https://www.summitracing.com/search/part-type/brake-fittings?SortBy=BestKeywordMatch&SortOrder=Ascending&keyword=banjo+bolt https://www.summitracing.com/search/part-type/brake-fittings/fitting-size-1/3-8-in-24?SortBy=BestKeywordMatch&SortOrder=Ascending&keyword=banjo+bolt Nope not gonna work.... I forgot they had the bleeder threaded into the banjo.... Looks like this.... And dats_mandersun I'm not gonna have it mine were junk... Converted to disk instead.... 1 Quote
Crashtd420 Posted August 2, 2023 Report Posted August 2, 2023 Banjos with bleeder do exist but I'd be concerned with length and the location of the cross hole.... Might be best to buy new wheel cylinders with the fittings..... That other picture came from parts available on ebay... just checked rockauto and the don't give you the tee or the bolt... make sure its listed on what ever you get.... You can also use the ones for the early 620, but you'll have to cut the end off the brake line and put a metric fitting on... 2 Quote
Stoffregen Motorsports Posted August 2, 2023 Report Posted August 2, 2023 Forgot about the bleeder... Quote
wayno Posted August 2, 2023 Report Posted August 2, 2023 9 hours ago, datzenmike said: The 620 used similar bolt. Not the same part number but can't see why they would change it. The 620 had metric threads, the 521 had SAE threads, but you can use the early front 620 brake wheel cylinder on the 521 as long as you use the 521 fitting that the brake line connects to, it does not care if the banjo bolt has metric threads or a bleeder there also. I have a few of them banjo bolts, but I do not know if they are SAE or Metric anymore, I do not have anything to compare them too as I have disc brakes on all my 520/521 trucks now. 1 Quote
banzai510(hainz) Posted August 2, 2023 Report Posted August 2, 2023 (edited) i ordered some cylinders on ebay that came with the banjos. some have them, most dont washers i think also. Edited August 2, 2023 by banzai510(hainz) 1 Quote
Dats_Mandersun_408 Posted August 2, 2023 Author Report Posted August 2, 2023 8 hours ago, Crashtd420 said: Banjos with bleeder do exist but I'd be concerned with length and the location of the cross hole.... Might be best to buy new wheel cylinders with the fittings..... That other picture came from parts available on ebay... just checked rockauto and the don't give you the tee or the bolt... make sure its listed on what ever you get.... You can also use the ones for the early 620, but you'll have to cut the end off the brake line and put a metric fitting on... thank you so much for the info! yea this is a tough bolt to find Quote
Dats_Mandersun_408 Posted August 2, 2023 Author Report Posted August 2, 2023 10 hours ago, Crashtd420 said: Usually they come with that tee that comes with the wheel cylinder.. Probably have to find them used.... I can look through my old parts and see if I still have them... that would be awesome thanks! Quote
mklotz70 Posted August 3, 2023 Report Posted August 3, 2023 (edited) https://www.ebay.com/itm/254494751046?fits=Model%3A521+Pickup|Make%3ADatsun&epid=77110320&hash=item3b4111b946:g:e9QAAOSwGC9eLwfx&amdata=enc%3AAQAIAAAA8FmNi4eS%2Fqdrg3YXyBfV6d%2FxU1fymP5GqeXDWWYj3KziEvNLRNY7ujIueyPaGoYPqCp0%2BVA1cMWDloPrMYZghmq4kJs3TTS3PbVl2Y49zst42rS2g513xSR9bzSkC%2FfkMGRFuFTjWc3Sp9P23opzFq7zv22UjqI69tHM5fUctn%2B8oKzF2IZSLCJ%2Bgba9ZniqPdhlPa7urBT4GK%2F4SGcGo%2BegPaUu1yivgD2TvdEu3AmRbeV5hL2sUKCa6oF93Cbuvs9Qk2WoQCi%2FcTSN%2BBUaTNhA%2BqS9pyo1ZIvIe2QVpX6dHL53P6mCpuVRrycHkUh0vA%3D%3D|tkp%3ABk9SR8yn_6C3Yg Edited August 3, 2023 by mklotz70 2 Quote
Dats_Mandersun_408 Posted August 3, 2023 Author Report Posted August 3, 2023 17 hours ago, mklotz70 said: https://www.ebay.com/itm/254494751046?fits=Model%3A521+Pickup|Make%3ADatsun&epid=77110320&hash=item3b4111b946:g:e9QAAOSwGC9eLwfx&amdata=enc%3AAQAIAAAA8FmNi4eS%2Fqdrg3YXyBfV6d%2FxU1fymP5GqeXDWWYj3KziEvNLRNY7ujIueyPaGoYPqCp0%2BVA1cMWDloPrMYZghmq4kJs3TTS3PbVl2Y49zst42rS2g513xSR9bzSkC%2FfkMGRFuFTjWc3Sp9P23opzFq7zv22UjqI69tHM5fUctn%2B8oKzF2IZSLCJ%2Bgba9ZniqPdhlPa7urBT4GK%2F4SGcGo%2BegPaUu1yivgD2TvdEu3AmRbeV5hL2sUKCa6oF93Cbuvs9Qk2WoQCi%2FcTSN%2BBUaTNhA%2BqS9pyo1ZIvIe2QVpX6dHL53P6mCpuVRrycHkUh0vA%3D%3D|tkp%3ABk9SR8yn_6C3Yg thank you I ordered it!!! 2 Quote
