Kingcab Posted August 26, 2020 Report Share Posted August 26, 2020 Hey so I'm doing the 4.3 swap in my 720 got a list of parts to do it i was wondering if the chevey 4 link rear end would fit if I cut and welded on the brakets to the datsun 1 Quote Link to comment
Charlie69 Posted August 26, 2020 Report Share Posted August 26, 2020 Measure it. Not sure if anyone has done this one before. Quote Link to comment
datzenmike Posted August 26, 2020 Report Share Posted August 26, 2020 It'll be too wide and besides the H-190 is good to 300 ft lbs torque. More than enough for a chevy. Quote Link to comment
Lockleaf Posted August 26, 2020 Report Share Posted August 26, 2020 You want 4 link without scratch building, look at a wd21 pathfinder. Axle is only 2 inches wider than 720. Course the gears suck so there's that to deal with. Quote Link to comment
Kingcab Posted August 26, 2020 Author Report Share Posted August 26, 2020 Wasn't aware the h-190 could handle that torq I think I may just stick with it i have plenty of spare parts for them anyway. Thanks for the info guys. If anyone has ever done or tried the swap though please do tell your storry 1 Quote Link to comment
Stoffregen Motorsports Posted August 27, 2020 Report Share Posted August 27, 2020 Will it work? Yep, anything can be built. It all depends on the end use. Is it going to be a 4x4? Quote Link to comment
bottomwatcher Posted August 27, 2020 Report Share Posted August 27, 2020 The pathfinder is a stronger unit, disc brakes and optional limited slip. Quote Link to comment
datzenmike Posted August 27, 2020 Report Share Posted August 27, 2020 On 8/26/2020 at 12:45 PM, Lockleaf said: You want 4 link without scratch building, look at a wd21 pathfinder. Axle is only 2 inches wider than 720. Course the gears suck so there's that to deal with. It's an H-233 which is larger than a Ford 9". The Pathfinder does come with LSD but only in 4.375 and 4.625 4 pinion differentials. Quote Link to comment
Kingcab Posted August 29, 2020 Author Report Share Posted August 29, 2020 No it will not be 4x4 its really low with hardbody lowering spindles and breaks and steering rack going to mod my steering knuckles for more angle for sliding and i bobed I think 21 inches off the bed. Just thought I could use the rear end im taking the 4.3 motor from but If the h190 can handle it im all game to keep it i got a spare one and lots of spare axels for it also. Any suggestions on maybe what rear shocks I should use?? 1 Quote Link to comment
bottomwatcher Posted August 29, 2020 Report Share Posted August 29, 2020 Got the engine in yet? If not I wouldn't worry about the shocks yet. Your in for a lot of work with that swap. If it's in post some pics 1 Quote Link to comment
Kingcab Posted August 29, 2020 Author Report Share Posted August 29, 2020 Not in yet just waiting on parts and money to buy parts 1 Quote Link to comment
Stoffregen Motorsports Posted August 29, 2020 Report Share Posted August 29, 2020 If you want to keep it 6 lug, go with a Toyota 8" rear axle. They came out of 79-95 pickups. The 79-85 axles are 55.3 inches wide, the 86-95 axles are 58.5 inches wide. Later Tacomas also had the 8 inch diff, but only in the TRD trucks with electric locker. The non TRD trucks had an 8.4 inch diff that is harder to build (it has shims instead of adjusters. First gen Tacoma rear axles are 60" wide. Any of these Toyota axles can handle the power of the 4.3L and there are a ton of available gear ratios, brake kits, lockers, limited slips, etc. Waaaaaay cheaper than going with a Datsun/ Nissan axle. 2 Quote Link to comment
