SLOWPOKE - 1971 1400DX Bluebird 4dr (510)
The floors are amazing!  The jute pad still looks factory fresh.
large.04042020_slowpoke_(44).JPG.9858603
large.04042020_slowpoke_(45).JPG.a9173ac
Is the front as nice as the rear?
large.04042020_slowpoke_(46).JPG.3f0f397
except for some compression from the driver's heel, yep!
large.04042020_slowpoke_(47).JPG.570d5b4
Blinker stalk with flash-to-pass!
large.04042020_slowpoke_(48).JPG.1d35517
Passenger's side
large.04042020_slowpoke_(49).JPG.ef98984
The plastic is going to go asap!
large.04042020_slowpoke_(50).JPG.c96bf2f
Hardly even a seat-belt ding on the sill cover
large.04042020_slowpoke_(51).JPG.54f1138
This side had some water.  Nothing terrible though.
large.04042020_slowpoke_(52).JPG.d61a09b
Requisite "flare"
large.04042020_slowpoke_(53).JPG.eee4914
Glovebox - note light switch - typical on these cars.
large.04042020_slowpoke_(54).JPG.009e231
large.04042020_slowpoke_(55).JPG.f68d0e7
Has anyone lifted this mat in the last 49 years?
large.04042020_slowpoke_(56).JPG.dd5fa3f
More protected goodness
large.04042020_slowpoke_(57).JPG.71bb7b2
large.04042020_slowpoke_(58).JPG.c698de8
large.04042020_slowpoke_(59).JPG.ffae956
Better shot of the headliner
large.04042020_slowpoke_(60).JPG.ff71d5c
Edited by carterb
  • Replies 161
To the engine room then...
large.04042020_slowpoke_(61).JPG.16fd814
large.04042020_slowpoke_(62).JPG.a60fb52
Nothing looks show car but everything appears complete and OEM
large.04042020_slowpoke_(63).JPG.75397ae
large.04042020_slowpoke_(64).JPG.3349c1d
large.04042020_slowpoke_(65).JPG.1feec5b
210 head
large.04042020_slowpoke_(66).JPG.f60d2f7
L14 block
large.04042020_slowpoke_(67).JPG.88ed1aa
Rated at 85 PS (84 hp)?  Not too shabby!
large.04042020_slowpoke_(68).JPG.e74b5d3
large.04042020_slowpoke_(69).JPG.7f6853a
More stocky stuff
large.04042020_slowpoke_(70).JPG.35cf1dc
large.04042020_slowpoke_(71).JPG.09471fd
Everything in here just looks amazing!
large.04042020_slowpoke_(72).JPG.2bc0833
except the deformed inner fender behind the left headlight
large.04042020_slowpoke_(73).JPG.f961ab9
Anyone want to translate?
large.04042020_slowpoke_(74).JPG.ca915cf
Service intervals?  Note the paint code showing through - 937.  I can't find any information on this in the US.  : (
large.04042020_slowpoke_(75).JPG.e314750
Looking good then...  Let's hope it's no chore to get you up and running.
large.04042020_slowpoke_(76).JPG.d7060d7
even super clean under the hood
large.04042020_slowpoke_(77).JPG.8a95f1e
Patina
large.04042020_slowpoke_(78).JPG.8e2a9ed
Edited by carterb
On 8/22/2020 at 10:15 PM, slowlearner said:
Very noice! Does it run?
Why thank you very much for asking!
Indeed once I gave it a battery full of juice and cranked it over a few times, it fired up and ran like a sewing machine!  Smooth and quiet.  Nice!
But - as mentioned in Japan, something was wrong with the clutch and I couldn't select a gear.  I was pretty sure the clutch was just frozen to the flywheel (I've experienced that before) but just to be certain, I wanted to make sure the hydraulics and such were working correctly.  Tough to do with a one man army, but armed with an iphone - nothing is impossible right?
I set the phone on the ground looking up at the slave cylinder then sat down, gave it a few pumps, and grabbed the camera to see what I could see.
http://datsun510.com/uploads/monthly_2020_05/IMG_9734_04042020_slowpoke_clutch.MOV.cf2c76c9be825397826578bf1ff8bb17.MOV
It works!
Awesome!  That just means we need to break the clutch free.
This part is not for the faint of heart.  You have to put the car in gear, clutch pedal down, foot on brake, and rotate the key to engage the starter.   This really loads up the starter but it's only for a moment before you turn it off and try again.
On previous cars, one or two engagements was all it took.  On this one, I tried 3 or 4 times and it was still stuck.  Then I alternated between 1st and reverse 3 or 4 more times and finally *POP*! the flywheel and clutch were decoupled and I was sitting in place, in gear, clutch depressed, motor running.  I could then select neutral and de-clutch, then depress the clutch again and select a gear.   Progress!
Only thing left to do now was go for a little drive.  (remember leaking brakes meant that it would be a slow short one)
http://datsun510.com/uploads/monthly_2020_05/IMG_9735_04042020_slowpoke.MOV.2720234be4150c81943062e986d2432a.MOV
Success!  Not only did it make it up the hill but I was able to start, stop, shift, steer.  What else do you need?!
A couple days later - everything still works.  : )
http://datsun510.com/uploads/monthly_2020_05/IMG_9732_04062020_slowpoke.MOV.9092769bd9ba2f75e6b668ec9abe09ab.MOV
http://datsun510.com/uploads/monthly_2020_05/IMG_9733_04092020_slowpoke.MOV.e347a4b29d650075d6c34d9e95df9411.MOV
Getting serious now...
Edited by carterb
About this time Adam had the title application complete and ready to send in so I could get a license plate.
I heard about some nice little JDM to US license plate adapters on ebay.
large.04102020_slowpoke.JPG.8d1be74d1e45
Kind of spendy for what it is I suppose but it beat drilling extra holes in the car and/or license plate.
A few days later a package showed up with the adapters along with a T-shirt and some cool stickers!
large.04152020_slowpoke.JPG.13149cf598bb
Now I know why it was $19.  : )  Thanks LHI!
I will very likely buy more in the future for my other Bluebirds.
After determining that the brake cylinder on the front struts was different than the brake cylinder on the rear, I made the easy decision to just swap to front disks right away and not fool with fixing the leaking front drum brakes.
I got the car up on jack stands and took a bunch of pictures of the wheel wells and suspension.  Everything is in such awesome shape!  Do I have the undercoating to thank for that?  Certainly didn't hurt.  I'm sure the car was just garaged and rarely driven.  That's the only way these things survive like this in Japan.
large.04152020_slowpoke_(1).JPG.1cffe111
large.04152020_slowpoke_(2).JPG.5d6d6f0a
large.04152020_slowpoke_(3).JPG.dcb8bebb
large.04152020_slowpoke_(4).JPG.e3bb347d
large.04152020_slowpoke_(5).JPG.5f0b7fd4
large.04152020_slowpoke_(7).JPG.2261699d
large.04152020_slowpoke_(8).JPG.be0c8ba8
I swapped over to some wheels and tires that actually held air in preparation for actually driving this thing soon.
For some reason, after jacking it up, it did NOT want to come back down!  Look how far up in the air the nose is now!  Jumping up and down on the front did not return it to earth.  Weirdy!
large.04152020_slowpoke_(9).JPG.ec3cd5e9
I'm getting a little ahead of myself.  Before making the decision to swap to front disks, I grabbed the old drum brake struts that came off of Granny in the hopes of a quick route to driveability.
Cooper looked on with interest.  "How's the weather up there?"
large.04212020_slowpoke.JPG.f601cd6d1d84
Look at the fender height!
Let's get to work then...
large.04242020_slowpoke_(2).JPG.ffc11ca4
Swappy swappy parts
large.04242020_slowpoke_(3).JPG.493c690f
Strut goes there
large.04242020_slowpoke_(4).JPG.4c7f2c65
Slowpoke strut at left, Granny strut at right
large.04242020_slowpoke_(5).JPG.525f12d0
Even higher?!  What the heck?!?!?!?!
large.966757763_04242020slowpoke(6).JPG.
I must be building a Stomper here!
(You guys remember those? - I was in heaven when you could get one in your Happy Meal)
While it's up in the air and easy to work on, I figured I should get a fender on there to make the car at least a little more presentable.
large.04252020_slowpoke_(1).JPG.50a83dfe
That'll do for now.
large.04252020_slowpoke_(2).JPG.af0e4602
The fender is a little munched in the front - it matches the rest of the car perfectly!  : )
large.04252020_slowpoke_(3).JPG.319bca82
large.04252020_slowpoke_(4).JPG.31d50e39
Between the elevated ride height and front drum brake issues, this set up just wasn't going to work...  The weekend had just started and I figured the obvious way forward was going to be swapping the suspension and brakes from Granny to Slowpoke.  She wasn't using them.  : )
Granny hadn't see the light of day for a while.
large.05082020_slowpoke_(1).JPG.60cb1d8d
Still makes me a little sad...
large.05082020_slowpoke_(2).JPG.d74bcf91
large.05082020_slowpoke_(3).JPG.0a26dcd8
For those who are still learning - Slowpoke (on right) is a '71, Granny (on left) is a '72.  Note the difference in the tail lights.
large.05082020_slowpoke_(4).JPG.238ac21a
They have different grills too.  The '71 has the grill with the center bump out.  This is often referred to as the "SSS Grill".  My understanding is that name came about during a time period where when you ordered a "510 grill" from a US Nissan dealer - the grill you got was the '71 bluebird grill with a SSS badge attached.
The '72 has the steel mesh grill with the plastic top and headlight surrounds.  That grill is often called the "plastic grill" or often the "coupe grill" which is funny because it never came on a coupe from nissan (they didn't make coupe's in '72) but again, my understanding, when coupes were ultra rare in the US, one of the more well known coupes had a '72 bluebird grill and everyone just assumed that was another detail unique to the coupes.  Now of course most people call them "supersonic grills" thanks to Love20Bee making reproduction versions available to the masses.  Apparently that provided the seed money to start their custom wheel business.  Smart!  Their custom wheels are gorgeous!!!!
large.05082020_slowpoke_(5).JPG.3e1f9079
large.05082020_slowpoke_(6).JPG.9ffaec68
Granny still has quite a bit of "junk in the trunk"
large.05082020_slowpoke_(7).JPG.414275bb
Most of that needed to come out to gain access to the rear coil overs.
No such trouble with Slowpoke.  Trunk is clean and ready to go.
large.05082020_slowpoke_(8).JPG.e27afa8f
Everything in this car is in such incredible condition!
large.05082020_slowpoke_(9).JPG.f242a05c
large.05082020_slowpoke_(10).JPG.ee61c95
Commence swapping!
large.05082020_slowpoke_(11).JPG.e91846f
Granny never got the chance to wear these out - they are still like new.  Maybe 2-3k miles?
large.05082020_slowpoke_(12).JPG.bbdfe54
Of course, Slowpoke's suspension was still pretty crisp as well (less than 67,000 km)
large.05082020_slowpoke_(13).JPG.22a9f31
Funny how lowering a car is an upgrade...  Should it be a downgrade?
large.05082020_slowpoke_(14).JPG.554b7da
OEM shocks
large.05082020_slowpoke_(17).JPG.1d9e05f
Granny back on the ground
large.05082020_slowpoke_(19).JPG.cdbb1c8
And Slowpoke with the "new" rear suspension
large.05082020_slowpoke_(20).JPG.540e42d
large.05082020_slowpoke_(21).JPG.1873eb7
Much betterer...
The sun came up the next morning and so did the front of these two Bluebirds.
large.05092020_slowpoke_(1).JPG.ecb2cd58
ready for launch!
large.05092020_slowpoke_(2).JPG.0fede6e9
large.05092020_slowpoke_(4).JPG.dd0cf043
Drum vs Disk...  They aren't pretty (well, pretty rusty) but they should get the job done...
large.05092020_slowpoke_(5).JPG.5e160cb2
large.05092020_slowpoke_(6).JPG.cf946659
Pulled off the Suspension Techniques bar too - not sure if I'll mount it just yet...
large.05092020_slowpoke_(7).JPG.15f7ee28
Mounted
large.05092020_slowpoke_(8).JPG.d9b2be8e
Oh yeah - Experimental Engineering T/C Kit.  DEFINITELY have to swap that over!
large.05092020_slowpoke_(9).JPG.0a7a6105
Now we're talking!
large.05092020_slowpoke_(10).JPG.ec94c4f
large.05092020_slowpoke_(11).JPG.fda593c
Okay Granny - back to storage with you.  So sorry....
large.05092020_slowpoke.JPG.b2c3b6ef0302
One good thing though, while I had the car out in the open - I had a friend come and look it over to get a bid on repairing the crash damage and possibly even painting the car.  Hopefully we will be able to make something happen there...
HOW TALL ARE THOSE STRUTS?!?!?!?!
Into the garage then for a brake bleeding session followed by an alignment check.
In case you are unaware - changing the ride height of your car changes the wheel alignment.
Lowering a 510 changes the toe quite a bit - about 3/4" over the length of these alignment plates.
large.06022020_slowpoke_alignment_(1).JP
After some work with the tie-rods - we are now about 1/16" toe-in.
large.06022020_slowpoke_alignment_(2).JP
Let's see, what else...  Oh yeah, the license plates came in the mail so time to mount the adapters and get this thing road legal!
large.06042020_slowpoke_plate_adapters.J
What the heck was going on behind the license plate in Japan?  Did they try to remove the old plate with a claw foot hammer?  Weird...
First drive day is almost here!!!!
Edited by carterb
The next day, Friday the 5th of June, 2020, I drove Slowpoke to work for the first time!  Some seven months after purchasing from Japan.
large.06052020_slowpoke_to_work_(1).JPG.
After work, I decided I'd take a couple of pictures next to one of our buildings, seemed to offer a cool industrial backdrop...
large.06052020_slowpoke_to_work_(2).JPG.
While the car was sitting there idling, it died.  Seriously?  I could not get it to re-start.  Not even a sputter.
Although the fuel gauge said it had about 1/3 of a tank, there was an orange mark on it placed there by the PO.  I knew I was close to it but not that close.  My perspective from the drivers seat must be different than the other guys.  Anyway - it was out of gas.
See it there framed by the steering wheel?
large.06052020_slowpoke_to_work_(3).JPG.
Finding no suitable cans at work to walk to the gas station with, I called Jeff.  He had all our gas cans left over from the race at Pacific Raceways since it ended early with a crash.  In went 4-5 gallons of fresh gas and after some cranking to fill the carb's float bowl, it started right back up.
Next stop then?  The gas station.
large.06052020_slowpoke_to_work_(4).JPG.
I've never put so much gas in a 510 before!  Bone dry it was!!!
Crisis averted (or so I thought)
Sunday morning I woke up and hurried back and forth to the mail box to fetch the newspaper.  It was raining.  I noticed some color on my driveway but that's nothing too unusual.
After catching church online, I went back outside for something else and noticed rainbow footprints on my porch from when I got the paper earlier.  Well that's a little odd...  Then I looked at the driveway again and saw a rainbow road that Mario Kart fans would be jealous of.
large.06072020_slowpoke_(1).JPG.4fdd0cf9
Further investigation led me to Slowpoke.  I opened the door and found that the front footwell had probably a quarter gallon of gas sitting in it.
large.06072020_slowpoke_(2).JPG.63976ec5
The rear was worse so I started pulling things out of the car to locate the problem.
large.06072020_slowpoke_(3).JPG.f036637a
I assumed it was probably the fitting(s) at the bottom of the fuel tank as something similar to this had happened to the cactus green FJ 2dr I bought a couple years ago.  (to the previous owner)
In the process of pinpointing the problem, I brushed the rubber cap on one of the two fuel tank fittings and it fell off and started puking out fuel.  I quickly put my finger over it but I was now in a bit of a pickle.  I had nothing to pug it with so I started yelling for help.  Corey heard me and was able to hand me the tools and items I needed to get a handle on the situation.  I put a hose over the fitting to try and drain the remainder of fuel into a can.
large.06072020_slowpoke_(4).JPG.eba1c8ca
I recovered less than 2 gallons.  That means at least 8 or 9 gallons of gas passed through my car and onto my driveway overnight.
I abstain from using harsh language but I'll admit a few choice words passed through my mind when holding the culprit that caused this disaster.
large.06072020_slowpoke_(5).JPG.e176b2c9
Let the clean up begin
large.06072020_slowpoke_(6).JPG.c4fc4cd6
Next I stripped everything out of the car.  This is all I got in return for my trouble.
large.06072020_slowpoke_(7).JPG.4aac4d00
Maybe that missing lens led to the crash that put this bluebird on the market.  ?
The fuel soak turned the stock Nissan sound deadening into goo.  Sticky, nasty, squishy, awful, goo.  I tried to scrape up as much as I could without making an even bigger mess than I started with.
large.06072020_slowpoke_(8).JPG.445aaef6
I could hardly believe what I was in the middle of at this point.  Just a few photos earlier I was in awe of the condition of this car after 49 years of existence, and now a part of that has been completely erased by a tank of gas and a failed rubber plug.
PSA, if your tank still has one of those plugs, drain the tank and remove it NOW!
I kind of wonder - if your car is in continuous use, maybe it's not bad.  It might be the drying out from sitting with an empty tank that kills them.
The car was not the only victim here.  Look what it did to my driveway?!  As I was working on the car it felt like I was walking on a gravel parking lot.  All that fuel dissolved the oils in the asphalt and really left a mark.
large.06082020_slowpoke.JPG.0458b52aa0ce
*sigh*
Repeat to myself - Datsuns are fun, Datsuns are fun, Datsuns are fun...
Edited by carterb
  • Sad 2
Wow - bummer, sorry to hear that, and you were making such great progress. When I do my fuel pump install and gas tank draining, I will check for any rubber cap like that - thanks for the heads up. I liked your post as a thanks for posting, not what happened. ☹️
Edited by rosso
On 8/31/2020 at 9:53 PM, Draker said:
I can smell that from here. Sorry to see it!
Thanks...
If there is one thing I excel at, it is rolling with the punches.
Time to put this thing back together then...  First I found the upper seat belt anchor nut and poked a hole in the headliner so I could mount seat belts with shoulder harnesses.
large.06142020_slowpoke_(1).JPG.7e7f0ffd
I grabbed the belts out of Cooper since I'm not currently driving that car.  I grabbed the carpet too.  It's a cheap felt carpet but it makes a nice substitute for the now missing jute pads.
large.06142020_slowpoke_(3).JPG.7ffee699
large.06142020_slowpoke_(4).JPG.8e63c9dc
Seat belt receivers
large.06142020_slowpoke_(5).JPG.a0233d1e
Rubber mats back in.  They cleaned up very nice.
large.06142020_slowpoke_(6).JPG.87467b20
The blue ones did not.  Which is fine with me, I would have removed them anyway.
The cap is now replaced by a short section of hose leading under the car with a plug secured in place.
large.06142020_slowpoke_(7).JPG.3e795d75
With the seat back in, you'd hardly know something had happened - except for the staining on the rockers - to be addressed later.
large.06142020_slowpoke_(8).JPG.75e82bf8
To complete the re-dress, I installed the 4 best hubcaps I could find.
large.06142020_slowpoke_(9).JPG.ef38680f
Now it's looking like something!
  • Like 3
Back to work then...
large.06152020_slowpoke.JPG.a2974c333eb2
Things were going okay for a few days but then the carb started cutting out on us mid-drive.  I suspected that when the tank ran dry, something made it upstream past the filter.  I crossed my fingers and tried blowing out the jets with WD40 but blowing back into the float bowl would only be a temporary fix at best.
large.1844152809_06182020slowpoke.JPG.68
Step 1, replace fuel filter.
large.06212020_slowpoke.JPG.b16809ca6682
Step 2, find that soft line leading to fuel filter is no longer soft and fuel filter drains contents all over inside of engine bay.  *sigh*  Why can't the gas just stay where it belongs in this car?!
Step 3, replaced hose.
Step 4, consider disassembling carb to remove debris causing sputtering (seems like it is in the secondary circuit)
Step 5, discover individual gaskets are not available, order carb rebuild kit.
In the mean time, Father's day comes around and Corey gives me the most awesome gift ever!
A custom "Slowpoke" air freshener.
large.06262020_slowpoke.JPG.5304ac7eacad
Thanks Corey!!!
Surprisingly, even before the air freshener was unsheathed, the car didn't even smell like gas.  Or maybe my nose is fried?  How many years have I been driving carbureted Datsuns?  There must be SOME cumulative olfactory damage...
