SLOWPOKE - 1971 1400DX Bluebird 4dr (510)
  • 11 months later...
  • Replies 161
It looks like I have not posted in almost a year.  A couple things have happened since then...
We had some beautiful winter days
large.610935087_11142022slowpoke.JPG.ee0
large.12162022slowpoke(2).JPG.d1fe23a22f
large.12162022slowpoke(1).JPG.c58b9cdd8f
And lots of snow!
large.12032022slowpoke.JPG.af23c872289c1
Spring time brought the true source of my water leak...
large.03272023slowpoke.JPG.5b69d6e4449b6
large.03052023slowpoke(3).JPG.b8cf914bf4
Using a mirror, I could see the seepage between the head and the block
large.03052023slowpoke(2).JPG.49d9c604ba
large.03052023slowpoke(1).JPG.a72df7ae66
Not a pretty sight and I kept having to top up my radiator every month.  No apparent leaking into the cylinder but you can see it has no trouble finding its way outside the block.
My clutch had started slipping by this time so I found a replacement clutch kit.
large.06012023slowpokeclutch(4).JPG.9329
large.06012023slowpokeclutch(3).JPG.c695
large.06012023slowpokeclutch(2).JPG.5303
large.06012023slowpokeclutch(1).JPG.20c3
The clutch kit was easy to find.
The time to replace it was not.
My life was consumed by a huge project at work and my brother lost his life to cancer on May 25, 2023.
He had asked me to be his executor before he died.
I can tell you that even though 150,000 people die every day on this planet - when you try to conduct business on behalf of one of them - the institutions you are required to interact with behave like my brother was the first person in history to have lost his life.  So stressful!
Work got even more intense in June and caused me to make a trip to the UK in July.
While I was away, my friends Jeff and Paul swapped my clutch for me.  I can't tell you how huge that was to come back from the UK and have that taken care of and off my list.  They have my sincere gratitude!
It looks like even though I have an L18 bottom end, it was still running the L14 clutch.  Have you ever seen such a tiny L-motor clutch disk?!
180mm
large.07272023slowpoke.JPG.3e3a957f85893
And no life left that's for sure!
large.07272023slowpokeclutch.JPG.178e1e7
Edited by carterb
Summer isn't very long in Washington but it sure is beautiful!
large.07232023slowpoke(3).JPG.dd719dfa02
large.07232023slowpoke(2).JPG.199e862725
large.07232023slowpoke(1).JPG.dadf71fceb
That's Paul's old 2002 WRX beside Slowpoke.  He got a new Lexus lease car for work so I bought the WRX off of him for a little summer fun and winter duty.  Thanks again Paul!
Then one day...
*BANG*!!!
Lost the new muffler on the way to work!  But it hung on long enough for me to get to a parking spot and remove it from the hanger.
large.08022023slowpoke(2).JPG.303375b322
large.08022023slowpoke(1).JPG.d6322ac083
Looks like I get to try welding exhaust for the first time.
It broke at the base of the old weld
large.08052023slowpoke(1).JPG.5b33a87f1f
New weld functional but not pretty
large.08052023slowpoke(2).JPG.7870a276e1
Almost back in business!
large.08052023slowpoke(3).JPG.c630beab14
Look ma!  No leaks!
large.08052023slowpoke(4).JPG.bdb7759ffd
Typical Electroimpact Datsun car show!
large.09222023slowpoke(2).JPG.448fb72ec3
Skyline sighting
large.09122023slowpoke.JPG.d62f76cb2e1ea
1971 1400DX Bluebird 4dr at work
large.08112023slowpoke.JPG.9245df4c6fdb4
Summer turns to winter
large.01112024swampthing.JPG.e43d362f1da
More snow!
large.01112024slowpoke.JPG.5051896bc0c44
My snow tires just don't seem to handle this like they should
large.01132024slowpoke(1).JPG.9268d24cb0
Oh...  Perhaps it is because they are over 16 years old!
large.01132024slowpoke(2).JPG.67f94820f9
Well...  Put is on the list...
Work finally slowed down and Christmas break provided an opportunity to take care of that head gasket leak.
large.12262023slowpoke(1).JPG.3633068467
Upon removing the head, I found that the bolts by the firewall must have been torqued by a 3rd grader...  Just a tad more than finger tight.  It's *possible* I could have just torqued them down and got back on the road but I was committed now...
First to get rid of the JDM rust water
large.12262023slowpoke(2).JPG.ad878990e7
I left the intake and exhaust in place and just lifted up the head with a crane.
large.12262023slowpoke(3).JPG.999ebd72cd
Head looks decent - may need new valve stem seals next.
large.12262023slowpoke(4).JPG.257c8dcf80
large.12262023slowpoke(5).JPG.6579575a72
large.12262023slowpoke(6).JPG.17ff02ebee
large.12262023slowpoke(7).JPG.12f86adf7b
Block an pistons look to be in good nick too!
large.12262023slowpoke(9).JPG.b3ca3baf9c
large.12262023slowpoke(10).JPG.8cf0cf980
large.12262023slowpoke(11).JPG.87cb02a2e
large.12262023slowpoke(12).JPG.c4d6a318b
Gee, can you tell where it was leaking?
large.12262023slowpoke(13).JPG.7d9b6d50f
All back together now and no leaks and after flushing the block and radiator 3 times, the coolant is even *slightly* less orange.  : )
When Jeff and Paul changed the clutch for me, they recommended that I service the driveline soon.  And also the front wheel bearings.
I took care of the bearings when I did the head gasket but I needed another opportunity for the driveline.  I finally removed it a couple weeks ago and took it to Drivelines NW for new u-joints and balance.  It came back very pretty but put quite a dent in my wallet.  $250 for this work now.  Nothing is cheap these days...
large.02032024slowpoke(8).JPG.ca008500f7
large.02032024slowpoke(9).JPG.f26446fdaf
And finally - instead of maintenance - I took the opportunity to UPGRADE the car.  N510 chassis have 4.3 something rear end gears and the engine is really singing on the freeway back and forth to work so I thought I would swap in a stock 3.9 rear but Jeff said I was being silly and I should put in an LSD instead and he was of course correct so I grabbed a 3.7 R160 LSD.
large.02032024slowpoke(1).JPG.c801173962
The stub shaft bolt head had been sheared off!  What the heck!
large.02032024slowpoke(2).JPG.a35870b543
large.02032024slowpoke(3).JPG.beb45adff2
Then I remembered.  I was running that rear end in Granny with a faulty CV axle set up and the axles bound and ground the bolt heads off while driving.  I will have to deal with that later.
So I grabbed another one that looked nice and clean.
large.02032024slowpoke(5).JPG.2adda27cb2
And swapped in the stub shafts from the stock rear end I just removed
large.02032024slowpoke(6).JPG.475602f435
Insert rear end here:
large.02032024slowpoke(4).JPG.dbee4de392
More betterer!
large.02032024slowpoke(7).JPG.be475ee798
I got some advice from the bluebirds list and filled with Royal Purple 75/140W synthetic oil w/ friction modifiers.  At $25/qt it must have some magic too or purple food coloring is the most expensive food coloring in the rainbow!
large.02042024slowpoke.JPG.205b4418ef0de
It drives awesome and I am happy and you are up to date!  : )
10 minutes ago, datzenmike said:
If stored out of the sun they are ok.
I've used them on every Datsun 510 I've owned during winter time.  I might have bought them new in 2007 - I don't remember.
I'm in Seattle though, so define "sun".  : )
