Payco Posted July 27, 2020 Report Share Posted July 27, 2020 Guys, How much of a job is it to remove the windscreen wiper motor/assembly to paint/polish ?. Not looking to overhaul the internals but I'm guessing you have to disconnect the linkage to remove it from the car ?. Do we have any "How to" guides or can someone share their experience on the difficulty level and challenges. Thanks Martin Quote Link to comment
DanielC Posted July 27, 2020 Report Share Posted July 27, 2020 This page on my 521 thread shows wiper motor work. It might have some useful info for your 1600 SSS coupe. https://ratsun.net/topic/49698-my-dragon-datsun-521/page/12/ 1 Quote Link to comment
Payco Posted July 27, 2020 Author Report Share Posted July 27, 2020 Thanks Daniel. Will have a read. All feedback and advice is welcomed and appreciated. Martin Quote Link to comment
carterb Posted July 27, 2020 Report Share Posted July 27, 2020 It is not difficult at all, but the small screws holding the wiper pivots down are often rusted in place and so need to be drilled out and replaced. There is a clip that holds the motor arm to the wiper assembly under the cowl. Remove the clip (and don't lose it) and the rest is self explanatory. --carter 2 Quote Link to comment
grannyknot Posted July 27, 2020 Report Share Posted July 27, 2020 Just be sure to take lots of pics before and during the work so every thing goes back where it needs to. Although it is rewarding to clean up the appearance of the wiper motor the internals are very well sealed off and won't need much in the way of maintenance, what really needs the work is the linkage to the wiper arms and specifically the spindles. The last pic is of the spring clip that holds the spindles in place, a dental pick is a good tool to remove it then clean an polish the spindle, grease it and slide the spring clip back down the shaft, then throw away what is left of the rubber caps that were there when you started the job and buy 2 new ones, good for another 40 yrs. 3 Quote Link to comment
Payco Posted July 28, 2020 Author Report Share Posted July 28, 2020 really helpful. thanks guys. Quote Link to comment
Payco Posted July 30, 2020 Author Report Share Posted July 30, 2020 Anyone able to show me the assembly within the cowl ie how she bolts on to the mechanical arms. The clip below was loose and I'm gusessing it has a part to play somewhere. Thanks again all. Quote Link to comment
rosso Posted July 31, 2020 Report Share Posted July 31, 2020 (edited) That is the clip Carter was talking about above.. "There is a clip that holds the motor arm to the wiper assembly under the cowl." I found the carpartsmanual.com is a good resource for diagrams of the 510. https://www.carpartsmanual.com/datsun/bluebird-1968-1973/electrical/windshield-wiper/from-oct-68 Edited July 31, 2020 by rosso Quote Link to comment
Payco Posted July 31, 2020 Author Report Share Posted July 31, 2020 thanks. All fixed and back working. Cheers guys. 1 Quote Link to comment
yenpit Posted August 3, 2020 Report Share Posted August 3, 2020 That clip mentioned by carterb & shown by you (fuzzy pic) is a little "loose" when in place, so no worries there! If your old original wiper motor doesn't suit your needs, I have installed Honda wiper motors (some are literally a bolt in), which are far more technologically advanced, being 25+ years newer. If you use the same motor I did (ugh, can't remember the exact year!), I have the wiring figured out. Honda changed wire color codes often, between years & models, so that should be researched ahead of time for ease of installation! Quote Link to comment
4perrev Posted August 3, 2020 Report Share Posted August 3, 2020 (edited) On 7/27/2020 at 3:16 PM, grannyknot said: Just be sure to take lots of pics before and during the work so every thing goes back where it needs to. Although it is rewarding to clean up the appearance of the wiper motor the internals are very well sealed off and won't need much in the way of maintenance, what really needs the work is the linkage to the wiper arms and specifically the spindles. The last pic is of the spring clip that holds the spindles in place, a dental pick is a good tool to remove it then clean an polish the spindle, grease it and slide the spring clip back down the shaft, then throw away what is left of the rubber caps that were there when you started the job and buy 2 new ones, good for another 40 yrs. Nice work Grannyknot….My whole car is on its way to you. Should see her by next week!!!!! Edited August 3, 2020 by 4perrev Quote Link to comment
grannyknot Posted August 4, 2020 Report Share Posted August 4, 2020 23 hours ago, 4perrev said: Nice work Grannyknot….My whole car is on its way to you. Should see her by next week!!!!! Sure thing, just don't send it C.O.D. Quote Link to comment
