MiltonV Posted May 8, 2020 Report Share Posted May 8, 2020 Which is the most common for a 71 with J series motor? Metal or plastic? 1 Quote Link to comment
d.p Posted May 8, 2020 Report Share Posted May 8, 2020 Dont think I have seen a metal one, so my vote would be for plastic. 1 1 Quote Link to comment
Crashtd420 Posted May 8, 2020 Report Share Posted May 8, 2020 I'm sure if we are wrong someone will let use know, but yes I believe the factory ones are plastic.... 1 1 Quote Link to comment
DanielC Posted May 8, 2020 Report Share Posted May 8, 2020 521 trucks in the USA with L-16 engines had both metal, and plastic, plastic being used in later trucks. The L-16 engine engine was tilted to the right, and because of this, the fan is not centered on the radiator, and the fan shrouds were offset to accommodate this. What material a car part is made of is a cost decision. What is cheaper to make, and what material can be made with lower cost tooling. Sheet metal is more expensive, but easier to make a stamping die for. On the other hand, plastic injected into a mold is cheaper, but the mold is way more expensive. If you are going to make a few parts, for a low selling model, 521 with J series engine, use metal. If you are going to make a lot of parts, 521 with L-16 engine, a big seller in the USA, and the "Premium" model in Japan, it becomes more economical for a car company to invest in more expensive plastic mold tooling. Milton, does the serial number of your 521 begin with PL-521 or just L-521? 2 Quote Link to comment
Crashtd420 Posted May 8, 2020 Report Share Posted May 8, 2020 See I told you someone would correct us.. 1 Quote Link to comment
wayno Posted May 8, 2020 Report Share Posted May 8, 2020 (edited) This will be interesting, I have several metal shrouds and I have no idea what they are for now, maybe I have one as my 521 kingcab had a J series in it when I bought it and I never throw anything away, so if someone posts a photo of a J series shroud................... Edited May 8, 2020 by wayno 2 Quote Link to comment
Charlie69 Posted May 9, 2020 Report Share Posted May 9, 2020 I would be leaning towards metal if it was a J13 in the USA. Costo Rica is another factor that I know nothing about! LOL Quote Link to comment
pidge Posted May 9, 2020 Report Share Posted May 9, 2020 Don’t mean to hi-Jack this thread, but while we’re on the topic did 69’ with a J13 ever come with a fan shroud? Mine didn’t when bought used. -Pidge 1 Quote Link to comment
MiltonV Posted May 9, 2020 Author Report Share Posted May 9, 2020 9 hours ago, DanielC said: 521 trucks in the USA with L-16 engines had both metal, and plastic, plastic being used in later trucks. The L-16 engine engine was tilted to the right, and because of this, the fan is not centered on the radiator, and the fan shrouds were offset to accommodate this. What material a car part is made of is a cost decision. What is cheaper to make, and what material can be made with lower cost tooling. Sheet metal is more expensive, but easier to make a stamping die for. On the other hand, plastic injected into a mold is cheaper, but the mold is way more expensive. If you are going to make a few parts, for a low selling model, 521 with J series engine, use metal. If you are going to make a lot of parts, 521 with L-16 engine, a big seller in the USA, and the "Premium" model in Japan, it becomes more economical for a car company to invest in more expensive plastic mold tooling. Milton, does the serial number of your 521 begin with PL-521 or just L-521? The aluminum plate inside the engine bay says L521 1 Quote Link to comment
MiltonV Posted May 9, 2020 Author Report Share Posted May 9, 2020 12 hours ago, pidge said: Don’t mean to hi-Jack this thread, but while we’re on the topic did 69’ with a J13 ever come with a fan shroud? Mine didn’t when bought used. -Pidge According to my user manual yes it does. 1 1 Quote Link to comment
Ash77 Posted May 20, 2020 Report Share Posted May 20, 2020 Ive got a 521 with a J15 and it came with a plastic fan shroud if that helps. Bought off the first owner so I'm guessing its the original one. 1 1 Quote Link to comment
pidge Posted May 20, 2020 Report Share Posted May 20, 2020 Yeah mine didn’t have it (69 521 with the j13) another part I’ll put on the to do list. thanks Milton for the pic. -Pidge 1 1 Quote Link to comment
