73 240Z last one for me
earlyvws
So I started this car May of 2018, and was working on it till June 2019. I have since then moved from CA to TX. I'm now ready to get back to finishing this Z. I'm in the middle of wiring this cal and have run into a problem with the turn signals. I have every wire counted for except 2 wires coming from the dash harness. One is black and has a male spade and the other is a red (18 gauge I think) with a female connector. The red is a constant 12V and seems to power several fuses on the fuse block. The black does not seem to be a ground wire but it tones out to another black wire on the drivers side and that wire is also black with a female bullet connector. I have eliminated a few of the original items and I have checked a few different wiring diagrams but I cannot figure out where these go. As far as the turn signal switch is concerned I have headlights, tail lights, hazards, but no turn. If u look at the assembly it is 2 halves and the side with the headlight switch has power and none of the wires on the turn signal side has power. I can't help but think the red wire needs to power the turn signal side some how but there is no where to connect it.
In these pics I am showing the original harness as I took it out. Then installed after I did a few mods to it and rewrapped it.
49819713811_21cba4b3a6_k.jpgIMG_4067 by Joe Hill, on Flickr
In this photo the black alligator clip is attached to the red wire Im asking about
49820030132_4fa75d41dc_k.jpgIMG_0974 2 by Joe Hill, on Flickr
In this photo the black alligator clip is attached to the unknown black wire and it seems to me connected or is the same wire as the red alligator clip.
49819180468_c7369596b5_k.jpgIMG_0976 by Joe Hill, on Flickr
Please HELP. I need to know where these go. I should mention that despite my modifications all wires are still factory and in most cases I left everything I did not use just taped away so I can not get confused.
Edited by earlyvws
  • Replies 20
Here is a few pics to get u interested
Day 1
49820112007_0b8835f8d4_k.jpgIMG_3024 by Joe Hill, on Flickr
Chemical paint strip before going to blasting
49819802731_7cae0a56b8_k.jpgIMG_3126 by Joe Hill, on Flickr
Powdercoat Primer
49819263063_086f00ea0d_k.jpgIMG_3475 by Joe Hill, on Flickr
Paint
49820115972_88ae75c250_k.jpgIMG_3714 by Joe Hill, on Flickr
Bottom
49819265663_9c28a923d3_k.jpgIMG_3696 by Joe Hill, on Flickr
Lizard skin sound deadner
49819807211_2e41ca0d4a_k.jpgIMG_3710 by Joe Hill, on Flickr
@earlyvws, nice work on the Z! Powder coat primmer?  I'm going have to check that out, the red and black wires up on the steering column, I'm pretty sure those are there for the ignition key buzzer, I believe the wires were installed in the wire harness even before the  key/ignition switch had the key sensor.  Usually they were disconnected decades ago to silence the buzzer.
If there is no power on the signal side then you need to trace those red wires back and find the break in the line or blown fuse or maybe blown signal flasher.  The original signal flasher was a mechanical unit so you would want to replace that anyway with a modern electronic flasher.
No Ray not done yet. Yes lets move this to projects!
Thanks granny knot. I actually finally figured everything out. I don't have the OG ignition anymore so I did not have anything to look at. I finally found the FSM. Not sure why I did not have it before. Im using the DZ push button start. And for some reason it is not sending out any 12V on the green/ white wire and Black/ white wire. I figured out a work around and now my turn signals work.
Edited by earlyvws
Here is a few more shots of progress stuff
Every part of the body is powder primer, /hood/ door/ hatch/ fenders
49824838907_ffaccaa2a5_k.jpgIMG_3478 by Joe Hill, on Flickr
Re-zinc most of the OG hardware
49824841362_330dead023_k.jpgIMG_3736 by Joe Hill, on Flickr
49824842072_aaefb1e3ab_k.jpgIMG_3742 by Joe Hill, on Flickr
L28 with a 5 speed
49824883887_6d56781ab0_k.jpgIMG_4167 by Joe Hill, on Flickr
49824030623_5ab7bc6a23_k.jpgIMG_4166 by Joe Hill, on Flickr
Valve cover is powder coated first black, then blue flake metallic then powder clear
49824029148_2b96f6b297_k.jpgIMG_4125 by Joe Hill, on Flickr
49824035473_4f3562d14e_k.jpgIMG_4128 by Joe Hill, on Flickr
Edited by earlyvws
  • Like 3
A few things I made to save money
Made a cv axle kit using German Porsche cv's and chromoly axles
49824857662_7256a2e1fa_k.jpgIMG_3910 by Joe Hill, on Flickr
49824004688_ebc7cc647f_k.jpgIMG_3911 by Joe Hill, on Flickr
49824523201_a21c350fe5_k.jpgIMG_4203 by Joe Hill, on Flickr
49823992728_0a97c9828d_k.jpgIMG_4202 by Joe Hill, on Flickr
Made my disc brakes front and rear wildwood calipers all around
49824883822_210c35b103_k.jpgIMG_4168 by Joe Hill, on Flickr
49824883732_348451f685_k.jpgIMG_4169 by Joe Hill, on Flickr
49824560446_3389af6f4a_k.jpgIMG_4170 by Joe Hill, on Flickr
Im using a vintage air gen Iv A/C so I made a solid aluminum face plate to hold a double din radio A/C controls and kept the OG light and center vent
49824521421_815011c493_k.jpgIMG_4024 by Joe Hill, on Flickr
Re used some speed hut gauges from another project I sold. These are a little small but was good because I was able to machine parts to hold gauges in the original pods
49824527406_647ee2153f_k.jpg56922683137__4DB05CD8-1FA8-4BF8-A669-841F8CA367A5 by Joe Hill, on Flickr
Since I had an extra hole I used the side emblem with a back light
49824521271_772d7bf3ec_k.jpgIMG_4009 by Joe Hill, on Flickr
49823990938_299a22e93d_k.jpgIMG_4008 by Joe Hill, on Flickr
Got a new dash pad from Hung and Ivan
49824522436_e18867cb08_k.jpgIMG_4113 by Joe Hill, on Flickr
49824949222_0fca93791b_k.jpgIMG_0971 2 by Joe Hill, on Flickr
Some random pieces I bought
49824561056_86203e22d1_k.jpgIMG_4138 by Joe Hill, on Flickr
49824884012_4273b02154_k.jpgIMG_4141 by Joe Hill, on Flickr
49824882527_248cf4ac38_k.jpgIMG_0955 2 by Joe Hill, on Flickr
49824559551_e437a71e3a_k.jpgIMG_0954 2 by Joe Hill, on Flickr
49824029338_56fa621eac_k.jpgIMG_0952 2 by Joe Hill, on Flickr
49823993313_2ae459d51e_k.jpgIMG_4204 by Joe Hill, on Flickr
Made a battery tray. Ive decide the engine bay isn't going to be super organized because I do not want to have anything in the interior.
49824029398_00d862ebcf_k.jpgIMG_0950 2 by Joe Hill, on Flickr
And finally some assembled photos
49824518546_f669aa7b87_k.jpgIMG_3719 by Joe Hill, on Flickr
49824519511_77dbf07aae_k.jpgIMG_3784 by Joe Hill, on Flickr
49824846807_e5c778b50f_k.jpgIMG_4205 by Joe Hill, on Flickr
49824525456_faf2458c04_k.jpgIMG_4210 by Joe Hill, on Flickr
49824848292_42f0c38430_k.jpgIMG_4212 by Joe Hill, on Flickr
49824883512_e1c0b83e35_k.jpgIMG_4278 by Joe Hill, on Flickr
49824561766_8cbd5d5660_k.jpgIMG_4282 by Joe Hill, on Flickr
And finally the actual wheels I'm running. SSR Dori Dori
49824568681_0efbab0b27_k.jpgIMG_4478 by Joe Hill, on Flickr
49824891112_3b57399529_k.jpgIMG_4474 by Joe Hill, on Flickr
Maybe the only Z with these wheels? Anyone know if there is anyone else with them?
So you are caught up. I didn't take a lot of photos. I was building this Z a 510 for a buddy that has all the same amount of work as this z. I used the exact same process for his car. and packing all my shit to move to Texas. So I will start taking new photos and update progress.
Right now I think I finally have all the body electrical working. Cant test the micro squirt, EDIS yet.
13 hours ago, earlyvws said:
Wow that throttle piece is nice. I almost had to make one. Things weren't working out with the OG one at first. Then I made a bracket that made it work. Whats the other end look like?
It has a UHMW wear ring pressed into the bottom. So its not metal on paint. It also has 8MM bronze oil bushings pressed in so it will self lube for a 100 years.
  • 3 months later...
Here in Colorado, we have Denver Metal Finishing.  In Michigan, we had Allegan Metal Finishing.  Google locally "metal finishing or plating", but I have heard that CA does not offer this kind of plating cuz of EPA.............??  I have seen home brew yellow zinc & prefer the professional outcome 🙂 Biggest problem is that they literally toss ALL of the hardware & parts into the plating tanks, so YOU need to know where everything goes once plated.  If you have spare hardware from other Datsun projects or parts cars, do it ALL!  We have boxes done & always have extra hardware to use later!  If you are gonna do it, you must use a LESS aggressive media like glassbead......NOT an aggressive media like aluminum oxide etc!
Wow earlyvws, your project is killer!
On 8/2/2020 at 10:25 PM, lbpd716 said:
I'm planning on starting my 71 soon.  Did you do the plating yourself or might I ask how or where I can send my stuff to get results like that?  Looks great!
