Stoffregen Motorsports Posted May 16, 2020 Report Share Posted May 16, 2020 Always check the backlash before and after installing a new carrier. Hindsight is 20-20. Quote Link to comment
5t341tH Posted May 27, 2020 Author Report Share Posted May 27, 2020 So i figured out the problem was the pinion flange wasn’t tight enough. I torqued it down and now all is well. The diff locks up nicely and I can do pretty slides now Quote Link to comment
vicdat Posted September 22, 2020 Report Share Posted September 22, 2020 On 3/31/2020 at 11:47 AM, 5t341tH said: Hey guys. I'm looking at available options to fit my 620 with an LSD. I am not familiar with this area so I need some help. I'd love to stick with factory options, but it seems like they are pretty hard to find with my research. All I know is I need an H190. Will it be a direct fit into my stock rear end? Thanks! can someone check this out and see if it will work? https://page.auctions.yahoo.co.jp/jp/auction/s727559651 Check with Timothy Leary.... 1 Quote Link to comment
frankendat Posted September 22, 2020 Report Share Posted September 22, 2020 7 minutes ago, vicdat said: Check with Timothy Leary.... Excellent Quote Link to comment
vgwagon Posted July 11, 2023 Report Share Posted July 11, 2023 On 3/31/2020 at 2:50 PM, wayno said: I am no LSD guru, there are others on here that actually bring them here from Japan, but again they are expensive. I put one in my 1969 Datsun kingcab turbodiesel truck, before I had a H190 with 3.5 gears out of a Hardbody, then I found an LSD in a 1993 Nissan Hardbody with 3.5 gears so I installed that and drove it around for a couple years, the one thing that I didn't like was when making a left hand turn at a signal where when you go when you have the room was that it became unpredictable, if it was raining or the road was wet the back end of my truck would try to come around on me, I had to be very careful as i didn't want to wreck it, it was scary sometimes, so when I found a H190 with 3.3 gears I removed the LSD and installed that, I have not regretted what i did, yes I spin one tire every once in a while when it is wet outside, but I don't have the back end of my truck racing the front end of my truck anymore either, and that is what I care about. Also it made the whole back of my truck vibrate when I stepped on the pedal and made a 90 degree turn when it was dry outside. DMike gave you the correct ratio even though he typed 48/12 instead of 48/13, it is 3.69 which I have never heard of before, that is close to 3.7 gear ratio. This is what a H190 Nissan LSD looks like. This is what a Nissan H190 open differential looks like. Do you still have this diff or did you sell it already? Quote Link to comment
wayno Posted August 2, 2023 Report Share Posted August 2, 2023 On 7/11/2023 at 5:41 AM, vgwagon said: Do you still have this diff or did you sell it already? Yes I still have the h190 LSD with 3.5 gears, I have not tried to sell it yet. Quote Link to comment
