grannyknot Posted December 21, 2019 Report Share Posted December 21, 2019 I started tearing down the instrument cluster today, PO manged to lose the clear plastic windows and looks like he installed an aftermarket tach, but the circuit board is the real problem. A leak at the bottom of the windshield has rusted the backing plate behind the board but also the copper on one of the lines has corroded and broken the circuit. You can see where he tried to solder a jumper wire over top of the break. I was going to drill out the 5 brass rivets holding the board to the backing plate so I can remove the rust. Is there anyway to repair a circuit board? Thanks Quote Link to comment
banzai510(hainz) Posted December 22, 2019 Report Share Posted December 22, 2019 (edited) I would have just lightly cans the copper and get some solder flux and make a new jumper.Who ever did this did not use flux as the solder would flow better. If this is a multilayered circuit board and broke inside you got to find a spot that is aces sable an add a bypass fire if possible. really there is a lot of people that have spares of these things and start out with a better one.shit I might have 2 spares but you want the tach as what you got looks cool. put a Want Ad for a new inst panel Edited December 22, 2019 by banzai510(hainz) Quote Link to comment
thisismatt Posted December 22, 2019 Report Share Posted December 22, 2019 Honestly, I would just replace the whole thing. A stock dash without tach should be a dime a dozen. Just looks like a lot of work for a stock part you could find for cheap. Quote Link to comment
Draker Posted December 22, 2019 Report Share Posted December 22, 2019 I have one. if interested. Quote Link to comment
grannyknot Posted December 22, 2019 Author Report Share Posted December 22, 2019 (edited) Thanks guys, it wasn't as hard as I thought it would be, the rust on the backing plate was just on the edges and I have a 5 gal bucket full of 510 and KA24 fasteners to be re plated so I'll just throw it in with rest. 7 hours ago, banzai510(hainz) said: but you want the tach as what you got looks cool. So I take it that 510's didn't come with a tach? The tach that came with it looks like it was never hooked up and seems to be in new condition, anyone want to take an educated guess which wire goes to the ignition coil? 4 wires, red, black, white and green. Edited December 22, 2019 by grannyknot Quote Link to comment
thisismatt Posted December 23, 2019 Report Share Posted December 23, 2019 That looks like a molested factory tach. They were an option. 1 1 Quote Link to comment
datzenmike Posted December 23, 2019 Report Share Posted December 23, 2019 4 hours ago, grannyknot said: Thanks guys, it wasn't as hard as I thought it would be, the rust on the backing plate was just on the edges and I have a 5 gal bucket full of 510 and KA24 fasteners to be re plated so I'll just throw it in with rest. So I take it that 510's didn't come with a tach? The tach that came with it looks like it was never hooked up and seems to be in new condition, anyone want to take an educated guess which wire goes to the ignition coil? 4 wires, red, black, white and green. The guts do not look like any 510 tach. That switch looks like the after market 4 6 8 cylinder option switch. The four wire 510 tach has black, green and two white wires Quote Link to comment
banzai510(hainz) Posted December 23, 2019 Report Share Posted December 23, 2019 There is a SSS tachometer cluster which people want a lot of money Byron on the 510realm or others know how to wire them up.Some say there is a series or parrellel type wiring Quote Link to comment
thisismatt Posted December 23, 2019 Report Share Posted December 23, 2019 1 hour ago, datzenmike said: The guts do not look like any 510 tach. That switch looks like the after market 4 6 8 cylinder option switch. The four wire 510 tach has black, green and two white wires Looks like a factory face & housing someone swapped the guts into... Quote Link to comment
banzai510(hainz) Posted December 23, 2019 Report Share Posted December 23, 2019 I think it would be ez to figure out one is power from the key switch +12volts one is ground the rpm wire would be the minus side of the coil Quote Link to comment
grannyknot Posted December 23, 2019 Author Report Share Posted December 23, 2019 Yes the tach face plate and housing are definitely original and the tach mechanism after market and as Mike says that switch on the back would be 4-6-8 cyl. Red is pos., green or black would be neg., I guess my real concern is am I going to blow something by hooking up the wrong lead to the coil? Quote Link to comment
datzenmike Posted December 23, 2019 Report Share Posted December 23, 2019 It may be inductive. Has to be in line with the coil negative. There were 2, 510 tachs. One 3 wire and an inductive 4 wire. Quote Link to comment
banzai510(hainz) Posted December 23, 2019 Report Share Posted December 23, 2019 Look up a typical Aftermarket tach wiring i believe most were hooked up to the minus side coil to trigger the rpm oh I forgot one wire could be to light up that tach originally. 1 Quote Link to comment
grannyknot Posted December 24, 2019 Author Report Share Posted December 24, 2019 Got it, green is the tach wire, a buddy on ClassicZcar figured it out. Captain Obvious I'm a member of this forum Members 1,741 6,551 posts Map Location:Philadelphia, PA Report post Posted 19 hours ago Red is +12. Black is ground. Green is speed input.* White is gauge illumination lamps. *Note that I don't know what kind of signal the tach is expecting, but the green wire is where it should occur. Quote Link to comment
Ken Layton Posted April 21, 2020 Report Share Posted April 21, 2020 On 12/22/2019 at 3:04 PM, grannyknot said: Thanks guys, it wasn't as hard as I thought it would be, the rust on the backing plate was just on the edges and I have a 5 gal bucket full of 510 and KA24 fasteners to be re plated so I'll just throw it in with rest. So I take it that 510's didn't come with a tach? The tach that came with it looks like it was never hooked up and seems to be in new condition, anyone want to take an educated guess which wire goes to the ignition coil? 4 wires, red, black, white and green. You did a great job repairing that circuit board. A suggestion: scrub the pc board with 99% Isopropyl alcohol and a toothbrush. It'll clean it up nicely. I've repaired a great many pinball machine circuit boards which had been damaged from the batteries leaking in a similar fashion. Quote Link to comment
iceman510 Posted April 21, 2020 Report Share Posted April 21, 2020 (edited) I have repaired circuit boards with copper strips before including in my own 510 many years ago. You can also use conductive paint, like for defroster repairs. I think I may also have one spare lens cover if you still need them. Edited April 21, 2020 by iceman510 addition Quote Link to comment
