KELMO Posted September 29, 2022 Report Share Posted September 29, 2022 29 pages in this thread and I've not posted once. The "before" pic has the vibe of "want some candy little girl?". End result looks the goods. 2 Quote Link to comment
datsunfreak Posted September 29, 2022 Author Report Share Posted September 29, 2022 59 minutes ago, KELMO said: The "before" pic has the vibe of "want some candy little girl?". Damn. That's the result we were going for with the after... 😁 1 1 Quote Link to comment
dimlight65 Posted October 1, 2022 Report Share Posted October 1, 2022 So, as cool as the 1, 2, 3, 4, 5, "Miso Soup!" shift knob is... the angle of the dangle makes 2, 4, and "Miso Soup!" too much of a backwards stretch for comfortable hooning. Therefore, I revived an idea I poo-pooed earlier because I didn't like the way it looked. I decided to go back to the bubble shifter thing because A) it is... and 2) it falls to hand better. I'm still not 100% a fan of the forward cant, but it does work better. Now we need to figure out why it smokes so much after engine braking, and what is clunking in the rear end... again! 1 Quote Link to comment
EDM620 Posted October 2, 2022 Report Share Posted October 2, 2022 6 hours ago, dimlight65 said: 1, 2, 3, 4, 5, "Miso Soup! Had a thought, have a leather wrap over and put the Miso on it either on the top or along the grip 1 Quote Link to comment
dimlight65 Posted October 2, 2022 Report Share Posted October 2, 2022 16 hours ago, EDM620 said: Had a thought, have a leather wrap over and put the Miso on it either on the top or along the grip I am going to have to get a "Miso Soup!" decal now. Quote Link to comment
dimlight65 Posted October 6, 2022 Report Share Posted October 6, 2022 On 10/1/2022 at 4:55 PM, dimlight65 said: Now we need to figure out why it smokes so much after engine braking So, this engine has what is known as the "Kegger" manifold, because it looks like a beer keg if you squint just right. https://images.app.goo.gl/wnD2Lwu6khF1Qy136 Anyhoo, These manifolds have a known weakness. There is a thin steel plate bolted to the bottom to seal the plenum. https://images.app.goo.gl/pu5Xn5xyDZMcUwVA7 These are known to leak. I think by being able to engine brake now, I have introduce WAAAAAAYYYYYYYY more vacuum to the plenum than it has ever seen. I believe I have sucked the gasket into submission... aw crap. I'm going to regret THAT choice of words. Moving on. I bought another manifold from the 'Bay, as well as a Hughes Plenum Repair Kit (1/4" aluminum plate, new gasket, and longer bolts.) https://images.app.goo.gl/9hyoK2zzK56C2tY47 All of that should be here soon and we'll tackle that chore... eventually. 1 Quote Link to comment
dimlight65 Posted October 8, 2022 Report Share Posted October 8, 2022 On 10/1/2022 at 4:55 PM, dimlight65 said: Now we need to figure out... what is clunking in the rear end. Found it! The pinion angle adjusters had come loose. (Whoever suggested some Locktite was in our future wins the prescience award.) We hunkered the hell out of them and the U-bolts while we were under there. We may go back and hit them with a tack weld just to be sure. With the ass in the air though, the air dam is just about at the right height! s/ Yes, it IS touching the ground. 1 Quote Link to comment
dimlight65 Posted October 13, 2022 Report Share Posted October 13, 2022 Got a whole bunch of packages today! In them was stuff! A gallon of Zero Rust grey paint so we can finally do something about the roof. A new, less aggressive air dam. (Its own post coming later) An intake manifold. (Also, its own post coming later) And the plenum repair kit. And a very extensive kit it is, I must say! Up next, manifold disassembly and cleaning. Quote Link to comment
datsunfreak Posted October 13, 2022 Author Report Share Posted October 13, 2022 Air dam on... 1 Quote Link to comment
datsunfreak Posted October 13, 2022 Author Report Share Posted October 13, 2022 (edited) Tim said he'd post more when his cat moves... 😄 Van on the move... Edited October 13, 2022 by datsunfreak 1 Quote Link to comment
dimlight65 Posted October 13, 2022 Report Share Posted October 13, 2022 (edited) Ok, the cat moved. Had a look at the intake manifold. This one had a blown plenum gasket as well. See it poking out between the bolts on both sides? Cover off, and you can see where it wasn't sealed. And the plate where it wasn't sealing. Dang, I just noticed how out of focus it is... sorry. And a couple gratuitous shots of the inside of a Kegger manifold. Finally, soaking in a bath of Simple Green. Edited October 13, 2022 by dimlight65 1 Quote Link to comment
dimlight65 Posted October 13, 2022 Report Share Posted October 13, 2022 (edited) Well, while I was welding John's transmission crossmember, he installed my new, less aggressive, more driveway friendly, air dam. (His picture is infinitely better, but I promised y'all its own post.) And I'd like to report: not a single scrape anywhere on the drive to dinner or home! Edited October 13, 2022 by dimlight65 1 Quote Link to comment
datsunfreak Posted October 13, 2022 Author Report Share Posted October 13, 2022 One more roller.... 3 Quote Link to comment
dimlight65 Posted October 16, 2022 Report Share Posted October 16, 2022 I should wait for the hot rod parts I'm buying for this to arrive so I can show them off, but I can't resist posting these. It's cleaner than it was When the Utawesome VRPs, airflow wedge, and valley pan oil splash shield arrive (the hot rod parts mentioned above), we'll start modifying this baby for more torque! 1 Quote Link to comment
dimlight65 Posted October 21, 2022 Report Share Posted October 21, 2022 We applied a couple coats of the Zero Rust paint to the roof today. I think it looks a million percent better. We have a plan to deal with the grotty driver's side and rear doors. Stay tuned. 1 Quote Link to comment
dimlight65 Posted October 22, 2022 Report Share Posted October 22, 2022 A box of bits arrived from Utawesome! I've got a lifter valley oil splash shield A 3D printed air deflector ramp thingy And VRPs (volume reduction plates) Wednesday I will start fitting them to the manifold! 1 Quote Link to comment
dimlight65 Posted October 24, 2022 Report Share Posted October 24, 2022 On 10/21/2022 at 2:34 PM, dimlight65 said: We applied a couple coats of the Zero Rust paint to the roof today. I think it looks a million percent better. On 10/22/2022 at 4:52 PM, dimlight65 said: Wednesday I will start fitting them to the manifold! I stopped by the shop "on my way" to a memorial luncheon for a friend's late mother (quotes because it was by no stretch of the imagination "on my way"). A) The roof looks even better today, possibly due to having a few days to dry and possibly due to the rain (and, I said "doo-doo" twice!). and 2) I had a preliminary grok of the Utawesome parts in the manifold. They are going to require substantial "fitting." Oh well, I knew the job was dangerous when I took it! 1 Quote Link to comment
dimlight65 Posted October 27, 2022 Report Share Posted October 27, 2022 So, start with some Utawesome VRPs Trim them to look something like this Lop off a little bit of the center divider And you get something along these lines Then, cut a V-notch in the middle for the air defector Which sits something like this Pookie and bolt that to a Hughes plenum plate And it looks something like this when installed Next we find an aluminum welder to zook the VRPs in place and we start thinking about swapping this maniflod for the old one. 1 Quote Link to comment
Duncan Posted October 27, 2022 Report Share Posted October 27, 2022 Curious as to what the end result will be with the plates. Performance? better mileage? both? I've not seen them used before. 1 Quote Link to comment
datsunfreak Posted October 27, 2022 Author Report Share Posted October 27, 2022 (edited) 8 hours ago, Duncan said: Curious as to what the end result will be with the plates. Performance? better mileage? both? It seems whoever engineered this intake made the plenum a little too large, making for laggy throttle response at low vacuum. This effectively reduces the size of the plenum to eliminate that. Some reading on what it does: http://utawesomeperformance.com/kegger-vrp.html Quote The addition of these CNC 16 gauge aluminum plates reduces the massive volume in the kegger manifold and greatly increases the velocity of the incoming air. You can see, none of the available aftermarket intakes make torque down low like the stock one. And this mod increases that bottom end torque (from idle to 3000rpm) by 10%. Edited October 27, 2022 by datsunfreak 1 Quote Link to comment
dimlight65 Posted October 27, 2022 Report Share Posted October 27, 2022 (edited) Yes, what John said! Looking at that dyno chart, and comparing it to how I drive the thing, none of the hot-rod manifolds outperform the Kegger until after 4000 rpm and that's right about where I have my shift light set. Not to mention, 4000 in 5th is 110 miles per hour! Oops, I mentioned it! 😇 Edited October 27, 2022 by dimlight65 1 Quote Link to comment
Duncan Posted October 28, 2022 Report Share Posted October 28, 2022 I get it. What didn't make sense to me was using something to restrict the air. I know Nascar does it, (or they used to) but just to reduce speed. Seeing that it was an engineering "oops" it makes sense. 👍 Quote Link to comment
dimlight65 Posted October 28, 2022 Report Share Posted October 28, 2022 16 hours ago, Duncan said: I get it. What didn't make sense to me was using something to restrict the air. I know Nascar does it, (or they used to) but just to reduce speed. Seeing that it was an engineering "oops" it makes sense. 👍 I think it's more "redirecting" rather than "restricting." The VRPs (Volume Reduction Plates) force the air to take a more direct path from the throttle body to the ports rather than having a HUGE plenum full of air that has to get moving in order to... get moving. 1 Quote Link to comment
dimlight65 Posted November 3, 2022 Report Share Posted November 3, 2022 (edited) We installed the single rear door today! First, I made a nut-holder so I could bolt in the striker. Did a "proof of concept" installation in an existing hole because I wasn't sure of my interpretation of John's measurements. My mark was about an inch too high, it turns out. Anyhoo, while I waited for John to show up and confirm the proper striker placement, I removed the double doors... ...and set them aside Then, when John arrived, we installed the single door and "aligned" it. Finally, we covered the holes left by the passenger side door hinge with some faux carbon vinyl and replaced the window decals I also dropped the manifold and VRPs off at an aluminum welder. Hopefully I'll get that back next Wednesday. Edited November 3, 2022 by dimlight65 3 Quote Link to comment
dimlight65 Posted November 3, 2022 Report Share Posted November 3, 2022 19 hours ago, dimlight65 said: I also dropped the manifold and VRPs off at an aluminum welder. Hopefully I'll get that back next Wednesday. Picked it up today after work! I'll post pictures as we finish getting it ready to install. Quote Link to comment
