ejydryd Posted May 5, 2019 Report Share Posted May 5, 2019 I purchased a Kyorad but I'm having an alternator clearance issue. The lower hose connector is hitting my alternator. Has anyone else have the same issue or have any suggestions on how to remedy. Your input is appreciated thank you in advance. 1 Quote Link to comment
datzenmike Posted May 5, 2019 Report Share Posted May 5, 2019 510 or 720? help us out, and how about a picture? 1 Quote Link to comment
Draker Posted May 5, 2019 Report Share Posted May 5, 2019 5 hours ago, ejydryd said: I purchased a Kyorad but I'm having an alternator clearance issue. The lower hose connector is hitting my alternator. Has anyone else have the same issue or have any suggestions on how to remedy. Your input is appreciated thank you in advance. Shorter alternator belt might help. This is a very common problem. I've got a few koyos, great radiators Much better then champion radiators. 1 Quote Link to comment
ejydryd Posted May 5, 2019 Author Report Share Posted May 5, 2019 Yes, it's a 510, but I didn't take any pictures. I did reposition the alternator and tried a few smaller belts (891mm) but I couldn't the belt on over the pulley. The 920mm belt fit but the alternator would hit the lower hose connector. Thanks for your response, when I get some time I will take some photos and post it. 1 Quote Link to comment
Crashtd420 Posted May 5, 2019 Report Share Posted May 5, 2019 You need to get the belt on first then bolt up the alternator up.... I had to do that upgrading my 521 alternator.... 1 Quote Link to comment
datzenmike Posted May 5, 2019 Report Share Posted May 5, 2019 Me too on a 620. Some rads have an elbow on the rad outlet so the hose is away from the spinning parts of the alternator. 1 Quote Link to comment
Stoffregen Motorsports Posted May 5, 2019 Report Share Posted May 5, 2019 If it is an aluminum radiator with welded core (not epoxy), you could cut the lower nipple off and move it. Anyone with a TIG can do this. 1 Quote Link to comment
Draker Posted May 6, 2019 Report Share Posted May 6, 2019 Easy to move it, but many people run this radiator without modding it. But not all cars are modded equally. 1 Quote Link to comment
banzai510(hainz) Posted May 6, 2019 Report Share Posted May 6, 2019 (edited) I get the shortest put it over the alt and the waterpump pully. then the lower part of belt is short and wont get over the crank pully then I turn the water pump pulley then the lower will slip on. belt sizes Gates part numbers 7345 up to 7360.of coarse depens on alt size 35 or 50 amp or bigger I heard the KOYO still need spacers on the core support to spaceit off the support Edited May 6, 2019 by banzai510(hainz) 1 Quote Link to comment
BambooU Posted May 7, 2019 Report Share Posted May 7, 2019 My Kyorad did need about a 1/4 inch spacer to get it off the supports. That did put it in a clearance issue with the alternator at the same hose/outlet that OP is having. I ended up using a slightly shorter belt (only about an inch shorter). I have been able to change the belt without totally disconnecting the alternator; start with the belt on the alternator, just need to work it around the fanbelt pulley with a small screwdriver. 1 Quote Link to comment
