Ebenezer scrooge Posted April 19, 2018 Report Share Posted April 19, 2018 The engine bay lamp doesnt work on my datsun. I measured the voltage to the wires connected to the socket and i got about 0.12V (switch not activated). When i searched here in the forum i read that there is a fuse located behind the glovebox,but does this current to this light run through this fuse? And the ground is not the problem. Quote Link to comment
banzai510(hainz) Posted April 19, 2018 Report Share Posted April 19, 2018 one side of swich should be 12volts the other side to ground. when hood is open the switch will short out. So you can ohm out the switch. If switch is shorted when hood open the its good and you can use your meter and see where you loose the 12volts. most time this is might be listed as a COMMON fuse on the fuse box. CCom,mon meaning its common to the door buzzer cig lighter dome light. Power will be ON (12volts) all the time. it just finds a Grnd to make it work thru a switch 1 Quote Link to comment
Loryde520 Posted April 20, 2018 Report Share Posted April 20, 2018 Not sure which car/truck you have but my '68 520 hoodlight only comes on when park or headlights are on. 1 Quote Link to comment
Charlie69 Posted April 20, 2018 Report Share Posted April 20, 2018 The 520 should be like the 521 and be swithed when the hood is opened. These lights are as bright as a candle in the wind! LOL Quote Link to comment
abbylind Posted April 20, 2018 Report Share Posted April 20, 2018 Mine has three settings dim, dimmer, dim wit..... :rofl: 1 Quote Link to comment
datzenmike Posted April 20, 2018 Report Share Posted April 20, 2018 The engine bay lamp doesnt work on my datsun. I measured the voltage to the wires connected to the socket and i got about 0.12V (switch not activated). When i searched here in the forum i read that there is a fuse located behind the glovebox,but does this current to this light run through this fuse? And the ground is not the problem. Early 620 under hood lamps were powered by the idle cut circuit, '74 and up were on the parking lamp circuit. If parking lamps are on there is power to the lamp also. It has nothing to do with the inline fuse in the wiring harness. It is only used on the '75 and up trucks for powering the interior lamp, cigar lighter and in one year, the clock option. 1 Quote Link to comment
G-Duax Posted April 20, 2018 Report Share Posted April 20, 2018 Buy one of those Chinese Bell & Howell 'TacLight' flashlight on TV, with a magnetic base, and carry it in the truck. You will be light years ahead. (pun intended) 1 Quote Link to comment
xxmass Posted April 20, 2018 Report Share Posted April 20, 2018 My 521 requires headlights, maybe just running lights I can’t recall, to be in the on position, and hood open. 1 Quote Link to comment
Ebenezer scrooge Posted April 21, 2018 Author Report Share Posted April 21, 2018 Ok i didnt knew that xD 1 Quote Link to comment
Loryde520 Posted April 22, 2018 Report Share Posted April 22, 2018 The 520 should be like the 521 and be swithed when the hood is opened. These lights are as bright as a candle in the wind! LOL Yes, mine is switched on when the hood is opened, but only when the park or headlights are on. 1 Quote Link to comment
Yellow Posted April 22, 2018 Report Share Posted April 22, 2018 ... Wait you guys have hood lamps? Lol 1 Quote Link to comment
Loryde520 Posted April 22, 2018 Report Share Posted April 22, 2018 ... Wait you guys have hood lamps? Lol we don't have much sunlight way up north here........ 1 Quote Link to comment
datzenmike Posted April 23, 2018 Report Share Posted April 23, 2018 I wonder why trucks got this and cars didn't???? Well the z car had a lamp you could detach and move around on an extension cord but the other's didn't. 1 Quote Link to comment
Charlie69 Posted April 23, 2018 Report Share Posted April 23, 2018 So does my 85 & 86 720 king cabs. Quote Link to comment
abbylind Posted April 25, 2018 Report Share Posted April 25, 2018 I remember that light on my 72 Z......handee! 1 Quote Link to comment
