Lopez916 Posted October 28, 2008 Report Share Posted October 28, 2008 Hey can anyone tell me where I can find the voltage regulator that controls the fuel/temp gauges? I've tried napa, auto zone, kragens local auto electric shop no luck.... Quote Link to comment
racerx Posted October 28, 2008 Report Share Posted October 28, 2008 try this guy...he has a lot of Datsun NOS stuff and used ones. http://www.rodsdatsun.com/ Quote Link to comment
Lopez916 Posted October 29, 2008 Author Report Share Posted October 29, 2008 thanks called him and he is getting one shipped! Quote Link to comment
fisch Posted October 29, 2008 Report Share Posted October 29, 2008 nissanparts.cc had them in stock as of a few months ago. I had the same problem and it worked like a charm! Quote Link to comment
ppeters914 Posted October 29, 2008 Report Share Posted October 29, 2008 Nissan Part Number: 25020-13200 Quote Link to comment
jesusno2 Posted October 29, 2008 Report Share Posted October 29, 2008 no prices i see must cost way to much!! Quote Link to comment
ppeters914 Posted October 29, 2008 Report Share Posted October 29, 2008 $15-$20 usually Quote Link to comment
Lopez916 Posted October 29, 2008 Author Report Share Posted October 29, 2008 thanks im probably gonna go with the nissan guys cuz the other guy wanted a butt load of cash for this hard to find part Quote Link to comment
Lopez916 Posted October 29, 2008 Author Report Share Posted October 29, 2008 Just ordered the part provided by ppeters came out to 29 dollars cuz it was special order shud b here in a week. Hope it solves the problem! Quote Link to comment
Lopez916 Posted October 29, 2008 Author Report Share Posted October 29, 2008 Part number ppeters provided* Quote Link to comment
banzai510(hainz) Posted October 30, 2008 Report Share Posted October 30, 2008 25020-13200 enter this # in the corner of nissanpaerts.cc and the price should come up. Beware of shipping. on that regulater (my 521) what I did is stick my skinny hand up there and moved it around and got it to work again. Quote Link to comment
fisch Posted October 30, 2008 Report Share Posted October 30, 2008 I took the regulator case apart, cleaned it and every other connection on the circuit board. Everything looked like it should work, but I still got nothing! Even cleaned every connection on the wireing harness all the way back to the gas tank, including the ground back there. Nothing worked. That replacement fixed it pronto. Quote Link to comment
MikeRL411 Posted October 30, 2008 Report Share Posted October 30, 2008 While waiting for a replacement, a good swat with the palm of the hand on top of the instrument cluster will usually restore operation for quite a while. Quote Link to comment
Lopez916 Posted November 1, 2008 Author Report Share Posted November 1, 2008 Put my new instrument voltage regulator in and no luck. So I guess I need a new fuel sending unit and temp unit?? :confused: Quote Link to comment
Cuts metal like mad Posted November 1, 2008 Report Share Posted November 1, 2008 I'd start checking your ground wires... Look in the fsm, there should be a page that shows them all. Quote Link to comment
datzenmike Posted November 1, 2008 Report Share Posted November 1, 2008 No, stop throwing parts at it. Unlikely both units are bad at same time. Ground the wire going to the temp sender and gauge should read full hot. Ground the wire to the fuel tank and it should read full. If they don't read then it's not the senders and you just saved yourself a lot of time and money. The fuel sender wire is exposed to mud, water and could easily have corroded off or the ground wire at the tank is no good. The temp sender wire could be off or corroded/bad contact or wire broken somewhere. Do your turn signals work??? They are on the same fuse as the voltage regulator that supplies the two senders. Quote Link to comment
Lopez916 Posted November 1, 2008 Author Report Share Posted November 1, 2008 (edited) All my signals work except for one reverse light. My fuel guage when I turn on the car moves barley but not giving anywhere near a acuarte reading. My temp does not move at all. Edited November 1, 2008 by datzenmike Quote Link to comment
Pacific coast Datsun Posted November 1, 2008 Report Share Posted November 1, 2008 Similar issue on my 74 620. The gas & temp gauges do work. Meaning theyre not frozen in 1 position. Wierd thing is that every time i start the truck the gas gauge reads different EVERY time & same issue w/the temp gauge except it usually reads in the HOT range. I just replaced the entire upper thermo. housing including the temp sender. Do the 620's have the same instument voltage regulator? If not what would cause intermittent gauge readings? Quote Link to comment
datzenmike Posted November 1, 2008 Report Share Posted November 1, 2008 All my signals work except for one reverse light. My fuel guage when I turn on the car moves barley but not giving anywhere near a acuarte reading. My temp does not move at all. Pull the wire off at the temp sender in the thermostat housing and touch it to ground..... the gauge should move to HOT. Try it. Quote Link to comment
dat521gatherer Posted November 1, 2008 Report Share Posted November 1, 2008 i see this all the time. clean the connections at the sending units. like mike said, when in doubt ground that damn wire on the frame body or engine to test the gauge. but clean it with sand paper or something first. water temp sending unit and wire corrode from water and the fuel sending unit get muddy from road and tire dirt. clean them people. Quote Link to comment
dat521gatherer Posted November 2, 2008 Report Share Posted November 2, 2008 for those wondering on a 521 where that other wire goes to on the fuel tank sending unit. it's the ground wire and it attaches to the frame rail next to the gas tank. the black wire. Quote Link to comment
Lopez916 Posted November 4, 2008 Author Report Share Posted November 4, 2008 ha ha well i peeped my thermostat and my temp wasnt even hookd up. i located my the wire grounded it and sure enough went hot. so today i went to the junk yard picked a plug to fit the temp sensor nipple. also got a rear view mirror off a 74 wagon. going bak tommorrow to snag the nissan electric fan off the wagon. but for my fuel guage not working is it a bad sending unit? Quote Link to comment
