willz Posted February 26, 2017 Report Share Posted February 26, 2017 Took the helper spring and put it on top, flattens the whole set. Makes the rear end unbearably stiff though so I'd recommend a 4" block with stock leaves. I'm running kyb gr2's all the way around Quote Link to comment
hobospyder Posted February 26, 2017 Report Share Posted February 26, 2017 Took the helper spring and put it on top, flattens the whole set. Makes the rear end unbearably stiff though so I'd recommend a 4" block with stock leaves. I'm running kyb gr2's all the way around look for angled blocks if going 3" and up Quote Link to comment
sebpv Posted February 26, 2017 Report Share Posted February 26, 2017 As a matter of fact i put 4in blocks on the project. Cannot confirm yet the handling and height. Quote Link to comment
willz Posted February 26, 2017 Report Share Posted February 26, 2017 I've seen 4" blocks, rode fine and such from what I could tell in a short ride. Who knows about longer drives or hard cornering though Quote Link to comment
Lockleaf Posted February 26, 2017 Report Share Posted February 26, 2017 2inch blocks and 720 4x4 leaf springs will net you over 4 inches of drop without the miserably stiff ride. Quote Link to comment
flatcat19 Posted February 26, 2017 Report Share Posted February 26, 2017 Angled 4" blocks and raise the carrier. Quote Link to comment
datzenmike Posted February 26, 2017 Report Share Posted February 26, 2017 This is going to wear a groove around the tire. Quote Link to comment
KoHeartsGPA Posted February 26, 2017 Report Share Posted February 26, 2017 205/55/15 on blazer steelies. Keep in mind this is a 78' 620 That color....WOW! I love it! Quote Link to comment
willz Posted February 26, 2017 Report Share Posted February 26, 2017 This is going to wear a groove around the tire. I've got over 4K miles on those tires at that height, half of those with the bed fully loaded down. Only time it's touched the tire was hitting a speed bump doing 30mph Quote Link to comment
willz Posted February 26, 2017 Report Share Posted February 26, 2017 Oh right, at that point in time it was riding on the bump stops Quote Link to comment
