Jocucumber Posted February 22, 2017 Report Share Posted February 22, 2017 Hello fellas... First Post! I recently bought a nice little 71' 521 and the temperature gauge doesn't work. So I replaced the temperature sensor and it wouldn't start, so i think i maybe i broke a wire at the dizzy with my dumb hands or something. Everything looked fine, so I checked for fire at the coil. no spark. I look at the points, trace every wire i can, even replaced the coil with a spare i had just in case the coil randomly went bad. Still no spark. I never in a million years thought replacing the sensor would make a difference, but I pulled the temperature sensor wire and it cranked right up! Plug it back in, No Start. I cant see in any diagram where a short in the temperature sensor wiring would affect spark, but who knows Ive lurked on this thread for years and I searched all through alot of posts and never heard anyone having a similar problem, so I registered just to ask if this is something you guys have seen before. Thanks Quote Link to comment
paradime Posted February 22, 2017 Report Share Posted February 22, 2017 Did you test the wire from the sensor to the gauge to make sure it's the correct one? Sounds like you may have an ignition wire shorted to the temp sending wire. Also, you'd probably get more response if you posted this in a truck or electrical thread rather than starting a thread for one question. 1 Quote Link to comment
Royal Sierra Posted February 22, 2017 Report Share Posted February 22, 2017 Is the wire black and yellow? Quote Link to comment
Jocucumber Posted February 22, 2017 Author Report Share Posted February 22, 2017 Did you test the wire from the sensor to the gauge to make sure it's the correct one? Sounds like you may have an ignition wire shorted to the temp sending wire. Also, you'd probably get more response if you posted this in a truck or electrical thread rather than starting a thread for one question. Yes it's temperature sensor wire, but my voltmeter is broken so my testing ability is limited. And I thought I was posting in the 521 thread... I didn't know if posting there would get more eyes... thanks for the advice Quote Link to comment
Jocucumber Posted February 22, 2017 Author Report Share Posted February 22, 2017 Is the wire black and yellow? Yeah it's the yellow wire Quote Link to comment
wayno Posted February 23, 2017 Report Share Posted February 23, 2017 When you ground out that yellow wire with a white line does your temp gauge go to full hot? Quote Link to comment
datzenmike Posted February 23, 2017 Report Share Posted February 23, 2017 Modified the title so the search engine will find this for future 521 owners with similar problem. Yeah it's the yellow wire No.... has to be Yellow with White stripe for the water temp sender. Yellow/Black (stripe) is the oil pressure sender. The temp and fuel gauges share a common power supply and have nothing to do with the ignition. Does your fuel gauge work properly????? Quote Link to comment
Jocucumber Posted February 23, 2017 Author Report Share Posted February 23, 2017 When you ground out that yellow wire with a white line does your temp gauge go to full hot? When I ground it like that nothing happens which makes me think dead ground between somewhere... but would that affect starting? Quote Link to comment
Jocucumber Posted February 23, 2017 Author Report Share Posted February 23, 2017 No.... has to be Yellow with White stripe for the water temp sender. Yellow/Black (stripe) is the oil pressure sender. I wasn't clear when I answered before... it looks fully yellow to me. No white stripe. I'm in the process of posting pics Quote Link to comment
thisismatt Posted February 23, 2017 Report Share Posted February 23, 2017 Does your fuel level work? Common for the gauge voltage regulator (on the back of the cluster circuit board) to fail. Quote Link to comment
Jocucumber Posted February 23, 2017 Author Report Share Posted February 23, 2017 Does your fuel level work? Common for the gauge voltage regulator (on the back of the cluster circuit board) to fail. Fuel level works Quote Link to comment
banzai510(hainz) Posted February 23, 2017 Report Share Posted February 23, 2017 later 521s have a dual point system so you sure you got the correct wire on there? the 2nd set points I think is blk/ yellow. this is the side with the smaller capicitor on side of the distributor. the drawing shows a blk yellow wire but I cant remeber As I run a Pertronix ignition unit now sender wire is a solid yellow if i remeber right on this drawing posted shows it yellow /white. Maybe the white turns more solid yellow over time as it get dirty so what I can remeber the blk yell by the distributor is the 2nd set of points yellow is the temp sender. yes thre is a yell/blk on the oil sender but this is obvious thats not it Quote Link to comment
datzenmike Posted February 23, 2017 Report Share Posted February 23, 2017 Yes, Black with Yellow stripe is ignition. Look for a Yellow with White stripe wire somewhere near the distributor. Quote Link to comment
Jocucumber Posted February 23, 2017 Author Report Share Posted February 23, 2017 ok give me minute to send pics... first time remember. second... Im pretty excited I got responses from Wayno and Datzen... im a little honored totally solid yellow wire. and i now im a newbie to the forum and this particular Datsun, but im a long time mechanic that possibly thought this might stump you guys. Quote Link to comment
Jocucumber Posted February 23, 2017 Author Report Share Posted February 23, 2017 http://i71.photobucket.com/albums/i141/jocucumber/IMAG06351.jpg http://i71.photobucket.com/albums/i141/jocucumber/IMAG06391.jpg http://i71.photobucket.com/albums/i141/jocucumber/IMAG06371.jpg Quote Link to comment
datzenmike Posted February 23, 2017 Report Share Posted February 23, 2017 Hainz, wayno and I, probably have 100 years of Datsun knowledge between us. Then there's Danial and..... Quote Link to comment
Jocucumber Posted February 23, 2017 Author Report Share Posted February 23, 2017 ok posted the pic links... thought i did it right so it was the images and not links, but apparently not Quote Link to comment
wayno Posted February 23, 2017 Report Share Posted February 23, 2017 That looks like the correct wire, I don't believe anything is mixed up, if you ground that wire out and nothing happens, meaning the gauge doesn't go to full hot, then something is wrong, either the wire/wire end is bad, or the gauge is bad as you said the fuel gauge works, so it is not the power regulator in the instrument cluster. You will have to find another way to test the gauge. Quote Link to comment
banzai510(hainz) Posted February 23, 2017 Report Share Posted February 23, 2017 thats the correct wire for the temp sender. Quote Link to comment
flatcat19 Posted February 23, 2017 Report Share Posted February 23, 2017 Put the old sender back in it? https://goo.gl/images/49EMO7 Use picture, take gauge out and test that pin for continuity all the way to the sender. You'll find your short/open. I don't get why it won't start though. Maybe that wire got tapped in to for something else. Quote Link to comment
Jocucumber Posted February 23, 2017 Author Report Share Posted February 23, 2017 right... I never thought anything was mixed up. Im just glad this isnt a normal thing... its an all original 521 no modifications of any kind. To be clear none of you have ever had issues with the temperature sensor wiring causing starting issues... Quote Link to comment
Jocucumber Posted February 23, 2017 Author Report Share Posted February 23, 2017 Put the old sender back in it? https://goo.gl/images/49EMO7 did that too... it runs and starts fine with the old one. also i started it with new one unplugged and then connected it in while it was running. it stayed running and now starts and runs with it connected, but of course the gauge still doesnt work which makes me feel like connecting while running killed the new sensor idk.. so somewhere between the sensor an Quote Link to comment
wayno Posted February 23, 2017 Report Share Posted February 23, 2017 That's strange, maybe wires melted together in the harness, and now there is a direct short. Quote Link to comment
Jocucumber Posted February 23, 2017 Author Report Share Posted February 23, 2017 which brings me back to the original question... obviously this isnt a common datsun thing where a dead short in the temperature sensor wiring kills spark to the coil so I'm gonna pull the wire all the way to dash and see what the hell ive got going on Quote Link to comment
Jocucumber Posted February 23, 2017 Author Report Share Posted February 23, 2017 i just happy i'm not a moron! as far as this is goes lol Quote Link to comment
