scooter Posted July 24, 2016 Report Share Posted July 24, 2016 you can also run an msd off a matchbox, your just hooking it to the two wires inside on either distributor. I've tried switching these wires around and it seems to be timed and runs the same. Theres has been arguments on there saying the matchbox is good as and msd, and it probably is. It's also nice to have Rev limiting capability and retard for nos/boost etc. 1 Quote Link to comment
Stoffregen Motorsports Posted July 24, 2016 Report Share Posted July 24, 2016 I prefer to use the old single point, or even dual point, stock 510 distributors with a Pertronix Ignitor in them. They look most at home in a 510 engine bay. Finding parts to recurve a matchbox distributor is impossible. You'll have to make all those tweaks the old way. 3 Quote Link to comment
racerx Posted July 24, 2016 Report Share Posted July 24, 2016 Yep..pertronix, have mine for like 13 no issues. You set it and forget it. Dont buy cheap ass hotspark made in china, copy. 1 Quote Link to comment
racerx Posted July 24, 2016 Report Share Posted July 24, 2016 Just remember that pertronix will only work w single point 68-69 datsun 510. The rest is dual points. Quote Link to comment
Stoffregen Motorsports Posted July 24, 2016 Report Share Posted July 24, 2016 They can be made to work in the dual point distributors without much hassle. Quote Link to comment
datzenmike Posted July 24, 2016 Report Share Posted July 24, 2016 Do they handle a lower 0.8-1.0 ohm impedance coil and have a hotter spark? Do they shut off if the key is left on and the engine not started? or does the coil fry? Quote Link to comment
racerx Posted July 24, 2016 Report Share Posted July 24, 2016 Stoffregen, how can u make a dual point dist. Work for pertronix.? Quote Link to comment
510SSS Posted July 24, 2016 Author Report Share Posted July 24, 2016 Wow, ok so I'm already running the 79 620 Dizzy, the E12-92, but I have been having problems with it, already lost 2 modules. Do you guys really think the Pertronix is superior? I had one on my L-16 motor before and the thing burnt out the second week I got it and left me stranded on the side of the road. Seems really cheaply made hmm, how would I wire up my ignition to work with the 78 distributor? Could I just drop it in place of my 79 Dizzy or would I need to wire up an external module in order to regulate the spark? Thanks for clearing things up all. :confused: Oh and racerx im pretty sure you're mistaken about the 68-69 only single points, my 71 came with a single points distributor, so I think it may have been 68-71 not 69-69. Quote Link to comment
racerx Posted July 24, 2016 Report Share Posted July 24, 2016 No, my datsun is 71 and is dual points. Cross reference with autozone, fairly sure 68-69 or sss dist. With single point. Quote Link to comment
racerx Posted July 24, 2016 Report Share Posted July 24, 2016 Had to get single point dist, thats how i know 68-69 came with single point. Maybe urs came with single or orig. Owner took one off. Quote Link to comment
510SSS Posted July 24, 2016 Author Report Share Posted July 24, 2016 Wierd I wouldn't really trust the Autozone computers seen them totally wrong on simple things like spark plug part numbers, but ok whatever u say. :thumbup: Quote Link to comment
datzenmike Posted July 24, 2016 Report Share Posted July 24, 2016 Wow, ok so I'm already running the 79 620 Dizzy, the E12-92, but I have been having problems with it, already lost 2 modules. Do you guys really think the Pertronix is superior? I had one on my L-16 motor before and the thing burnt out the second week I got it and left me stranded on the side of the road. Seems really cheaply made hmm, how would I wire up my ignition to work with the 78 distributor? Could I just drop it in place of my 79 Dizzy or would I need to wire up an external module in order to regulate the spark? Thanks for clearing things up all. :confused: Oh and racerx im pretty sure you're mistaken about the 68-69 only single points, my 71 came with a single points distributor, so I think it may have been 68-71 not 69-69. Check again. You need the E12-80 module. The E12-93 if used on a non EFI engine will retard as it revs up. I think this can be defeated by grounding one of the wires but I don't know for sure. The '79-'80 L20Bs had the matchbox modules. The '79-'81 L28 and L24 six cylinder distributors also. The ones for the 4 cylinder are ok and say E12-80 on them. The '82-'83 non turbo zx and '82-'84 Maxima are not and are marked E12-93. The E12-93 modules work with the EFI engines and provide an electronic ignition retard function to tune out detonation/pinging. All '79-'81 A series used the E12-80 The Z20S in the '79 A10 used the E12-8- but for '81 a new internal module was introduced similar to the Z20E in the 200sx and all the Z series trucks. Here's one I have from a Maxima. If you look on the side there are terminals for two more wires marked I and W No the Pertronix definitely is not superior, just an option. The two questions below are not a problem with the matchbox. Do they handle a lower 0.8-1.0 ohm impedance coil and have a hotter spark? Do they shut off if the key is left on and the engine not started? or does the coil fry? 1 Quote Link to comment
flatcat19 Posted July 25, 2016 Report Share Posted July 25, 2016 how would I wire up my ignition to work with the 78 distributor? Could I just drop it in place of my 79 Dizzy or would I need to wire up an external module in order to regulate the spark? Thanks for clearing things up all. :confused: Already answered, a few times actually. http://community.ratsun.net/topic/195-hei-wiring-pics-w-writeup/ Quote Link to comment
datzenmike Posted July 25, 2016 Report Share Posted July 25, 2016 Ya perhaps I will try to get a second opinion if this doesn't work pretty soon. I think my mechanic and I have diagnosed the problem, it would seem that my plug wires got old and were broken internally, even though they looked fine on the outside, I watched under the hood in the dark the other night and they were arcing to the number 3 cylinder, I also found a small crack in my distributor cap, so I am replacing wires, cap, and rotor and re-routing my plug wire routing to try to prevent any arcing in the future, I will get back to you guys on the results from these changes soon. :thumbup: So not pre ignition then? If wires were replaced why are we fucking with the distributor? Did the new wires work or not? Quote Link to comment
510SSS Posted July 25, 2016 Author Report Share Posted July 25, 2016 fucking shit fucking. No the wires did not solve the problem I am still getting misfires and dropped cylinder 3 hence the changing dizzy discussion damn lol. Quote Link to comment
flatcat19 Posted July 25, 2016 Report Share Posted July 25, 2016 Are you diagnosing these things? Or is your mechanic? Does your "mechanic" know what he's doing? Look up a member named BustaNut. Take it to him. He will have you diagnosed in no time. 1 Quote Link to comment
datzenmike Posted July 25, 2016 Report Share Posted July 25, 2016 Wow, ok so I'm already running the 79 620 Dizzy, the E12-92, but I have been having problems with it, already lost 2 modules. Do you guys really think the Pertronix is superior? I had one on my L-16 motor before and the thing burnt out the second week I got it and left me stranded on the side of the road. Seems really cheaply made hmm, how would I wire up my ignition to work with the 78 distributor? Could I just drop it in place of my 79 Dizzy or would I need to wire up an external module in order to regulate the spark? Thanks for clearing things up all. :confused: Oh and racerx im pretty sure you're mistaken about the 68-69 only single points, my 71 came with a single points distributor, so I think it may have been 68-71 not 69-69. Still wanting to know about this. You need an E12-80 module not anything else. Told you it does some weird retard thing when revved up. Quote Link to comment
racerx Posted July 25, 2016 Report Share Posted July 25, 2016 Basically u have 2 issues, 1. Misfire 2. Pinging. If misfire coud b vacuum leak or weak spark 2. Pinging too advance or hot spots on cylinder walls. For vacuum, spray carb cleaner around carb area or intake, if rpm goes up, then vacuum leak, can also test w vacuum gauge. For pinging, too advance timing. I think mike said it with wrong distributor. One thing at a time, set base line, like w timing. If u have an xtra dist. That fits then try that. Quote Link to comment
flatcat19 Posted July 25, 2016 Report Share Posted July 25, 2016 Don't use carb cleaner to test for vacuum. Use brake clean. Carb cleaner is nasty shit. It will eat through so many different materials. It will also ignite with extreme heat, without spark. Quote Link to comment
Stoffregen Motorsports Posted July 25, 2016 Report Share Posted July 25, 2016 Stoffregen, how can u make a dual point dist. Work for pertronix.? Solid breaker plate from Nissan Motorsports. Do they handle a lower 0.8-1.0 ohm impedance coil and have a hotter spark? Do they shut off if the key is left on and the engine not started? or does the coil fry? If your system has a ballast resistor, they say to leave it, but there are pretty specific instructions as to the ohms. The Ignitor II has a stronger spark, but the original Ignitor is basically a points replacement system. If you use it in conjunction with their Flamethrower coil, it does make a difference. If you leave the key on, nothing blows up. At least in my experience. It's a hall effect sensor. Quote Link to comment
racerx Posted July 25, 2016 Report Share Posted July 25, 2016 Yep, left my ballast resistor on, per pertronix and have higher voltage coil. As far as using carb cleaner to find vacuum leak never had any issues. But good to know brake fluid works too. Quote Link to comment
flatcat19 Posted July 25, 2016 Report Share Posted July 25, 2016 Not brake fluid. Brake cleaner. Quote Link to comment
510SSS Posted July 25, 2016 Author Report Share Posted July 25, 2016 Ok, thank's mike, I didn't think of that, maybe I have the Maxima distributor so it is retarding the timing when I rev it up, and therefore causing it to misfire. Yes my mechanic does know what he is doing, the walls of his shop are covered with Datsun 510 race cars, and he learned from a professional Datsun engine builder, who was in the biz for over 30 yrs, quit hating flatogato start participating... :rofl: Quote Link to comment
510SSS Posted July 25, 2016 Author Report Share Posted July 25, 2016 So you're saying that the E12-80's have to be from a 4 cylinder car correct mike? So this one would work? http://www.rockauto.com/en/catalog/nissan,1979,510,2.0l+l4,1210015,ignition,distributor,7108?a=Referer+www.google.com+URL+%2F Quote Link to comment
flatcat19 Posted July 25, 2016 Report Share Posted July 25, 2016 Start participating? Ha! Fuck it. Mine runs. GL. 4 Quote Link to comment
