Stoffregen Motorsports Posted April 20, 2017 Report Share Posted April 20, 2017 New transmission, May 14th Did something get deleted? More forum drama I missed? Quote Link to comment
Lockleaf Posted April 20, 2017 Report Share Posted April 20, 2017 No, gato is predicting transmission failure number 2 the day this beast is finished. Crew said his finish date is may 13th. Quote Link to comment
crew521 Posted April 20, 2017 Author Report Share Posted April 20, 2017 the reason it blew apart is the (loading only) drive line got driven on and was not true.....it was supposed to load and unload only!!!! had to park to far from show and could resist getting on it.. it was not balanced/true in the least and it rattled the trans mount bolts loose and blew case apart right then and drive line turned and went round and round like a jump rope... Quote Link to comment
crew521 Posted April 20, 2017 Author Report Share Posted April 20, 2017 gonna use old blue fenders remnents to skirt the sides with :0 2 Quote Link to comment
crew521 Posted April 26, 2017 Author Report Share Posted April 26, 2017 nap time is close to over just doing so dress up on stuff 2 Quote Link to comment
crew521 Posted April 26, 2017 Author Report Share Posted April 26, 2017 quick and dirty good old fashioned paint strait lines to lay out frame work.... yellow will be fixed to bed and red will lift from the rear will be raised bed with orig tubs and dressed with this wood my wife be playing with .. :0 thought u guys might like that..clearing it currently 1 Quote Link to comment
crew521 Posted April 26, 2017 Author Report Share Posted April 26, 2017 good old cardboard template now the metal is cut and tacked forgot those pics and air cleaner is fit over carb and scraping the enormas custom cowl Quote Link to comment
crew521 Posted April 26, 2017 Author Report Share Posted April 26, 2017 center lexan is fitted and fixed to door on both sides and seems to be perfect for what i need/want out of it..opens and closes nicly..(not airtight LMAO but really look at this thing)(leaving the gap under for now have a few ideas for the future Quote Link to comment
LTJ Posted April 27, 2017 Report Share Posted April 27, 2017 Looking forward to seeing the timber fitted up! 1 Quote Link to comment
crew521 Posted April 27, 2017 Author Report Share Posted April 27, 2017 leftover fenders put to work one side 1st cut time to trim and do the other side used body line that follows the hood work almost flawlessly and then marked along cowl line and trimed for fit side #2 both trim ready trimmed and started working from the from the front to the back and the top of cowl line down to hood ussing sawhorses and a adjustable prop rod to hold high and low peice of hood up while tacking as true as possible with me only side 1 done side 2 going dang near as good but stopped in this pis to untack the supports from a few days ago to lift the closest corner to the winsheild up a bit new air cleaner fits after i smashed it a little flat..(was to nice to not bent it a bit for this ride..lol might even pull it off and rust it up a bit:) SMASHED but from the top looks good with hood open over all came out nicly for what i wanted for this Masterpiece :thumbup: Quote Link to comment
crew521 Posted April 28, 2017 Author Report Share Posted April 28, 2017 my today delima is hood ideas,,when setting hood on getting ready to bot it back in palce i decided to look at options and here they are..any way i choose except stock layout it will be pinned also so it can be taken off to get at whats under the lowest side..inupt???????????? 1 Quote Link to comment
crew521 Posted April 28, 2017 Author Report Share Posted April 28, 2017 check out emblems i hijacked off falcon i snagged 260 v8 from 1 Quote Link to comment
crew521 Posted April 28, 2017 Author Report Share Posted April 28, 2017 trying to help the rattle and avoid breaking the fresh plexi i just laid in i used some door/ window rubber gaskets..seems to work for now 1 Quote Link to comment
crew521 Posted May 1, 2017 Author Report Share Posted May 1, 2017 body drop covered AKA chanel skirt almost bed time got my print out on back of cab reviewing my idea tacked in nicley outters all tacked in and inner liftable piece ready for cross bars 1 Quote Link to comment
Stoffregen Motorsports Posted May 2, 2017 Report Share Posted May 2, 2017 Nice to see you back on it. I think this truck is a good candidate for a two piece driveshaft. The length limit (per tubing diameter) looks to be far exceeded and building a larger diameter shaft won't be easy using the stock Datsun rear u-joint flange and yoke. Also, not to be a hater, but I hope you don't actually drive your kids around in that thing...as cool as it is. 2 Quote Link to comment
crew521 Posted May 2, 2017 Author Report Share Posted May 2, 2017 i do plan on putting kids in it and a nice through the floor halo ring with a couple cross bar roll cage in it..and yes like ive been saying forever crossmeber is going in at half way point with a 2 peice shaft being built by driveline shop as we speak 2 Quote Link to comment
Stoffregen Motorsports Posted May 2, 2017 Report Share Posted May 2, 2017 Awesome. Great minds think alike. 1 Quote Link to comment
crew521 Posted May 2, 2017 Author Report Share Posted May 2, 2017 yes sir :thumbup: got more pics coming soon 2 Quote Link to comment
crew521 Posted May 3, 2017 Author Report Share Posted May 3, 2017 so change of heart on the wood i was gonna use..so i headed out and hit the local hardware store and asked to look at old ratty antique wood and low and behold i want pointed to these beautiful redwood rems they had left in a few dif sizes i took what the had and played with them like big jigsaw puzzle some measuring and cutting and figuring i came up with this..i then added a touch of weed burning flame to them and then a nice light stain/urethane 3 Quote Link to comment
crew521 Posted May 3, 2017 Author Report Share Posted May 3, 2017 all dry this morning and going back in this afternoon/eve...dropped seats at upholstery shop today in for a real treat on those i do believe :thumbup: 3 Quote Link to comment
