macgyver Posted November 14, 2016 Author Report Share Posted November 14, 2016 I have a r180 from a old 240 I need to figure out what to do to get it to work on my car that's all apart. I'll have to check through your thread to see what it took to get it to work. Nice car. like three b's said, it'll bolt right in, no modifications needed. :) Quote Link to comment
edekalil Posted November 16, 2016 Report Share Posted November 16, 2016 That R180 will drop right in but you'll need the R180's shafts. You could use the R160's but will first have to remove the dust shields otherwise it'll cut up the diffs shaft seal. Pull the diffs cover and see what the ratio is and pray it isn't 37:11 or 37/11=3.36. My buddy Qwik510 has the 3.36 in his Brock 510 with L20b and SU's and 5-speed andf says though it's great on hiway it's doggy anywhere else. If it's a 3.54 ratio 39:11 that would be much better though maybe a bit doggie in 3rd 4th depending on the power output of your motor. I'll save you some time,,if that diff is out of an automatic it's a 3.54, if out of a 4-speed 3.36. I have a few diffs, a R180 3.70 ratio, a Subie LSD clutch pack direct replacement diff 3.70 ratio and a couple stock 510 diffs with 3.70 ratio. Been thinking (thinking) about selling the Subie diff, it has the Perrin diff cover and is in excellent excellent shape. Replaced it with R180 3.54 diff because I though it was going bad, turned out the muffler was ever so slightly hitting up against undercoating making it sound like the diff. I'm in no hurry to replace diff because I have CV axles safety wired that makes it a job and a half to replace. thanks for the info, I have the r180 half shafts as well. I think it is the 3.36 ratio so not sure what I would have to do to change it or if it would be better to go with something else. I got it way back in the 90s before all the web was like it is today just had 510 Again news letters and the a copy of the UFO news letters I bought back then. I love the Internet and YouTube these days. I do plan to put an L20b in it with Mlkuni dule side drafts. Quote Link to comment
edekalil Posted November 16, 2016 Report Share Posted November 16, 2016 like three b's said, it'll bolt right in, no modifications needed. :) Your car is looking real good. Quote Link to comment
macgyver Posted November 29, 2016 Author Report Share Posted November 29, 2016 Your car is looking real good.Thanks! So I've been driving her everyday I can, I ordered a new seal about 2 months ago but didn't want to miss out on the nice summer/fall driving days... I just had it picked up.... My bro-in-law has a body shop. He's going to wet sand the entire car, hit a few little spots where some surface rust is just starting.. And than Matt clear it! Plus new undercoating! Can wait to get her back. Quote Link to comment
SteadFast Posted November 30, 2016 Report Share Posted November 30, 2016 Have to say it was a battle dealing with this rear diff but well worth the wait and issues I had installing everything. The Test drive was unbelievable! This cv conversion is hands down the best upgrade you could do to your dime! She rides so smooth ESP at my ride hieght....it feels like a new car! The Sti rear LSD is working as it should and the lower gear ratio isn't as bad as I thought it would be. Bonus are the lower rpm's at high way speeds. Love it! Moving on the my next "fix". Why was it such a battle? I'm looking to do this same kit, but it looks really straight forward. Curious to get your take. Quote Link to comment
macgyver Posted December 4, 2016 Author Report Share Posted December 4, 2016 Why was it such a battle? I'm looking to do this same kit, but it looks really straight forward. Curious to get your take.Hey steadfast, the conversion was Pretty straight forward, just needed to install the input shalfs into the diff before installing the diff. It's still the best modifaction I think for these dimes ...my battle wasn't with the new set up or its install, it was everything I tried to do to "Fix" my r160lsd multipul times, looking for a replacement and so on and so on. So for the confusion Quote Link to comment
SteadFast Posted December 4, 2016 Report Share Posted December 4, 2016 Hey steadfast, the conversion was Pretty straight forward, just needed to install the input shalfs into the diff before installing the diff. It's still the best modifaction I think for these dimes ...my battle wasn't with the new set up or its install, it was everything I tried to do to "Fix" my r160lsd multipul times, looking for a replacement and so on and so on. So for the confusion Did you have to specify that it was a Subi R180 or is it just this one: http://www.driveshaftshop.com/import-axles/datsun/datsun-510-240z-with-r180-differential-108mm-cv-conversion-kit Quote Link to comment
macgyver Posted December 4, 2016 Author Report Share Posted December 4, 2016 Did you have to specify that it was a Subi R180 or is it just this one: http://www.driveshaftshop.com/import- axles/datsun/datsun-510-240z-with-r180-differential-108mm-cv-conversion-kit That's the one.... If you were going to run an newer r160, than you could call and they'll swap out the stubs for the correct spline ones. Quote Link to comment
SteadFast Posted December 4, 2016 Report Share Posted December 4, 2016 I too have a Subi STI R180, and am fairly low so I am getting this! Quote Link to comment
macgyver Posted December 5, 2016 Author Report Share Posted December 5, 2016 I too have a Subi STI R180, and am fairly low so I am getting this!It'll feel like a new car after you install it! Zero vibrations. Smooth and silky! Quote Link to comment
macgyver Posted December 10, 2016 Author Report Share Posted December 10, 2016 All wet sanded with a Semi gloss clear coat! Can't wait to get her back! Hope it's not too dull looking. I didn't want it looking like high gloss. 1 Quote Link to comment
Stoney Posted December 12, 2016 Report Share Posted December 12, 2016 I love it, did you do the work yourself? If so, what grit did you use? DA sander or by hand? etc Quote Link to comment
Draker Posted December 12, 2016 Report Share Posted December 12, 2016 Looks good! Quote Link to comment
macgyver Posted December 13, 2016 Author Report Share Posted December 13, 2016 I love it, did you do the work yourself? If so, what grit did you use? DA sander or by hand? etcThanks, it's at my bro in laws shop, not sure what # sand paper or by hand, could find out for ya though. Quote Link to comment
datsunfreak Posted December 13, 2016 Report Share Posted December 13, 2016 No pics of it back together yet? ^_^ Quote Link to comment
macgyver Posted December 13, 2016 Author Report Share Posted December 13, 2016 Waiting on a new windshield... Hoping by this weekend. Quote Link to comment
macgyver Posted December 14, 2016 Author Report Share Posted December 14, 2016 So happy with how this came out!! Looks amazing in person, still full of dust, waiting on the new a windshield. So stoked!!! 1 Quote Link to comment
fisch Posted December 14, 2016 Report Share Posted December 14, 2016 Looks fabulous! Just the right amount of mojo. Quote Link to comment
macgyver Posted December 14, 2016 Author Report Share Posted December 14, 2016 Looks fabulous! Just the right amount of mojo.Thank you! I have to be honest, I was really worried that it wouldn't have enough shine to it but when I walked through the hanging tarps and saw it, it came out better than I thought it would. So glad I stuck with my guns, my bro in law was begging me to have him go through all the body work and make it "like" new again. It's only "original" once and I wanted to protect that quality and character she's aquired over her life time. Quote Link to comment
datsunfreak Posted December 14, 2016 Report Share Posted December 14, 2016 Honestly, I was prepared to hate it. But I do not. :thumbup: But it's making me miss my old car even more... ^_^ 2 Quote Link to comment
q-tip Posted December 15, 2016 Report Share Posted December 15, 2016 That is the same level of dull that every unpolished 510 has, doesn't look bad at all. 2 Quote Link to comment
macgyver Posted December 16, 2016 Author Report Share Posted December 16, 2016 Small photo shoot in the back yard. I have to say it again.....I absolutely love it. The entire surface is nice and smooth, unified and beautiful. :) 4 Quote Link to comment
Stoney Posted December 16, 2016 Report Share Posted December 16, 2016 Nice panel gaps Quote Link to comment
macgyver Posted December 16, 2016 Author Report Share Posted December 16, 2016 They're not too bad, i need to tweak the hood for sure. I took out the "lift" washers that one of the PO had in. Quote Link to comment
