DatsuNissanLove Posted April 7, 2016 Author Report Share Posted April 7, 2016 While the driveshaft is out, bang a new seal in. You should do this any time it's convenient to do so. They are only $4 and a minute to put in.cost me 10 but so wut..lol..had a question though.. wen installing it should it just fit flush or go all the way inside to where ders a stopping point? And wut did u use to bang the new one in.. im thinking of using a 32mm socket with a piece of wood behind it to hammer it in evenly..wut u think? 1 Quote Link to comment
datzenmike Posted April 7, 2016 Report Share Posted April 7, 2016 Block of wood over it to start and then poked it in with a smaller dowel. Make sure you grease the seal lips. 1 Quote Link to comment
DatsuNissanLove Posted April 7, 2016 Author Report Share Posted April 7, 2016 Block of wood over it to start and then poked it in with a smaller dowel. Make sure you grease the seal lips.well i cant do it with a flat piece of wood because of the output shaft.. i found a 2" piece of aluminum pipe in my back yard..fits perfect around the seal..ima try that..and mike should it fit flush with the core? Orshould the seal be pushed in a lil more? 1 Quote Link to comment
DatsuNissanLove Posted April 7, 2016 Author Report Share Posted April 7, 2016 and here it is right on top of the seal..perfect to install it right? 1 Quote Link to comment
DatsuNissanLove Posted April 7, 2016 Author Report Share Posted April 7, 2016 yess i did it.. well here is a pic of the seal and a 2" aluminum pipe next to it.. 1 Quote Link to comment
distributorguy Posted April 7, 2016 Report Share Posted April 7, 2016 Flush. That way you know its straight. If its tipped at all it'll leak. 1 Quote Link to comment
DatsuNissanLove Posted April 7, 2016 Author Report Share Posted April 7, 2016 Flush. That way you know its straight. If its tipped at all it'll leak.ok cool thanks.. freakin rain delayed me from proceeding 1 Quote Link to comment
datzenmike Posted April 8, 2016 Report Share Posted April 8, 2016 I carefully tap them in till they bottom, this will keep them aligned. A proper sized pipe will also do this. Don't crush them. The last one I installed was thinner? than the one I took out so when set in place the seal lips were a couple of mm farther into the transmission. I believe replacement front chev crank seals are this way also. The lips are now sealing an untouched, unworn place on the spline. 1 Quote Link to comment
DatsuNissanLove Posted April 8, 2016 Author Report Share Posted April 8, 2016 I carefully tap them in till they bottom, this will keep them aligned. A proper sized pipe will also do this. Don't crush them. The last one I installed was thinner? than the one I took out so when set in place the seal lips were a couple of mm farther into the transmission. I believe replacement front chev crank seals are this way also. The lips are now sealing an untouched, unworn place on the spline.yes i noticed that the new seal is thinner aswell thats why i asked if i should push it all the way in.. and your saying yah so ill do that..thanks mike 1 Quote Link to comment
Ranman72 Posted April 8, 2016 Report Share Posted April 8, 2016 also if its not to late always loosen the fill plug before the drain plug to make sure it will come out 1 Quote Link to comment
DatsuNissanLove Posted April 8, 2016 Author Report Share Posted April 8, 2016 also if its not to late always loosen the fill plug before the drain plug to make sure it will come outyah i did the complete opposite and took me an hour n a half to take the fill plug off lol.. but it wouldve been quicker with some help.. i used a plumbers wrench 1 Quote Link to comment
DatsuNissanLove Posted April 8, 2016 Author Report Share Posted April 8, 2016 The damage that the yoke had.. and my new one 1 Quote Link to comment
DatsuNissanLove Posted April 8, 2016 Author Report Share Posted April 8, 2016 good share draker..!!.. i got the exact same one but the gallon looks different now..no longer see thru..this is the new look of the sta-lube gear oil.. 1 Quote Link to comment
distributorguy Posted April 9, 2016 Report Share Posted April 9, 2016 I had to supply the support bearing when I got charged $240. You got a good price!!! Those bearings can run $75. And yo got the u-joints that you can reach the grease nipple on, instead of it being between the cups in the cast iron area. Very nice. 1 Quote Link to comment
DatsuNissanLove Posted April 9, 2016 Author Report Share Posted April 9, 2016 I had to supply the support bearing when I got charged $240. You got a good price!!! Those bearings can run $75. And yo got the u-joints that you can reach the grease nipple on, instead of it being between the cups in the cast iron area. Very nice.actually i supplied the bearing aswell.. he charged me 228.00 after all..plus i think the bearing was around 75.. so 303 total..give or take.. 1 Quote Link to comment
DatsuNissanLove Posted April 9, 2016 Author Report Share Posted April 9, 2016 Pic with the seal..outpic using a 32mm socket to push it in.. and one of it installed does that look like the one u installed mike? 1 Quote Link to comment
datzenmike Posted April 10, 2016 Report Share Posted April 10, 2016 Close enough, yeah. You have a '73? 1 Quote Link to comment
DatsuNissanLove Posted April 10, 2016 Author Report Share Posted April 10, 2016 Close enough, yeah. You have a '73?ok cool.. the seal was really easy to slide in..is that normal should it have been a lil harder? And yes mike its a 73.. howd you know? 1 Quote Link to comment
hobospyder Posted April 10, 2016 Report Share Posted April 10, 2016 mike really knows his trannies 1 Quote Link to comment
datzenmike Posted April 10, 2016 Report Share Posted April 10, 2016 ok cool.. the seal was really easy to slide in..is that normal should it have been a lil harder? And yes mike its a 73.. howd you know? It shouldn't 'slide in', it should be a snug fit in order to seal against the transmission case. You shouldn't have to 'pound' it in either. Doubt it's the wrong seal. The part number is 32136-U0100 and this seal was common to EVERY Nissan car from '70 up (not the 510 or 521) even the Xterra and may still be being used. mike really knows his trannies 2 Quote Link to comment
DatsuNissanLove Posted April 10, 2016 Author Report Share Posted April 10, 2016 It shouldn't 'slide in', it should be a snug fit in order to seal against the transmission case. You shouldn't have to 'pound' it in either. Doubt it's the wrong seal. The part number is 32136-U0100 and this seal was common to EVERY Nissan car from '70 up (not the 510 or 521) even the Xterra and may still be being used. this is the one i purchased from napa..specs.. 1 Quote Link to comment
DatsuNissanLove Posted April 11, 2016 Author Report Share Posted April 11, 2016 So the pic i above is the seal i got.. and i lift the car from the front.. some tranny fluid came out.. is that fluid supposed to be coming out even with a new seal?.. i figure its just coming out from the output shaft but not sure..? Quote Link to comment
banzai510(hainz) Posted April 11, 2016 Report Share Posted April 11, 2016 oil wil still come out if angled down Just refill when level Quote Link to comment
DatsuNissanLove Posted April 11, 2016 Author Report Share Posted April 11, 2016 Thank you guys Quote Link to comment
datzenmike Posted April 12, 2016 Report Share Posted April 12, 2016 It has to have the driveshaft spline installed to seal properly.. Quote Link to comment
