393stroker Posted November 16, 2015 Report Share Posted November 16, 2015 Bought a 69 521 trying to find some info on the sr20 swap 1 Quote Link to comment
Ratwagon1600 Posted November 16, 2015 Report Share Posted November 16, 2015 Wont work, never been done. Post an intro thread and some pics, you may get a better response. Your first post is kinda like walking into a party where no one knows you and instantly wanting everyone to be your best friend. Just sayin............... 2 Quote Link to comment
datzenmike Posted November 17, 2015 Report Share Posted November 17, 2015 Bought a 69 521 trying to find some info on the sr20 swap First one is free.... http://community.ratsun.net/topic/43133-project-smurfet-1971-521-datsun-sr20det/ there were at least 4 more for the 521 and even more for the later 620 truck. If you are really serious, locate the SEARCH function upper right of every page, just below the 510 and type "521 SR20 swap" or SR20 swap into 521 or SR20 swap into 620 as they are similar trucks. Then try KA24E and KA24DE swaps as they have similar transmissions and EFI info. Look for the Can AM box sold here for making the wiring hook ups easier. Mod helps those who help themselves 2 Quote Link to comment
Draker Posted November 17, 2015 Report Share Posted November 17, 2015 Wont work, never been done. Post an intro thread and some pics, you may get a better response. Your first post is kinda like walking into a party where no one knows you and instantly wanting everyone to be your best friend. Just sayin............... 6 Quote Link to comment
datzenmike Posted November 17, 2015 Report Share Posted November 17, 2015 's not a purse, it's a satchel!!! Indiana Jones had one. 1 Quote Link to comment
datson4life Posted November 17, 2015 Report Share Posted November 17, 2015 Theres a few sr 521s on ratsun 1 Quote Link to comment
TENDRIL Posted November 17, 2015 Report Share Posted November 17, 2015 pretty straight forward, it should run you around 5-6k when said and done 1 Quote Link to comment
MicroMachinery Posted November 17, 2015 Report Share Posted November 17, 2015 Hi. Bye. 2 Quote Link to comment
datzenmike Posted November 17, 2015 Report Share Posted November 17, 2015 There were no RWD SR20s used in N AM so you have to import one and the 5 or 6 speed plus the complete electronics and ECU for the EFI conversion. The rear end will handle it, so from the back to the front.... High pressure electric in line fuel pump Fuel return line. Length modified one piece drive shaft. Transmission mount relocated/modified. D21 speedometer sleeve to replace electronic speed sensor. One off engine brackets and probably the rubber mounts also. Oil pan modifications to clear the front 521 steering and crossmember. Custom exhaust system with larger 2" pipe. Custom rad and hoses If you want to survive this swap you will need Disc brake conversion (probably D21 VG calipers and vented rotors) Drums on back are fine if you keep them adjusted. Better tires. $5K sounds almost right if you do your own work. Double if you pay someone. 1 Quote Link to comment
spriso Posted November 17, 2015 Report Share Posted November 17, 2015 While this is putting a SR into a 620, a lof of the info will be similar to your 521 project: http://www.superstreetonline.com/how-to/additional-tech/ssts-1119-ins-and-outs-of-custom-engine-swap Good luck! Michael 1 Quote Link to comment
Charlie69 Posted November 17, 2015 Report Share Posted November 17, 2015 I believe that Sycloned916 Did this swap twice because the first truck was totaled. I cannot find the first truck thread and the start of the second truck thread. if any one has the links for these threads please post them here. http://community.ratsun.net/topic/24521-the-520/ 1 Quote Link to comment
393stroker Posted November 25, 2015 Author Report Share Posted November 25, 2015 Thanks everyone for the info...already have the drive train 1 Quote Link to comment
hosestop@msn.com Posted December 13, 2015 Report Share Posted December 13, 2015 I am doing my shop truck at this time again, did the brakes ,now motor and suspension in off topics. 1 Quote Link to comment
TENDRIL Posted December 16, 2015 Report Share Posted December 16, 2015 cooling/ piping, ECU management, motor mounts, trans mount, oil pan clearance, drive shaft, brakes 1 Quote Link to comment
Chrisdevasher Posted February 9, 2016 Report Share Posted February 9, 2016 swapped and still rocking drums all the way around :fu: :thumbup: Quote Link to comment
