Anderson521 Posted June 20, 2016 Author Report Share Posted June 20, 2016 Picked up a h190 from a 69 fairlady. They come stock with 3.7 gears so a huge jump from m the current 4.88s in the truck 1 Quote Link to comment
Anderson521 Posted June 20, 2016 Author Report Share Posted June 20, 2016 So started by pulling the old pins that hold the ebrake rod and unbolting the 4 nuts holding the backing plate to the housing and then finally moving to the brake lines 1 Quote Link to comment
Anderson521 Posted June 20, 2016 Author Report Share Posted June 20, 2016 The h190 will have 10 bolts around the outside and the h165 will have 8. Slide the axles out at least 3 inches and wiggle the gears free from the studs 1 Quote Link to comment
wayno Posted June 20, 2016 Report Share Posted June 20, 2016 Your going to have to change out the side gears, as the Roadster H190 has different axles than the 521. 1 Quote Link to comment
Anderson521 Posted June 20, 2016 Author Report Share Posted June 20, 2016 Your going to have to change out the side gears, as the Roadster H190 has different axles than the 521.You sir are 100% correct Here's the roadster gears next to my donor with the appropriate spline side gear. 1 Quote Link to comment
Anderson521 Posted June 22, 2016 Author Report Share Posted June 22, 2016 Switched gears a little bit and got my alternator wired up with some 3 gauge and a breaker to stay on the safe side 1 Quote Link to comment
Anderson521 Posted June 22, 2016 Author Report Share Posted June 22, 2016 And these hammer crimpers are the shit 1 Quote Link to comment
Anderson521 Posted June 24, 2016 Author Report Share Posted June 24, 2016 Carpet coming soon 2 Quote Link to comment
Anderson521 Posted June 26, 2016 Author Report Share Posted June 26, 2016 Bent up a piece of sheet metal and threw some paint on it, I'll be ordering the gauge soon. Electric style which is a pretty easy switched power, ground and gauge wire set up for my gm vehicle Speed sensor 1 Quote Link to comment
Anderson521 Posted July 12, 2016 Author Report Share Posted July 12, 2016 So to start my gear swap i began to disassemble my donor which was blown and had rusted a little and didn't want to separate. I Promptly threw it out the door 1 Quote Link to comment
hobospyder Posted July 12, 2016 Report Share Posted July 12, 2016 :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: 1 Quote Link to comment
Anderson521 Posted July 12, 2016 Author Report Share Posted July 12, 2016 Taking the bearing caps off After caps are off I massaged the gears out of the housing There's a pin holding the gear cluster together which incidentally cannot be slid out with the ring gear in place so those bolts gotta go. I used a chisel and a hammer to flatten the lock tabs I don't have any pics from here of the disassemble but make sure to keep an eye on the brass shims behind the gears, swapped out the small spline for the large, rebolt the ring gear then torque. and don't forget the lock tabs! 1 Quote Link to comment
Atomic Posted July 15, 2016 Report Share Posted July 15, 2016 So my options are 1. Buy used tranny for 600 with warranty 2. Have shop rebuild for 500 with warranty 500 for only changing out that ball bearing or does it include something else too? :confused: 1 Quote Link to comment
Anderson521 Posted July 15, 2016 Author Report Share Posted July 15, 2016 500 for only changing out that ball bearing or does it include something else too? :confused:[/quo It's so pricey because these transmissions are a bitch to take apart and yes it was only for the ball bearings, I grabbed a replacement at a pick n pull 50% weekend 1 Quote Link to comment
Atomic Posted July 15, 2016 Report Share Posted July 15, 2016 500 for only changing out that ball bearing or does it include something else too? :confused:[/quo It's so pricey because these transmissions are a bitch to take apart and yes it was only for the ball bearings, I grabbed a replacement at a pick n pull 50% weekend Oh wow.. If I were to live there I could have done it for almost nothing :rofl: Volvos M47 was real pain in the ass too. But nice that you got the replacement! All the best for the build :thumbup: 1 Quote Link to comment
Anderson521 Posted July 16, 2016 Author Report Share Posted July 16, 2016 Thanks man! And the replacement tranny was only 70 bucks so I lucked out 1 Quote Link to comment
datson4life Posted July 16, 2016 Report Share Posted July 16, 2016 Sweet! Burnout video! 1 Quote Link to comment
Jester Posted July 16, 2016 Report Share Posted July 16, 2016 I just ordered an NV5600 for my Dodge. $3200.oo :blink: :console: 1 Quote Link to comment
The Engine Room Posted July 17, 2016 Report Share Posted July 17, 2016 I just ordered an NV5600 for my Dodge. $3200.oo :blink: :console: You blow 6th? 1 Quote Link to comment
Anderson521 Posted July 17, 2016 Author Report Share Posted July 17, 2016 I just ordered an NV5600 for my Dodge. $3200.oo :blink: :console: God damn! Well hopefully you'll never have to mess with it again 1 Quote Link to comment
Anderson521 Posted July 17, 2016 Author Report Share Posted July 17, 2016 Sweet! Burnout video! Soon I'm going to the muffler shop this week so it will be at full potential! 1 Quote Link to comment
Jester Posted July 17, 2016 Report Share Posted July 17, 2016 It was getting a sticky spot in the 3rd-4th gate. What ever the hell it is decided to just say fuck it and quit. If I hold it REAL hard in third it will work and fourth is there but it wont go in. All other gears seam fine. Fluid was changed to synth. about 5K miles ago. But yes, sixth was a little gravley. I love my truck and I wasn't willing to sacrifice the sixth gear for a NV4500. 2 Quote Link to comment
The Engine Room Posted July 17, 2016 Report Share Posted July 17, 2016 You should send me your old one. I've been looking for a busted one. PM me and we might could do some horse trading. 1 Quote Link to comment
Jester Posted July 18, 2016 Report Share Posted July 18, 2016 Ahhhhhhhh no. The core charge was $1600. 1 Quote Link to comment
