sebpv Posted October 19, 2015 Report Share Posted October 19, 2015 Do you guys know what material it is made of or if I can purchase it anywhere. I couldnt find it on carpartsmanual.com A friend of mine with turn one on a lathe using regular mild steel but I fear it wont be strong enough. Quote Link to comment
banzai510(hainz) Posted October 19, 2015 Report Share Posted October 19, 2015 YOur talking E bonics Pin squirted what? the chain oiler that near the bottom sproket??????? Yes Nissan dealer. Most dont need replacing unless a loose chain tear them up Quote Link to comment
sebpv Posted October 19, 2015 Author Report Share Posted October 19, 2015 yes indeed the chain oiler. Have you had luck finding the P/N? EDIT: my blind eyes found it... 13081-21000 Jet oil, timing chain sorry for the lost time 1 Quote Link to comment
sebpv Posted October 19, 2015 Author Report Share Posted October 19, 2015 As I thought, Everything Nissan and ebay dont have it Quote Link to comment
flatcat19 Posted October 19, 2015 Report Share Posted October 19, 2015 Squirter. Quote Link to comment
sebpv Posted October 19, 2015 Author Report Share Posted October 19, 2015 I just went with a broad description. Im sure someone here doesnt know yet what it does. Quote Link to comment
KoHeartsGPA Posted October 19, 2015 Report Share Posted October 19, 2015 Squirters r fun. Quote Link to comment
Doctor510 Posted October 19, 2015 Report Share Posted October 19, 2015 yes indeed the chain oiler. Have you had luck finding the P/N? EDIT: my blind eyes found it... 13081-21000 Jet oil, timing chain sorry for the lost time Why do you need one? I have some that are used here in AZ Quote Link to comment
MicroMachinery Posted October 19, 2015 Report Share Posted October 19, 2015 Hello. I'm here for the squirter discussion. 5 Quote Link to comment
sebpv Posted October 19, 2015 Author Report Share Posted October 19, 2015 Doc, I tried to send you an email, clean your mailbox. I need it because mine is worn out and while its still does the job, I was hoping to replace it. A new chain will be installed to it should be ok. Has someone successfully removed one without rending it useless? I have a spare block that isnt being used at the moment. For quote, my postal code is t9m2c6, Cold Lake, AB. Thanks Quote Link to comment
510freak Posted October 19, 2015 Report Share Posted October 19, 2015 Hello. I'm here for the squirter discussion. 1 Quote Link to comment
MicroMachinery Posted October 20, 2015 Report Share Posted October 20, 2015 Changed the title? Too late... corruption has already taken hold. 2 Quote Link to comment
sebpv Posted October 20, 2015 Author Report Share Posted October 20, 2015 Anybody having a valid answer as to how to remove the chain oiler safely? Quote Link to comment
flatcat19 Posted October 20, 2015 Report Share Posted October 20, 2015 You said yours wasn't damaged. Right? Why the desire to replace it? If it's spitting oil, its working. Quote Link to comment
MicroMachinery Posted October 20, 2015 Report Share Posted October 20, 2015 He doesn't like squirters, apparently. Quote Link to comment
sebpv Posted October 20, 2015 Author Report Share Posted October 20, 2015 My L16 which im using has a damaged one. Its still lubes but... I further damaged it by removing it... My L20B has one ALMOST intact but I dont want to mess it up too. Capisce? 1 Quote Link to comment
flatcat19 Posted October 20, 2015 Report Share Posted October 20, 2015 Capisce? If she keeps squirting someone's going to capsize. 1 Quote Link to comment
KoHeartsGPA Posted October 20, 2015 Report Share Posted October 20, 2015 You said yours wasn't damaged. Right? Why the desire to replace it? If she's squirting, she's lubricated. 1 Quote Link to comment
Draker Posted October 20, 2015 Report Share Posted October 20, 2015 Vice grips... twist, pull. I'm pretty sure it's a pressed fit. Quote Link to comment
KoHeartsGPA Posted October 20, 2015 Report Share Posted October 20, 2015 Two fingers works as well, Craig, no need for tools... 2 Quote Link to comment
flatcat19 Posted October 20, 2015 Report Share Posted October 20, 2015 Do it like a pirate. Pull on it with your teeth. Then lick the alphabet. Oh. Working on cars. Never mind. 2 Quote Link to comment
KoHeartsGPA Posted October 20, 2015 Report Share Posted October 20, 2015 :ROFL: Quote Link to comment
shacks510 Posted October 20, 2015 Report Share Posted October 20, 2015 You would be ok not using it. Oil draining down the front from the head will get on the chain, and the chain tensioner block has a jet that squirts oil on the bottom sprocket on the tension side. There is a lot of oil being slung around already from the moving parts. Only the L16/18/20B have the oiler peg. L6 and naps Z blocks don't use them. Tap it and put in an allen head plug. Just don't leave it an open hole. 2 Quote Link to comment
