datsunaholic Posted September 21, 2015 Report Share Posted September 21, 2015 Your descriptions of what the starter is doing are quite confusing. You said it isn't doing anything, then said it's clicking, now you say it's rolling. Which is it? 1) If it's doing nothing, it will make no sound at all. The dash lights won't dim. That's sign of a bad switch or broken/disconnected wiring. 2) If it does nothing EXCEPT make the lights dim or go out, that's either a dead battery or bad connections at the battery. 3) If it goes "click" ONCE, and the lights go out, that's a bad connection at the battery. Usually moving the battery cables makes the lights go back on, but it then just happens again unless they're cleaned and put on tight. 4) If it goes "CLANK", CLUNK. or something else relatively loud, dims the lights (but not out completely, every time you turn the key, that's usually the battery-to-starter cable isn't connected properly to the starter solenoid OR the starter is bad (bad brushes or a bad armature). 5) If it goes "Whrrrrrrrrr", sort of like a big drill, that's a bad bendix in the starter (it's spinning but not engaging the engine) OR you're missing teeth on the flywheel. 6) If it makes crunching clunking noises like a rock stuck in a garbage disposal that's a loose flywheel, broken ring gear, bad bendix, loose starter, or a myriad of very bad mechanical things. 7) If it goes Rrr-Rrrr-Rrr, that's the engine turning over. If it's doing that too slowly, that's a bad battery, though it can be a weakened starter. 2 Quote Link to comment
banzai510(hainz) Posted September 21, 2015 Report Share Posted September 21, 2015 Datsunaholic I think you got it covered This is a simple fix unless sombody fucked something up.. I had starter issues with my 521 . ONly to find out after 3 starter swaps, cables find out it was a weak ignition switch. I added a Ford relay and all is good 2 Quote Link to comment
paradime Posted September 21, 2015 Report Share Posted September 21, 2015 Had the same thing happen in my second 510. I must have spent $250 chasing that gremlin, only to find it was my starter switch. Opened it up brushed off the contacts and BINGO! Hard way to learn you don't spend a dime until you'er 100% sure it needs to be spent. 1 Quote Link to comment
Emilio's79620 Posted September 21, 2015 Author Report Share Posted September 21, 2015 Hey thank you and sorry for being confusing but now I actually believe my battery is dead because I took it to my other 620 and the lights were really dim also the sticker on the battery says 07 I didn't see it until I removed the battery so I'm pretty sure sitch is good as soon as I get a new one 1 Quote Link to comment
Emilio's79620 Posted September 21, 2015 Author Report Share Posted September 21, 2015 Banzai and paradise how would I go about locating these switches I would really like to further my knowledge on my trucks 1 Quote Link to comment
Emilio's79620 Posted September 21, 2015 Author Report Share Posted September 21, 2015 *paradime 1 Quote Link to comment
Emilio's79620 Posted September 21, 2015 Author Report Share Posted September 21, 2015 Also datsunaholic id say #5 1 Quote Link to comment
Hawaiian620 Posted January 6, 2016 Report Share Posted January 6, 2016 So much good info! My truck won't start. I started on Sunday, there was one crank where nothing happened (non starter noise), then it started on the next turn. Changed spark plugs yesterday and nothing from the starter. I used a screw driver to test the starter. It cranked twice and now will only make a "Clank, Clunk" sound. I'm assuming its my starter after the screw driver test. I'll have o'rillys test the new starter at the store before I take it home. If that doesn't work I'll try a new igniton switch and possibly a relay switch. Does anyone know where I can get a fuse box diagram for my 77 620? I've tried searching. Also, is there a ignition or starter fuse? I'm not sure if you helped this guy, but this thread had a lot of info for me! Thanks guys! Second time since I've had the truck ( a week) you guys have provided great information! 1 Quote Link to comment
datzenmike Posted January 7, 2016 Report Share Posted January 7, 2016 Make sure your battery is up to the job and charged up. Clean and tighten the battery terminal clamps, clean and tighten the negative cable where it bolts to the head behind the fuel pump, clean and tighten the positive battery cable where it bolts onto the starter. Don't assume! Do it. If it (the starter) cranks the engine over every time when using a screwdriver, but hit or miss with the key, it can be two things. Possibly the ignition switch. More likely a weak voltage start signal getting to the starter from the ignition switch. This is where a hot start relay works best. I started on Sunday, there was one crank where nothing happened (non starter noise), then it started on the next turn. Changed spark plugs yesterday and nothing from the starter. I used a screw driver to test the starter. It cranked twice and now will only make a "Clank, Clunk" sound. I'm assuming its my starter after the screw driver test. I'll have o'rillys test the new starter at the store before I take it home. You know what you mean but not everyone else does. "there was one crank where nothing happened (non starter noise)" It can't crank and also not make starter noise. I assume this was with the ignition key? "I used a screw driver to test the starter. It cranked twice and now will only make a "Clank, Clunk" sound". All this using the screwdriver??? or the clank clank sound is with the key?? 1 Quote Link to comment
Charlie69 Posted January 7, 2016 Report Share Posted January 7, 2016 Here is the 77 Wiring diagram. You can download the pdf here and take the pdf to a copy center and have it blown up. http://www.davidcmurphy.com/olddat/data/dat620-1977.pdf 1 Quote Link to comment
Hawaiian620 Posted January 7, 2016 Report Share Posted January 7, 2016 Make sure your battery is up to the job and charged up. Clean and tighten the battery terminal clamps, clean and tighten the negative cable where it bolts to the head behind the fuel pump, clean and tighten the positive battery cable where it bolts onto the starter. Don't assume! Do it. All these items were double checked. I even tried to start it with the battery from my xterra with no luck. Used only the key, not screw driver while the Xterra battery was in. No noise besides the clicking of the relay on the passenger side (fuel pump relay?) and the "no seat belt" beep. I did not hear the starter at all. If it (the starter) cranks the engine over every time when using a screwdriver, but hit or miss with the key, it can be two things. Possibly the ignition switch. More likely a weak voltage start signal getting to the starter from the ignition switch. This is where a hot start relay works best. The starter does not crank the engine at all now (key or screwdriver don't do anything). It cranked it twice, but that was it. Now it just make a "clank/clunk" sound. It will only do this with the screw driver method, I do not hear anything when using the key. I tried wiring up the hot start relay and now the seat belt sound doesn't sound off unless I use the screw driver. You know what you mean but not everyone else does. "there was one crank where nothing happened (non starter noise)" It can't crank and also not make starter noise. I assume this was with the ignition key? When I turn the key the relay clicks and the seat belt sound comes on, I can't hear the starter at all. When I use the screwdriver I hear the starter "Clank/Clunk" and well as the seat belt and relay. "I used a screw driver to test the starter. It cranked twice and now will only make a "Clank, Clunk" sound". All this using the screwdriver??? or the clank clank sound is with the key?? "Clank/Clunk is only while using the screwdriver. I don't hear anything besides the relay and seat belt beep. While using the key. I'm ordering a new starter today and a new ignition cylinder. I'm going to disconnect the hot start relay untill I have the new starter and cylinder installed. 1 Quote Link to comment
datzenmike Posted January 7, 2016 Report Share Posted January 7, 2016 The hot start can't affect the seat belt warning so recheck how it's wired. 1 Quote Link to comment
Hawaiian620 Posted January 7, 2016 Report Share Posted January 7, 2016 Alright. I have the picture saved and the thread bookmarked. I'll triple check everything. I'll be installing the new starter and ign cylinder on sunday, so in the mean time I'll triple check and pretty up the hot start. The only thing i'm unsure of is the wire coming from the ign. cylinder going to the hot start relay. I connected it to the same black/yellow wire that went to the starter solinoid. One from close to the starter and the other from close to the ign cylinder. So the relay has that same wire BLK/Yellow) going to it twice. Is that correct or am I suppose to connect a differnent wire from the cylinder? On a side note: I did find 2 wires with a fuse connected to one and the other was loose, I connected those and my marker lights would stay on with or without the key in, so I unplugged that. 1 Quote Link to comment
Hawaiian620 Posted January 12, 2016 Report Share Posted January 12, 2016 Installed new starter and ign. cylinder. Starts like a champ! Thanks again for all the info Quote Link to comment
