Are these wheels rare?
WallRocket
  • Replies 13
Probably chev or ford turbine rims. I had some not as wide on my Bronco and the spokes were rubbery. They will fit a Datsun but you won't be able to lower your ride height and even if the fender is close they will hit on big bumps and damage the tire and the fender. Good for those with a well raised ride and wanting a meatier tire on their trucks. The fronts will probably rub the frame on turns. My 10.5X31s on 7" rims sure did.
  • 1 month later...
